  3. Guide: Setting up and testing MQTT Client Gateway
78 Posts 18 Posters 64.6k Views 18 Watching
  • dakkyD dakky
    @dakky said:
    The gateway tries to open a lot of connections and all of them seem to die after a short while
    Any idea?
    Narghs!
    Seems to be a hardware problem. I changed the w5100 module with an w5100 arduino shield and now it works fine:
    0;0;3;0;9;Starting gateway (RNNGA-, 1.6.0-beta)
    0;0;3;0;9;Radio init successful.
    IP: 192.168.100.10
    0;0;3;0;9;MQTT connected
    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
    I'm still interested in the reason. Hardware broken or wiring fail?
    • pinging the arduino worked
    • i can see the connections on the broker
    => basic networking seems to work, but "delivering content" failed. Any guesses?
    Strange fact: with the "broken" hardware:
    IP: 0.40.68.10
    with the shield:
    IP: 192.168.100.10
    Same sketch, 192.168.100.10 is the correct Ip (obviously) ;)
    Greeting
    Dakky
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @dakky I guess I had that problem once or twice before but I don't pay attention to it as there was other bugs which were more important.
    I remember that I just reset the nano and it worked at once. Glad that it worked for you but as you have said, knowing the root cause it important.
    Will try to reproduce it again when I have time.
    • dakkyD
      dakkyD
      dakky
      wrote on last edited by dakky
      #35
      Another question:
      I don't have any experience with the classic setup (broker on gateway). But does
      The topic resembles the serial protocol. You must define you preferred subscribe and publish prefix in the sketch. The topic is build like this:
      MY_MQTT_PUBLISH_TOPIC_PREFIX/FROM-NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
      mean, that the consuming controllers configuration (openhab in my case) has to be changed?
      From
      sensor-gw1-out/99/3/V_TRIPPED
      To
      sensor-gw1-out/99/3/1/0/16
      in order to represent what is really pushed to the mqtt broker? Because thats what is posted to the broker?
      Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
      Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
      Software: MySensors 2.0development
        moskovskiy82
        A little bit cofused. Can this sketch be uploaded to ESP12 set as in the "ESP8266 WiFi Gateway"? Without the arduino?
        After uploading it to esp all i get
        tail 0
        chksum 0x42
        csum 0x42
        ~ld
          moskovskiy82
          Can more detailed instructions be given on the development branch? As i understand this is not a simple copy the code from here https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino paste into arduino IDE compile and upload process?
            @moskovskiy82
            Yes, after the MySensors library has been installed you should be able to compile/upload the sketch and run it.
              moskovskiy82
              Well i had to move all the libs from production branch and extract clean only the development branch in arduino IDE to get it to work.
              Afterwards had to do the same thing back to production to compile the humidity sensor as it gave me the following error during compilation
              Arduino: 1.6.5 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
              In file included from Mysensors_DHT_Wireless.ino:31:0:
              \My Documents\Arduino\libraries\MySensors/MySensor.h:201:3: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
              Mysensors_DHT_Wireless:39: error: 'MySensor' does not name a type
              Mysensors_DHT_Wireless.ino: In function 'void setup()':
              Mysensors_DHT_Wireless:50: error: 'gw' was not declared in this scope
              Mysensors_DHT_Wireless.ino: In function 'void loop()':
              Mysensors_DHT_Wireless:75: error: 'gw' was not declared in this scope
              Mysensors_DHT_Wireless:85: error: 'gw' was not declared in this scope
              Mysensors_DHT_Wireless:90: error: 'gw' was not declared in this scope
                moskovskiy82
                Is there some miscompatability betweed development/production branches?
                My humidity sensor reports in the serial console just fine.
                req id
                req id
                T: 24.60
                req id
                H: 87.00
                On the gateway i see the following
                0;255;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
                But in mosquitto...
                mygateway1-out/255/255/3/0/3 (null)
                  moskovskiy82
                  Please ignore the last post. Solved by finding out that Openhab doesn't handle Node ID assigning.
                  • T
                    tante ju
                    Just tried to set up an ESP-12E as MQTT gateway and noticed one bug in the actual development branch:
                    As soon as one of the three LED PIN assignments is not defined (commented out), the Example sketch will lock itself after initializing NRF radio, and running DHCP. So, no further NRF communication nor signup at the broker. WDT steps in then.
                    Just defining all three LEDs, without any other parameter or use the LED blinking feature, and everything is fine.
                      @tante-ju
                      http://forum.mysensors.org/topic/2749/1-6-gateway-possible-error/8
                      • greglG
                        greglG
                        gregl
                        Im lost...
                        Ive just setup a new MQTT client gateway ( from link at the top of this post..) and have a few nodes successfully sending data to a mosquito server.
