  3. SceneController
SceneController
28 Posts 9 Posters 19.9k Views 5 Watching
  • D
    dayve218
    @Dalhoj thanks for that, it seems super obvious now in retrospect.
    • D Dalhoj
      Hi
      After the Node and Scenecontroller shows up in the Vera UI you have to create a scene and then asign the scenecontroller as a trigger:
      For button 1 the scene number is 0
      for button 2 the scene number is 1 and so on.
      Hope is helps ;-)
      dayve218
      @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
      korttomaK hekH 2 Replies Last reply
      • D dayve218
        korttomaK
        korttomaK
        korttoma
        @dayve218
        If you use PLEG you could do it like this:
        Condition ----------------- Action
        LightOn AND Button = Turn Light Off
        LightOff AND Button = Turn Light On
        • Tomas
        • D dayve218
          @dayve218
          Some "scene controllers" I've seen triggers "scene off" when you push-and-hold button for say one a second.
          • D
            dayve218
            wrote on last edited by dayve218
            #22
            how would i make that happen?
            @korttoma i dont, PLEG is infinitely confusing to me.
            • D
              Dalhoj
              I dont know if you can have a 1 sec press!
              but i uses LUUP and a simple ex could be turn on a lamp and if the lamp if on turn it off:
              local relay1 = 114 --Light ID
              local relay1_status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", relay1) --Status of Light
              if (relay1_status == "0") then
              luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" }, relay1)
              luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="0" }, relay1)
              end
              Or you can use a toggle from the advanced scene menu:
              upload-cb06931d-0aaa-4ee3-b90f-345180b5247c
              That is how I do it.
              hekH 1 Reply Last reply
              • D Dalhoj
                end
                I mean that the Arduino checks if user presses button for one sec and send the SCENE_OFF. You probably shouldn't let Vera handle this.
                D 1 Reply Last reply
                • NuubiN
                  NuubiN
                  Nuubi
                  Hey! Any pictures of scene controller installations? I'm planning on DIY'ing some "aesthetically pleasing" ones :-)
                    Dalhoj
                    I would make the Arduino send ie. for button 1 send scene ID 0 at short press and scene ID 1 for long press and so on.
                    @Nuubi Here is two of my scene controllers:
                    The first one is installed in my bedtable upload-c29b281d-083c-4b73-a4df-b27240ee9e31 and is a combination of a scenecontroller and a relaysensor for controling the 3 leds.
                    The 2. is installed in the living room, and is a 8 button scenecontroller.
                    upload-aee5fc51-3dea-4a00-b592-db58744e1e87
                    It controlles
                    • the lights in the living room
                    • Blinds Open / Close
                    • a power outlet On/Off
                    • pause/plays my XBMC Medie Center
                    • starts my Yamaha reciver and starts playing net radio
                    • stops the radion again and turn of the reciver
                    • turns up / down the volume on the reciver
                    That is what I use it for at the moment.
                    S 1 Reply Last reply
                    • D Dalhoj
                      It controlles
                      Smelliot
                      @Dalhoj what enclosures are they? They look really slick!
                      • D
                        Dalhoj
                        Its a danish enclosure: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-2-modul-346dd488/ for the button one and: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-1-modul-hvid/ for the top one.
                        Its a danish department of Schneider Electric called LK(Lauritz Knudsen)
