  3. Trouble with ethernet gateway
5 Posts 2 Posters 2.2k Views 1 Watching
  • dakkyD Offline
    dakkyD Offline
    dakky
    Hello again ;)
    I'm trying to go with the EthernetGateway and a w5100 ethernetshield.
    I am not sure, if the ethernet part is working.
    why?
    1. I can't finde the nodes in domoticz (although domoticz claims to be connected to the GW)
    2. when doing an nc to the gateway:port nothing happens
    the nodes can find the GW, at least in the gw serial monitor i can see them polling for an ID
    Log:
    0;255;3;0;9;Starting gateway (RNNGAS, 1.6.0-beta)
    IP: 192.168.100.10
    Any Idea?
    Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
    Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
    Software: MySensors 2.0development
    • F Offline
      F Offline
      flopp
      I also just setup an Ethernet Gateway, was using Serial before.
      If you have DEBUG mode ON you shall see data from the nodes in Arduino IDE Serial Monitor.
      Do you see data coming from Sensor?
      If you see them in Arduino IDE they should appear in Domoticz.
      • dakkyD Offline
        dakkyD Offline
        dakky
        As soon as i hardcode a node ID in my sketch, i can see everthing as usual in die serials (node reporting values, arriving on gateway, signing ok etc)
        As soon as i set a AUTO id, nothing works, because i get no node id from domoticz
        • F Offline
          F Offline
          flopp
          Try to erase EEPROM in arduino. You find the sketch under MySensors-Clear....
          If that node has been connected before maybe that is the problem.
          • dakkyD Offline
            dakkyD Offline
            dakky
            hmm this helped ... i think oO did a lot of stuff and suddenly iw works :confused: really strange