                        What im trying to now do is, using the RelayActuator sketch, is control the relay via a MQTT message...but im confused as to what i need to send it!
                        Here is the serial output from the RelayActuator sketch:
                        Starting repeater (RNNRA-, 2.0.0-beta)
                        send: 9-9-0-0 s=255,c=3,t=15,pt=1,l=1,sg=0,st=ok:0
                        send: 9-9-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                        send: 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                        send: 9-9-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
                        send: 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                        send: 9-9-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                        Init complete, id=9, parent=0, distance=1
                        So what message do i send it from another MQTT client ?
                        ive been trying things such as mygateway1-in/9/0/1/1 with message of 0 or 1
                        Pls help ! ;-)
                          What happens if you send to child sensor 1 (ack disabled)
                          mygateway1-in/9/1/0/1
                          • greglG
                            greglG
                            gregl
                            Hi @hek
                            Nothing...
                            there is no message received from the node. ( based off the serial output)
                            How can i serial.print out all the messages it receives?
                            • greglG
                              greglG
                              gregl
                              @hek
                              mmm..perhaps there is a problem between mosquito and the mqttclient gateway. As ive now attached a serial monitor to the mqttclient gateway and sending the message doesnt appear in the console. I assume it should...
                              Opening port
                              Port open
                              0;255;3;0;9;read: 9-9-0 s=255,c=3,t=15,pt=1,l=1,sg=0:0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/255/3/0/15
                              0;255;3;0;9;read: 9-9-0 s=255,c=0,t=18,pt=0,l=10,sg=0:2.0.0-beta
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/255/0/0/18
                              0;255;3;0;9;read: 9-9-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/255/3/0/6
                              0;255;3;0;9;read: 9-9-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/255/3/0/11
                              0;255;3;0;9;read: 9-9-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/255/3/0/12
                              0;255;3;0;9;read: 9-9-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                              0;255;3;0;9;Sending message on topic: mygateway1-out/9/1/0/0/3
                              0;255;3;0;9;read: 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:26.8
                              0;255;3;0;9;Sending message on topic: mygateway1-out/1/0/1/0/0
                              0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.7
                              0;255;3;0;9;Sending message on topic: mygateway1-out/1/1/1/0/0
                              as you can see no incoming messages from mosqutto.
                              • greglG
                                greglG
                                gregl
                                I can see in mosquitto logs a subscription from the gateway
                                1452645694: mosquitto version 1.3.4 terminating
                                1452645694: Sending CONNACK to mysensors-1 (0)
                                1452645694: Received SUBSCRIBE from mysensors-1
                                1452645694: 	mygateway1-in/+/+/+/+/+ (QoS 0)
                                1452645694: Sending SUBACK to mysensors-1
                                So looks like i need to add an extra level to the message i send!
                                So i just tried sending a message to topic:
                                mygateway1-in/9/1/0/1/1
                                and now i can see in my serial outputs of both the mqttclient gateway and the relaysketch node the message received!
                                ( but its not swithing my relay yet! )
                                @hek is this the correct MQTT formatting:
                                • greglG
                                  greglG
                                  gregl
                                  Ok got it... ( sorry for making mess of this discussion!)
                                  If i publish to
                                  mygateway1-in/9/1/1/0/2 and send message values of 0 or 1 it works.... ;-)
                                  Hope this helps someone else!
                                  Greg ;-)
                                  • T
                                    tante ju
                                    @hek
                                    That thread does not directly touch on the issue I noticed, although that might be connected.
                                    Some other questions:
                                    Why is the topic structure as it is? I like my MQTT topics in hierarchical order. So, having different prefixes for send and receive (in and out) is not nice, but ok. BUt why is the ACK flag before the data type, which is usually linked to a value or variable in the sensor? I would consider ACK to be a sub-value of that one.
                                    And is there a way to have more speaky names instead of numbers? So, the source does not have that option and as that gateway is now included in the library I only see the possibility of changing the source in the library, which will disconnect from updates. Not nice. What about an option of excluding gatewayTransportSend and incomingMQTT via define from the library and define then in the own sketch?
                                      moskovskiy82
                                      What is the correct way to run DHCP? Tried commenting out
                                      #define MY_IP_ADDRESS
                                      but that didn't help.
                                      Also is it possible to use fqdn for the mqtt broker instead of the ip?
                                      greglG 1 Reply Last reply
                                      • M moskovskiy82
                                        greglG
                                        greglG
                                        gregl
                                        @moskovskiy82
                                        I also tried to use DHCP and fqdn for mosqitto, but no luck....so I cant help but I too would like to know if its possible.
                                          @gregl
                                          A PR was merged 5 days ago where you can specify
                                          MY_CONTROLLER_URL_ADDRESS
                                          https://github.com/mysensors/Arduino/pull/375
                                          I haven't verified it myself yet though.
