  3. Domoticz
  4. Error Sending switch command
57 Posts 11 Posters 34.7k Views 5 Watching
  • N
    N
    NBM
    wrote on last edited by NBM
    It shows everytime when im reset the sensor.
    • sundberg84S
      sundberg84S
      And when you switch it looks like this:
      But what about the gateway?
      • N
        N
        NBM
        Only this is showing when i switch the sensor.
        Where do i find the log on gateway? GW log?
        • sundberg84S
          sundberg84S
          Yea, the serial log from your arduino - connect the gateway to your computer and open the serial monitor in the arduino IDE.
          Another thing that you can try is to remove the device completley from domoticz, reset the node and add it again in Domoticz.
          H 1 Reply Last reply
          • sundberg84S sundberg84
            H
            H
            hugo_pn
            @sundberg84 said:
            Another thing that you can try is to remove the device completely from domoticz, reset the node and add it again in Domoticz.
            I'm having exactly the same problems as NBM.
            I've tried doing as suggested by soundberg84.
            It worked for one Node(relay) but another one does not seam to get up and working. Using the serial gateway it's working.
            I find odd that (Motion Sensor) Nodes are always good and working. It seems to be something concerning relays. Because when the problem occurs it affects all the relays simultaneously.
            My setup is a Raspberry Pi with a serial Gateway. I've had the same problem with the stable version and the beta version.
            Another thing that I've noticed, if there are two Raspberry Pi with the same setup, and with out having the " Accept new Hardware Devices Allow for 5 Minutes " turned on, without resetting the a (Motion Sensor), Domoticz recognizes them on the devices panel.
            Hugo
            • sundberg84S
              sundberg84S
              @hugo_pn If you are using the default relay sketch you need ack back from the gw to switch it. Is the problem in Domoticz (Error sending switch command) or it doesnt get switched?
                H
                H
                hugo_pn
                I am using the default relay sketch with button.
                Ack back = acknowledge?
                The message I receive from Domoticz is (Error sending switch command...)
                when the message doesn't appear it switches.
                • sundberg84S
                  sundberg84S
                  In new Domoticz beta there is so you can enable/disable ack. Havent tried that myself but maybe you can try to change that.
                  Also what does your gw serial log say? Maybe we can find some clues there...
                  • J
                    J
                    jlaraujo
                    I'm having the same issue, running Version: 2.3530 Build Hash: 9eef872
                    The sensor is number 1, and as soon as i try to change the state i get the "Error sending switch command, check device/hardware !"
                    This is what the domoticz is sending:
                    0;0;3;0;9;send: 0-0-1-1 s=35,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                    It seems that the problems is that the sensor does not reply correctly, how do i parse the message and reply?
                    Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
                    fetsF 1 Reply Last reply
                    • J jlaraujo
                      fetsF
                      fetsF
                      fets
                      st=fail means that the message was not received. So this is a hardware issue
                      • macieiksM
                        macieiksM
                        macieiks
                        Hello guys,
                        I had the same problem with st=fail, also with this output: "Error sending command, check your hardware/device (blablabla :D)". I can give you here my hints, maybe they will help you. First of all I am using the latest beta domoticz and beta mysensors library v1.6.
                        I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage.
                        I have Arduino Mega2560 installed 1 week ago with 16 channel 12v relay board together. I had the the same problem like you "Error sending command, check your hardware/device". Two days ago I realized that maybe there is a problem with my powering my gateway. I have RFXtrx433, APCups and Ethernet Arduino Uno gateway connected to Raspberry Pi USB. I connected my MySensors gateway separately via 5V charge to the wall socket and this error problem is gone. Conclusion was this that my Raspberry couldnt supply enough current for all attached devices. Now I am planning to install PiHut USB hub with external power supply and move all connected USB interfaces to it and then just with one connection cable to my raspberry (maybe RFX will work better :) we will see).
                        Update us if these two hints helped you ;D.
                        Maciek
                        RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
                        RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
                        RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
                        H J 3 Replies Last reply
                          H
                          H
                          hugo_pn
                          Sorry for not replying but the error hasn't been appearing, só I cant show the log. From what I've read there is no log file in Domoticz.
                          Haven't tried to enable/disable ack.
                          • macieiksM macieiks
                            Hello guys,
                            Maciek
                            H
                            H
                            hugo_pn
                            wrote on last edited by hugo_pn
                            #23
                            @macieiks said:
                            Hello guys,
                            I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage."
                            This may come into a great help, I have two external antennas that I thought where damaged since arrival, maybe this is the problem. I'm going to try this next week.
                            Although, this still makes me thinking of distance, the error appears with the hardware separated by +- 3m with no obstacles .
                            N 1 Reply Last reply
                              Hello guys,
                              Maciek
                              J
                              J
                              jlaraujo
                              @macieiks Could't find what my problem was. I've tried changing the gateway code to the sensor, same issue, change the radios, the same thing.
                              I ended up downloading again the Mysensors library, the same issue, i then changed the baud rate for the debug and serial gateway to 19200 and that seemed to solve the issue, i can now issue commands to the nodes, thanks for the help.
                              My sensor and gateway are all Pro mini, 8v 8Mhz, i remember now that i've read something in the forum, but can't find it now.
                              • H hugo_pn
                                @macieiks said:
                                Hello guys,
                                N
                                N
                                NBM
                                @hugo_pn Is's possible to see the sketch? Im insecure where to alter the sketch.
                                • N NBM
                                  H
                                  H
                                  hugo_pn
                                  @NBM
                                  I'm trying to find it. As soon as I do and if I do I'll tell.
                                  Chears
                                    Hello guys,
                                    Maciek
                                    H
                                    H
                                    hugo_pn
                                    #27
                                    @macieiks said:
                                    Hello guys,
                                    Can't find the specific line. The most similar one is in the MyConfig.h line 115
                                    #define RF24_PA_LEVEL_GW RF24_PA_LOW
                                    Going with the GitHub file I don't even find it...
                                    Where exactly did you change the mentioned above?
                                    Hugo
                                    P.S. I can't find the V 1.6 library for my sensors. That's why I mentioned github
                                      1.6 is the default branch when you go to the github project.
                                      • N
                                        N
                                        NBM
                                        This is what im getting when im trying to turn on the light.
                                        0;0;3;0;9;send: 0-0-1-1 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                                        • sundberg84S
                                          sundberg84S
                                          #30
                                          st=fail means the gw radio doesnt reach the node.
                                          It can be a power issue (search the forum) which can be fixed with caps and/or other power.
                                          It can be a range issue and then you need a repeater.
