  3. repeater node with sensor
12 Posts 5 Posters 8.6k Views 1 Watching
  • mfalkviddM
    Yes you can combine sensor and repeaters.
    Use the sensor sketch, but change gw.begin according to http://www.mysensors.org/download/sensor_api_15#create-repeating-nodes an change gw.sleep to gw.wait
    I think that's all that needs to be done.
    • crankyC
      crankyC
      cranky
      wrote on last edited by cranky
      You sure can. I made early on a MotionSensorRepeater using 1.5.0 . The gotcha is you need to implement some sort of NON_BLOCKING rate limiting so the sensor doesn't spam the repeater. If you use DELAY(), you will lose messages. A lot of them.
      Also, I'm using a junky Sparkfun PIR sensor for this, with NO potentiometers for sensitivity or triggered duration, so I had to do duration in software. That's why the extra complication.
      #define NODE_ID 3
      #define CHILD_ID 5   // Id of the sensor child
      String ROOM_ID = " ID 5, living room repeater" ;
      unsigned long MIN_TIME_TRIGGERED = 60000 ; // Time for sensor to report "off". Normally set on the PIR itself but this is junky sparkfun.
      boolean previousTripped = LOW;
      unsigned long PREVIOUS_TRIPPED_TIME = millis();
      unsigned long MIN_RETRIGGER = 3500;
      // Initialize motion message
        gw.begin(NULL, NODE_ID, true);
        gw.sendSketchInfo("Motion Sensor", "1.0");
        gw.present(CHILD_ID, S_MOTION);
        // Sensor must be HIGH and not yet sent the status of the sensor
        if ((tripped == HIGH) && (tripped != previousTripped) ) {
          Serial.print(tripped); Serial.println(ROOM_ID);
          gw.send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
          previousTripped = tripped;
        // Is sensor HIGH, already sent to gateway, and under the minimum time to trigger? Then don't send
        if ( (PREVIOUS_TRIPPED_TIME + MIN_RETRIGGER) < millis() ) {
          if ( (tripped == HIGH) && (tripped == previousTripped) ) {
            Serial.println("Counter Reset"); PREVIOUS_TRIPPED_TIME = millis();
        // Is sensor low and not sent? Then send LOW to gateway
        if (tripped == LOW) {
          if ( ((PREVIOUS_TRIPPED_TIME + MIN_TIME_TRIGGERED) <= millis() ) && (tripped != previousTripped) ) {
        gw.process(); // makes the node repeat
      A 1 Reply Last reply
      • E
        E
        ericvdb
        wrote on last edited by ericvdb
        Keep this in your loop otherwise it will not process messages:
        PS @cranky beat me with an example ;)
        • mfalkviddM
          gw.wait() already calls process() so there is no need to call process if gw.wait is used
          See https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MySensor.cpp#L832
          • crankyC cranky
            #define NODE_ID 3
            abrasha
            wrote on last edited by abrasha
            @cranky
            thanks a lot all of you,
            cranky - i made a similar sketch using the same method with if XXXX > millis:
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            DHT dht;
            float lastTemp;
            float lastHum;
            boolean metric = true;
            unsigned long oldTime;
              gw.begin(NULL, AUTO, true);
              oldTime = 0;
              gw.sendSketchInfo("Repeater Node", "1.0");
              if((millis() - oldTime) > 600000)
              oldTime = millis();
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                Serial.print("T: ");
              if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
            its just the regular humidity sensor with gw.begin in repeater mode and gw.process in the end(with no sleep time) and the "anti-spam" is the if((millis() - oldtime) > 600000) statement so i still have reading every 10 minutes.
            is that ok or the dht22 delay can interfere with the repeater operation?
            also, the send.sketchc should be "repeater" or "humidity"?
            • mfalkviddM
              Using delay can cause the node to miss messages received during that time. Use gw.wait instead.
              I would call the sketch something like "Repeater+Humidity". The name is just for you to make you remember which node does what. It is not used by the system.
              By the way, your indentation is off. The code would be easier to read if you use Ctrl+T in the Arduino IDE (CMD+T on Mac)
              • A
                abrasha
                ok that ctrl+t is realy a nice tip. thanks.
                about this delay - delay(dht.getMinimumSamplingPeriod());
                it comes with the humidity sensor sketch and i thought it is crucial for the sensor to work.
                did you meant replace this line with the gw.wait?
                maybe i can delete it anyway because the whole loop doesnt perform until 10 minutes passed.
                • E
                  E
                  ericvdb
                  mfalkvidd means:
                  gw.wait(dht.getMinimumSamplingPeriod());
                  • crankyC
                    crankyC
                    cranky
                    Looking at the code, there's no good reason to use that delay at all. You're already waiting for 600 seconds with the
                    loop. The Delay is only recommended in the main codebase so that the sensor has time to regenerate the data. Some sensors have to wait for a bit or the measurement will be off, but we're talking about milliseconds here.
                    Just delete the whole line:
                    and you should be perfectly fine. If you wanted to be on the safe side, you could do the following...
                    if((millis() - oldTime) > (600000 +dht.getMinimumSamplingPeriod() )
                    and that would include any delay that the sensor library might need.
                    All the best,
                    cranky
                    • H
                      H
                      Heizelmann
                      wrote on last edited by Heizelmann
                      If cycle interval might become a parameter and for smaller values of this it is better to do it this way
                      if((millis() - oldTime) > max(cycleInterval, dht.getMinimumSamplingPeriod() )
                      • H
                        H
                        Heizelmann
                        ... and to give the DHT sensor a chance on reading errors to retry and not to wait until next cycle which might be very long:
                            for (unsigned int i = 0; i < DHT_MAX_TRIES; i ++) {
                                if (!metric) {
                        Repeat the same for humidity of cause.
