  3. Uploading SerialGateway WARNING
18 Posts 2 Posters 5.5k Views
  • W Offline
    W Offline
    Wijbe.Fryslan
    Hello, I'm trying to make a new SerialGateway, from scratch and the same on this webside. So far so good... But I think he's not working... (In Domoticz I see no versionnumber nor a sensor.)
    So I started checking the hardware, that's (lets hope) ok.
    Next step is checking the software, installing the newest version of ArduinoIDE (on Windows) and the latest release of MySensors, so far so good.
    When I try to check the SerialGateway-sketch there's the next warning:
    WARNING: Category '' in library UIPEthernet is not valid. setting to 'Uncategorized'
    Can I Upload the sketch?
    • S Offline
      Hi! Welcome!
      Here is a great tutorial from MySensors how to install the Arduino IDE and MySensors liberary! Start there and work your way forward. Maybe your library didnt install correctly?
      http://www.mysensors.org/about/arduino#installing-the-development-environment-on-your-computer
      • W Offline
        W Offline
        Wijbe.Fryslan
        @sunberg84 Thanks for your advice. All those steps already done some time ago...
        Think this is not a relevant answer by my question. ;)
        • S Offline
          Hi, then i missunderstood you.
          Have you tried to upload the sketch?
          • W Offline
            W Offline
            Wijbe.Fryslan
            Yep, with the same warning and zero results in Domoticz.
            • S Offline
              No "Upload finish" and nothing on the serial log - then the answer is: No you cant and I would think if you go back to my first post that your library didnt install correctly.
              • W Offline
                W Offline
                Wijbe.Fryslan
                Again, installing AerduinoIDE, then de latest realese of MySensors: same problem...
                • S Offline
                  Sorry to hear - but the Warning really sounds like the Library UIPEthernet is something wrong with. Did you have this library before or installed on another directiory as well? It has not been updated for a year in MySensors Masterbranch.
                  When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed.
                  W 2 Replies Last reply
                  • W Offline
                    W Offline
                    Wijbe.Fryslan
                    So mabey the download from MySensors isn't ok (UIPEthernet is a part of that).
                    Again downloaded and added but the same warning.
                    • S Offline
                      @hek Has there been any change in 1.5 download lately? I cant remeber any other users having this problem.
                      • W Offline
                        W Offline
                        Wijbe.Fryslan
                        Now installing ArduinoIDE 1.6.5 (aug '15) and MySensors 1.5 (jan '15) there's no warning...
                        W 1 Reply Last reply
                        • W Wijbe.Fryslan
                          W Offline
                          W Offline
                          Wijbe.Fryslan
                          @Wijbe.Fryslan LOL, jan '15 has to be jan '15 (older version deleted...)
                          • S Offline
                            Nice to hear @Wijbe-Fryslan! :)
                            • W Offline
                              W Offline
                              Wijbe.Fryslan
                              You think this is THE solution????
                              • S Offline
                                Dont know, as long as it works for you...
                                • S sundberg84
                                  W Offline
                                  W Offline
                                  Wijbe.Fryslan
                                  @sundberg84 The sketch UIPEthernet becomes to al my downloads from MySensors.
                                  • S sundberg84
                                    W Offline
                                    W Offline
                                    Wijbe.Fryslan
                                    @sundberg84 said:
                                    ... When you open your arduino IDE do you see all the MySensors examples there (In example -> MySensors)? The your lib is installed....
                                    I think so. How manny are there, so I can check. ;)
                                    • W Offline
                                      W Offline
                                      Wijbe.Fryslan
                                      Playing with my Arduino IDE and mysensors download on my computer with Windows 7, I can make the following conclusion:
                                      Arduino-1.6.5-r2-windows works fine;
                                      Arduino-1.6.7-windows gives described UIPEthernet warning.
                                      12.2k
