  3. Domoticz
  4. Error Sending switch command
57 Posts 11 Posters 34.7k Views 5 Watching
  • macieiksM macieiks
    Hello guys,
    I had the same problem with st=fail, also with this output: "Error sending command, check your hardware/device (blablabla :D)". I can give you here my hints, maybe they will help you. First of all I am using the latest beta domoticz and beta mysensors library v1.6.
    I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage.
    I have Arduino Mega2560 installed 1 week ago with 16 channel 12v relay board together. I had the the same problem like you "Error sending command, check your hardware/device". Two days ago I realized that maybe there is a problem with my powering my gateway. I have RFXtrx433, APCups and Ethernet Arduino Uno gateway connected to Raspberry Pi USB. I connected my MySensors gateway separately via 5V charge to the wall socket and this error problem is gone. Conclusion was this that my Raspberry couldnt supply enough current for all attached devices. Now I am planning to install PiHut USB hub with external power supply and move all connected USB interfaces to it and then just with one connection cable to my raspberry (maybe RFX will work better :) we will see).
    Update us if these two hints helped you ;D.
    Maciek
    J
    J
    jlaraujo
    @macieiks Could't find what my problem was. I've tried changing the gateway code to the sensor, same issue, change the radios, the same thing.
    I ended up downloading again the Mysensors library, the same issue, i then changed the baud rate for the debug and serial gateway to 19200 and that seemed to solve the issue, i can now issue commands to the nodes, thanks for the help.
    My sensor and gateway are all Pro mini, 8v 8Mhz, i remember now that i've read something in the forum, but can't find it now.
    Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
    • H hugo_pn
      @macieiks said:
      Hello guys,
      I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage."
      This may come into a great help, I have two external antennas that I thought where damaged since arrival, maybe this is the problem. I'm going to try this next week.
      Although, this still makes me thinking of distance, the error appears with the hardware separated by +- 3m with no obstacles .
      N
      N
      NBM
      @hugo_pn Is's possible to see the sketch? Im insecure where to alter the sketch.
      H 1 Reply Last reply
      • N NBM
        H
        H
        hugo_pn
        @NBM
        I'm trying to find it. As soon as I do and if I do I'll tell.
        Chears
          Hello guys,
          Maciek
          H
          H
          hugo_pn
          wrote on last edited by hugo_pn
          #27
          @macieiks said:
          Hello guys,
          Can't find the specific line. The most similar one is in the MyConfig.h line 115
          #define RF24_PA_LEVEL_GW RF24_PA_LOW
          Going with the GitHub file I don't even find it...
          Where exactly did you change the mentioned above?
          Hugo
          P.S. I can't find the V 1.6 library for my sensors. That's why I mentioned github
            1.6 is the default branch when you go to the github project.
            • N
              N
              NBM
              This is what im getting when im trying to turn on the light.
              0;0;3;0;9;send: 0-0-1-1 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
              • sundberg84S
                sundberg84S
                #30
                st=fail means the gw radio doesnt reach the node.
                It can be a power issue (search the forum) which can be fixed with caps and/or other power.
                It can be a range issue and then you need a repeater.
                N 1 Reply Last reply
                • sundberg84S sundberg84
                  N
                  N
                  NBM
                  @sundberg84 The node is 2 meters from the gateway.
                  It most be an power problem. Is it with the gateway or node?
                  • sundberg84S
                    sundberg84S
                    #32
                    Hi!
                    Can be both (or even worse, faulty hardware/bad fake nrf radios).
                    I power my gateway through USBCharger and have a 4.7 + 47 uF cap paralell on VCC/Gnd.
                    On my nodes i use a single 4.7uF cap VCC/GND
                    In best case its just one of your radios thats bad or misswired... check wiring and/or change the radios if you have another one.
                      Hi!
                      N
                      N
                      NBM
                      wrote on last edited by NBM
                      #33
                      @sundberg84 On my gateway (nano) is an 4.7 uF og it is connected with USB to the domoticz. How can I do it different?
                      Im getting this from the node. It reads okay.
                      1;255;3;0;11;RELAY_BUTTON_JUL
                      0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                      1;255;3;0;12;1.0
                      0;0;3;0;9;read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                      1;1;0;0;3;
                      • N
                        N
                        NBM
                        I have made an temp node and it communicating okay.
                        0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:17.8
                        4;1;1;0;0;17.8
                        0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.2
                        4;0;1;0;1;45.2
                        0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.0
                        4;0;1;0;1;45.0
                        0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.3
                        4;0;1;0;1;45.3
                        4;0;1;0;1;45.0
                        Read is not the problem. it is send comands
                        • sundberg84S
                          sundberg84S
                          #35
                          I had this problem due to range but 2m shouldnt be any problem... so strange you can recieve but not send.
                          Some things to consider if someone else doesnt know better than me:
                          • Change radios if possible
                          • Send commands without relays attached (to see if there is some spokes or disturabnce from relay)
                          • Connect MYSController to debug if possible
                          Whats your node ID on that node?
                          Im not good reading those serial lines but if they are beginning with 0 its like its sending to the gateway!?
                          In my case when i send: 103;1;1;1;2;1 where 103 is node ID, Child(Relay) 1, MsgType = 1 (Set), Ack = 1 (yes), 2 = V_LIGHT, 1 = On
                          • N
                            N
                            NBM
                            #36
                            My relay sensor
                            How can i Send commands without relays attached? Where i see log from the gatway?
