  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • P
    P
    p0lar
    I thinking I am build a DEBUG version of the GW code. but I dont think the logging is working in the app with my eth GW. am I mising something?
    So. when I build a DEBUG version of the GW code I get this in the serial console hex size=29k so its bigger.
    0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:71.6
    1;1;1;0;0;71.6
    0;0;3;0;9;read: 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
    2;1;1;0;16;0
    the NON DEBUG I get this. hex size = 26k
    1;1;1;0;0;69.8
    1;0;1;0;1;35.0
    1;1;1;0;0;71.6
    1;0;1;0;1;36.0
    1;1;1;0;0;73.4
    1;0;1;0;1;37.0
    2;1;1;0;16;0
    tekkaT 1 Reply Last reply
    • P p0lar
      1;1;1;0;0;71.6
      2;1;1;0;16;0
      1;1;1;0;0;69.8
      1;0;1;0;1;35.0
      1;1;1;0;0;71.6
      1;0;1;0;1;36.0
      1;1;1;0;0;73.4
      1;0;1;0;1;37.0
      2;1;1;0;16;0
      tekkaT
      tekkaT
      tekka
      1;1;1;0;0;71.6
      2;1;1;0;16;0
      that looks good :)
      • P
        P
        p0lar
        wrote on last edited by p0lar
        #349
        Still nothing in the MySensors Debug tab... and only the NON debug info in the log files. maybe this is a ethernet GW issue? So I get debug info in the Arduino Serial monitor but no debug via TCP?
        [GENERAL]
        VERSION=0.1.2.282
        [COMMUNICATION]
        COM=COM1
        SPEED=4
        IP=10.1.1.200
        PORT=5003
        TCPACTIVE=1
        [STATUS]
        LOGGING=1
        DEBUGGING=1
        SENDMSG=1
        LOGPARSE=1
        AUTOFW=0
        AUTOID=1
        UTCTIME=0
        CLOSECONFIRM=0
        FILTERLOG=1
        SAVENODES=1
        METRICSYSTEM=0
          stebra
          @tekka : I tested the ID reassign by hardcoding the functionality in the serial gw sketch. Reboot node 6, wait for FW_CONFIG_REQUEST, answer with FW_CONFIG_RESPONSE.
          Works as expected & described in the MYSBootloader code. Please give me some hint why MYSController does not send the FW_CONFIG_RESPONSE packet with the bootloader commands after the reboot.
          I trigger the reassign via the node´s context menu in the gui, MYSBootloader Commands --> reassign ID. Anything wrong with that ?
          Maybe someone else has an idea what is happening/not happening ? @tekka could you find something in the log file?
          Thanks a lot...
            stebra
            Has anyone tested successfully reassigning the node-id with MYSBootloader 1.1 and MYSController 1.2.282 ? Would give me some new motivation to hear it's possible and has been done before. At the very moment I m at a dead end.
            If it is not working for you, I would also appreciate your feedback.
            • greglG
              greglG
              gregl
              @tekka
              Is the (dev branch) MQTTClientGateway supported by MYSController?
              I'm in the process of moving from Vera and Ethernet GW, to Openhab with MQTTClient gateway and would love to have the OTA functionality your bootloader and controller provides. I looked at this a while back, but ran out of time to play!
              So yeah.. Can MYSController talk with the MQTTClientGateway ( over Ethernet) ?
              Cheers,
              Greg
              • greglG
                greglG
                gregl
                In answer to my own question... No..it doesnt seem to.. ;-(
                I tried with the IP address of my MQTT client gateway board, and port 5003 ( same port that works for my 1.4 Ethernet GW )
                It says it connects, but no data flows in....
                @tekka @hek - Is it unlikely that the MQTTClient Gateway will be usable with MYSController??
                If not, would this work?
                Have two networks -
                1 for MYSController to perform OTA's using a serial gateway on the PC we typically do sketch changes on.
                2 for normal MySensors operation. When you want to invoke an update, you could send a I_REBOOT command ( MQTT message in my case), which would reboot the node and if i understand correctly, look for an update on the other network channel.
                I guess you would loose all the other functionility of MYSController, but at least we could do OTA.
                Cheers,
                Greg
                • S stebra
                  tekkaT
                  tekkaT
                  tekka
                  @stebra The log looks normal - is the node directly communicating with the gw or via a repeater? Does the clearEEPROM option work?
                  • greglG gregl
                    Have two networks -
                    Cheers,
                    Greg
                    tekkaT
                    tekkaT
                    tekka
                    @gregl MYSController is currently not supporting MQTT, I'll add it to my feature request w/o ETA.
                    crankyC 1 Reply Last reply
                      stebra
                      @tekka
                      No repeater, clear eeprom via MYSController gui does not work. Clear eeprom via sketch works, node gets new id after reboot.
                      My assumption is that MYSController does not respond to the FW_CONFIG_REQU after reboot.
                      • tekkaT tekka
                        crankyC
                        crankyC
                        cranky
                        @tekka You might not have to. I've been working on Node-Red as a controller and more.
                        With my kit, you need Node-Red, node-red-contrib-mysensors , Mosquitto, and some of my flows which I have available ( http://forum.mysensors.org/topic/2802/flow-to-turn-serialgateway-into-mqtt-serialgateway ).
                        And it makes this:
                        http://forum.mysensors.org/topic/2815/flow-to-turn-serialgateway-with-mqtt-flow-to-ethernetgateway
                        The only flaw is that when you first connect MYSController, you need to send a junk topic so that MYSController can receive data. It's a bug/peculiarity with Node-Red, but honestly not a big deal. I'm also working on how to fix even that.
                          stebra
                          @tekka
                          Can you verify it works for you? Do you see any response packets with the bl commands in your log?
