  3. Need some help to start....
21 Posts 4 Posters 6.9k Views 1 Watching
    mark76
    I have now tried to re-install lib 3x.... I am stumbeling a little bit, cause I have allready a libraries folder and have copied all folders from MySensors- library folder to that folder... cause my understanding is that all libraries should be in the same folder....
    • sundberg84S
      sundberg84S
      That sounds right. When you open arduino ide do you find MySensors under the example menu?
      • E
        E
        ericvdb
        Your libraries folder should look like this:
        upload-ebc1aaee-0c0f-4184-ad7d-3a54681bf9a7
        Then you should see in the arduino gui:
        upload-c7796245-4038-4239-ad0f-54f367de54ab
          mark76
          yes.... every thing seams to be correct...
          • sundberg84S
            sundberg84S
            Hi!
            Any luck @mark76 ? Only difference from me is that you run 1.6.7 arduino IDE... but that shouldnt make the errors... Can you post a code/screeshot of all the error? (Complete log).
              mark76
              No chance.... error is only that one I have postet... Could be that the IDE causes the problem?
              • sundberg84S
                sundberg84S
                If nothing else works you could try download another version and try... but i doubt it.
                • E
                  E
                  ericvdb
                  As you can see in my screenshots, i'm also running 1.6.7 and i have no issues at all.
                    mark76
                    One question regarding that issue.... Do I have to tell the Sketch that I am working with nrf24? That library is very big and it is not easy to get an overview what library is doing in the backround.... But from my point of view I should define the Radio I use... (?)
                      mark76
                      I have now decided to stay at TmrH20 - Basis... that is working fine for me...
                      Thanks to all, trying to help.