                            I also tryed change radios. No change.
                            • sundberg84S
                              sundberg84S
                              #37
                              Sorry, Domoticz logs and hardware doesnt provide any info about the radio traffic. MySensors NodeID and Domoticz ID is not the same either.
                              If you disconnect the relay from your Arduino you should still be able to send the switch command and with this the relay disconnected it doesnt make any power spikes that could interfere with the radio.
                              Could you please post your sketch and logs from the gateway again... I cant seem to figure this out.
                              • N
                                N
                                NBM
                                The sketch to the relay
                                 * Version 1.0 - Henrik Ekblad
                                 * Example sketch for a "light switch" where you can control light or something
                                 * else from both HA controller and a local physical button
                                 * (connected between digital pin 3 and GND).
                                 * This node also works as a repeader for other nodes
                                 * http://www.mysensors.org/build/relay
                                #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                                #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                                #define RELAY_ON 0
                                #define RELAY_OFF 1
                                Bounce debouncer = Bounce();
                                int oldValue=0;
                                bool state;
                                  gw.sendSketchInfo("RELAY_BUTTON_JUL", "1.0");
                                 // Setup the button
                                  pinMode(BUTTON_PIN,INPUT);
                                  // Activate internal pull-up
                                  debouncer.attach(BUTTON_PIN);
                                  debouncer.interval(5);
                                  gw.present(CHILD_ID, S_LIGHT);
                                  pinMode(RELAY_PIN, OUTPUT);
                                  state = gw.loadState(CHILD_ID);
                                *  Example on how to asynchronously check for new messages from gw
                                  debouncer.update();
                                  // Get the update value
                                  int value = debouncer.read();
                                  if (value != oldValue && value==0) {
                                      gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                                  oldValue = value;
                                  if (message.isAck()) {
                                     // Change relay state
                                     state = message.getBool();
                                     // Store state in eeprom
                                     gw.saveState(CHILD_ID, state);
                                Log from gateway:
                                1;255;3;0;12;1.0
                                1;1;0;0;3;
                                0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:17.9
                                4;1;1;0;0;17.9
                                0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.4
                                4;0;1;0;1;44.4
                                Without relay:
                                0;0;3;0;9;send: 0-0-1-1 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                                0;0;3;0;9;read: 1-1-0 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                1;1;1;1;2;1
                                But in domoticz it still gives me hardware error.
                                Gateway version 1.5.
                                • N
                                  N
                                  NBM
                                  #39
                                  How do i change the node number?
                                  It select node 2 all the time with new nodes?
                                  In the sketch they are set to AUTO.
                                  Im using standard sketch from the libery.
                                  • sundberg84S
                                    sundberg84S
                                    #40
                                    Change: gw.begin(incomingMessage, AUTO, true);
                                    To: gw.begin(incomingMessage, 3, true); (If you want 3 as node id)
                                    • H
                                      H
                                      hugo_pn
                                      Made a test (with the external antenna on Gateway) the other day and this is what happens.
                                      I put the nrf24 with the external antenna attached to the Nano and Upload the Serial Gateway Scetch onto it.
                                      Ran The Serial Monitor and get this
                                      I remove it from the PC, attach it to the Raspberry Pi I give two switch commands that work, then at the third attempt the message comes to life "Error sending switch command, check device/hardware !"
                                      2016-01-06 01:04:25.708 MySensors: Using serial port: /dev/ttyUSB0
                                      2016-01-06 01:04:27.186 MySensors: Gateway Ready...
                                      2016-01-06 01:04:27.262 MySensors: Gateway Version: 1.5
                                      2016-01-06 01:04:28.329 Hardware Monitor: Fetching data (System sensors)
                                      2016-01-06 01:04:56.024 User: admin initiated a switch command
                                      2016-01-06 01:04:58.436 Hardware Monitor: Fetching data (System sensors)
                                      2016-01-06 01:05:05.599 User: admin initiated a switch command
                                      2016-01-06 01:05:28.560 Hardware Monitor: Fetching data (System sensors)
                                      Back to PC this is what I get.
                                      0;0;3;0;9;radio init fail
                                      After a few minutes It's OK again like the beginning.
                                      • sundberg84S
                                        sundberg84S
                                        #42
                                        It (radio init fail) means that when you power it up (connecting it back to PC) it cant initialise radio.
                                        Mostly this is = check wires and/or power issues.
                                        Actions:
                                        Check wires, check wires and check wires :)
                                        Try powering your nano without the relay attached if possible (and see if you get Radio Init fails)
                                        If not - power your relay seperatly if possible (relay often create interferance with radio).
                                          Actions:
                                          H
                                          H
                                          hugo_pn
                                          @sundberg84
                                          Thanks for the reply, the thing is that I'm powering the Nano via USB from the raspberry Pi (serial Gateway with the external antenna).
                                          The wires I don't think are the problem because it works with the integrated antenna.
                                          Can I power Up the Nano with the Raspbery Pi USB and a 5V Transformer with out burning everything?
                                          From what I remember, parallel tension doesn't sum up, but the current does. Wright?
                                          Will I damage everything, including the Raspberry?
