  3. Uploading SerialGateway WARNING
18 Posts 2 Posters 5.7k Views
  • sundberg84S
    sundberg84S
    Hi, then i missunderstood you.
    Have you tried to upload the sketch?
    • W
      W
      Wijbe.Fryslan
      Yep, with the same warning and zero results in Domoticz.
      • sundberg84S
        sundberg84S
        No "Upload finish" and nothing on the serial log - then the answer is: No you cant and I would think if you go back to my first post that your library didnt install correctly.
        • W
          W
          Wijbe.Fryslan
          Again, installing AerduinoIDE, then de latest realese of MySensors: same problem...
          • sundberg84S
            sundberg84S
            Sorry to hear - but the Warning really sounds like the Library UIPEthernet is something wrong with. Did you have this library before or installed on another directiory as well? It has not been updated for a year in MySensors Masterbranch.
            When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed.
            W 2 Replies Last reply
            • W
              W
              Wijbe.Fryslan
              So mabey the download from MySensors isn't ok (UIPEthernet is a part of that).
              Again downloaded and added but the same warning.
              • sundberg84S
                sundberg84S
                @hek Has there been any change in 1.5 download lately? I cant remeber any other users having this problem.
                • W
                  W
                  Wijbe.Fryslan
                  Now installing ArduinoIDE 1.6.5 (aug '15) and MySensors 1.5 (jan '15) there's no warning...
                  W 1 Reply Last reply
                  • W Wijbe.Fryslan
                    W
                    W
                    Wijbe.Fryslan
                    @Wijbe.Fryslan LOL, jan '15 has to be jan '15 (older version deleted...)
                    • sundberg84S
                      sundberg84S
                      Nice to hear @Wijbe-Fryslan! :)
                      • W
                        W
                        Wijbe.Fryslan
                        You think this is THE solution????
                        • sundberg84S
                          sundberg84S
                          Dont know, as long as it works for you...
                          • sundberg84S sundberg84
                            W
                            W
                            Wijbe.Fryslan
                            @sundberg84 The sketch UIPEthernet becomes to al my downloads from MySensors.
                              W
                              W
                              Wijbe.Fryslan
                              @sundberg84 said:
                              ... When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed....
                              I think so. How manny are there, so I can check. ;)
                              • W
                                W
                                Wijbe.Fryslan
                                Playing with my Arduino IDE and mysensors download on my computer with Windows 7, I can make the following conclusion:
                                Arduino-1.6.5-r2-windows works fine;
                                Arduino-1.6.7-windows gives described UIPEthernet warning.
