  3. SceneController
SceneController
28 Posts 9 Posters 19.8k Views 5 Watching
  • D Dalhoj
    Hi
    After the Node and Scenecontroller shows up in the Vera UI you have to create a scene and then asign the scenecontroller as a trigger:
    For button 1 the scene number is 0
    for button 2 the scene number is 1 and so on.
    Hope is helps ;-)
    dayve218
    @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
    korttomaK hekH 2 Replies Last reply
    • D dayve218
      korttomaK
      korttomaK
      korttoma
      @dayve218
      If you use PLEG you could do it like this:
      Condition ----------------- Action
      LightOn AND Button = Turn Light Off
      LightOff AND Button = Turn Light On
      • Tomas
      • D dayve218
        @dayve218
        Some "scene controllers" I've seen triggers "scene off" when you push-and-hold button for say one a second.
        • D
          dayve218
          wrote on last edited by dayve218
          #22
          how would i make that happen?
          @korttoma i dont, PLEG is infinitely confusing to me.
          • D
            Dalhoj
            I dont know if you can have a 1 sec press!
            but i uses LUUP and a simple ex could be turn on a lamp and if the lamp if on turn it off:
            local relay1 = 114 --Light ID
            local relay1_status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", relay1) --Status of Light
            if (relay1_status == "0") then
            luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" }, relay1)
            luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="0" }, relay1)
            end
            Or you can use a toggle from the advanced scene menu:
            upload-cb06931d-0aaa-4ee3-b90f-345180b5247c
            That is how I do it.
            hekH 1 Reply Last reply
            • D Dalhoj
              end
              I mean that the Arduino checks if user presses button for one sec and send the SCENE_OFF. You probably shouldn't let Vera handle this.
              D 1 Reply Last reply
              • NuubiN
                NuubiN
                Nuubi
                Hey! Any pictures of scene controller installations? I'm planning on DIY'ing some "aesthetically pleasing" ones :-)
                  Dalhoj
                  I would make the Arduino send ie. for button 1 send scene ID 0 at short press and scene ID 1 for long press and so on.
                  @Nuubi Here is two of my scene controllers:
                  The first one is installed in my bedtable upload-c29b281d-083c-4b73-a4df-b27240ee9e31 and is a combination of a scenecontroller and a relaysensor for controling the 3 leds.
                  The 2. is installed in the living room, and is a 8 button scenecontroller.
                  upload-aee5fc51-3dea-4a00-b592-db58744e1e87
                  It controlles
                  • the lights in the living room
                  • Blinds Open / Close
                  • a power outlet On/Off
                  • pause/plays my XBMC Medie Center
                  • starts my Yamaha reciver and starts playing net radio
                  • stops the radion again and turn of the reciver
                  • turns up / down the volume on the reciver
                  That is what I use it for at the moment.
                  S 1 Reply Last reply
                  • D Dalhoj
                    It controlles
                    Smelliot
                    @Dalhoj what enclosures are they? They look really slick!
                    • D
                      Dalhoj
                      Its a danish enclosure: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-2-modul-346dd488/ for the button one and: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-1-modul-hvid/ for the top one.
                      Its a danish department of Schneider Electric called LK(Lauritz Knudsen)