                          • sundberg84S
                            sundberg84S
                            #359
                            First time i try OTA. Everything went well until fw update (Pro mini). It sends/recieve like 20-30 packages, and then ends. I need to reconnect Myscontroller and it will start to flow again. I can see there is requests from node on gw led, but nothing comes through in Myscontroller (.282). Using 2.0b ethernet gw. Its just like either GW stops sending to Myscontroller or Myscontroller doesnt accept it. Also getting in domoticz that "MySensors: Connection reset!" Do i need to disconnect Domoticz while I do updates?
                            Any clues?
                            Edit: Sorry, jepp - needs to disconnect Domoticz and it works... I bet its those new gateway pings from Domoticz killing it.
                            • sundberg84S
                              sundberg84S
                              #360
                              A quick one: How long does the OTA takes for Blink sketch?
                              I press update FW, it start rolling and the node changes status from "fw updating" to "booting" but then goes back to fw updating... have been going like this for a long time now (1000 packages sent/recieved).
                              Also - is it possible to upload via fdti with MYSBootloader or you need to use OTA?
                              Edit: somethings is not right, its rebooting or starting over again:
                              2016-01-16 21:09:41	RX	14;255;4;0;2;0A0001002F00
                              2016-01-16 21:09:43	TX	14;255;4;0;3;0A0001002F008083E1EBF0E0808184608083E0EBF0E0
                              2016-01-16 21:09:43	RX	14;255;4;0;2;0A0001002F00
                              2016-01-16 21:09:45	DEBUG	Undefined firmware/type for node=14
                              2016-01-16 21:09:45	INFO	BL version=257
                              2016-01-16 21:09:45	INFO	Send FW info to node 14: type=A, version=1, blocks=0x0048, CRC=0xD098
                              2016-01-16 21:09:45	TX	14;0;4;0;1;0A000100480098D0
                              2016-01-16 21:09:45	RX	14;255;4;0;0;FFFFFFFFFFFFFFFF0101
                              2016-01-16 21:09:46	DEBUG	FW update started, node id = 14
                              2016-01-16 21:09:46	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
                              2016-01-16 21:09:46	RX	14;255;4;0;2;0A0001004700
                              2016-01-16 21:09:47	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
                              2016-01-16 21:09:47	RX	14;255;4;0;2;0A0001004700
                              2016-01-16 21:09:48	TX	14;255;4;0;3;0A00010046002C020E947000C0E0D0E00E948B002097
                                stebra
                                @tekka
                                Fortunately a helpful guy gave me your bootloader 1.3 beta, which fixes the problem with nonworking bootloader commands. It seems I was not the first one asking you...
                                For all others trying the bootloader commands in bootloader 1.1 : this does not work at all, and you are only wasting your time.
                                I would really appreciate if the code for bl 1.3 was on github also. I do not mind if its beta only...
                                Below the working debug output for a reassign nodeid 8 --> nodeid 88
                                16.01.2016 23:06:46	RX	8;255;3;0;9;0108A000B9F7FFFEDA7221F0001E950F09
                                16.01.2016 23:06:48	RX	0;0;3;0;9;read: 8-8-0 s=255,c=4,t=0,pt=6,l=10,sg=0:1E00010048047AA801
                                16.01.2016 23:06:48	INFO	BL version=259
                                16.01.2016 23:06:48	INFO	Executing bootloader command section
                                16.01.2016 23:06:48	TX	8;255;4;0;1;0200580000007ADA
                                16.01.2016 23:06:48	RX	8;255;4;0;0;1E00010048047AA80103
                                16.01.2016 23:06:48	RX	0;0;3;0;9;send: 0-0-8-8 s=255,c=4,t=1,pt=6,l=8,sg=0,st=ok:02005800000
                                16.01.2016 23:06:48	RX	0;0;3;0;9;read: 88-88-255 s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                • S stebra
                                  @tekka
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @stebra The 1.3 is a closed beta and is not supposed to be distributed (ping @niccodemi). It is not supported in any terms nor should it be used in a productive environment, the compatibility to any library version is not guaranteed.
                                  Currently, there is ongoing work for MYSBootloader 2.0 and the ETA is tbd, same for the code.
                                  • sundberg84S sundberg84
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @sundberg84 Please upload MYSController log with DEBUG enabled.
                                    • AndurilA
                                      AndurilA
                                      Anduril
                                      Hello @tekka,
                                      is the feature 'save nodes' supposed to be working or WIP? With every start of MYSController I get a blank page and have to wait for every sensor to appear. At the moment that's not a big problem for me because of only 3 sensors, but already got a doubled ID once because new sensor requested an ID before the old #1 was recognized.
                                      Thanks a lot for your work with the controller, it's great.
                                      • tekkaT tekka
                                        Hi all,
                                        I've been working on this project since some time, basically it's a GUI for controlling/updating/debugging a network of MySensors nodes. OTA functionality is supported via MYSBootloader - read posts for further instructions/troubleshooting or PM.
                                        link updated: MYSController Version 1.0.0.3316 released
                                        New features:
                                        • support OTA FW update Sensebender board
                                        • metric/imperial system I_CONFIG
                                        • save nodes
                                        Update via update button in MYSController or download here.
                                        N
                                        N
                                        NotTooTechy
                                        @tekka
                                        Hi, just found this so downloaded and installed. Went to config to see what was there and selected TCP/IP tab to turn it off as it is not on a network and I only need Serial. The thing locks up and crashes and I have to use Task Manager to end it.
                                        Is there some way to start it without it trying to access 192.168.0.5?
                                        • N NotTooTechy
                                          @tekka
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @NotTooTechy try setting
                                          TCPACTIVE=0
                                          in MYSController.ini
