  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • D dakipro
    I think I have flashed MYSBootloader finaly, after ~6hours of trying and reading (persistent guy :) )
    The instructions are for the older version I guess, right board should be copied from MYSController/bootloader/boards.txt, not from this topic post#75. Now I am trying to figure how to flash the sketch, but I guess that is explained somewhere on the topic
    tekkaT
    tekkaT
    tekka
    @dakipro I use the settings mentioned in #75 in Atmel studio, however, AVRDUDE does not support the upper two bits of the lock fuse (therefore the error message 0xFF!=0x3F). Changing the lock bits to 0x3F should do the job.
    And yes, as @p0lar pointed out, only the nodes and not the gateway should have MYSBootloader.
    • P
      P
      p0lar
      HMM i cant build a DEBUG version of the ethernet gateway... even when I try to define it and print hello world it wont... weird.. any ideas?
      • D
        dakipro
        Aha, I get it now. Then I just flash MYSBootloader on the sensor, and attach the radio and it will automatically connect to the gateway (it has some sort of sketch/communication with MySensors built in)? And then I use the MYSController to upload my sketch as described?
        Or how do I upload a initial sketch if I cannot use arduino anymore?
        Btw, I love MYSController, i use it all the time in development as it shows all that is going on with the sensors, thank you very much for developing it!
        • P
          P
          p0lar
          wrote on last edited by p0lar
          #345
          correct. you build the .hex file in arduino studio or whatever and copy it to the MY gui firmware folder and edit the csv file and then reload.
          http://forum.mysensors.org/topic/1066/bootloader/8
          This should help
          • P
            P
            p0lar
            #346
            • P
              P
              p0lar
              I thinking I am build a DEBUG version of the GW code. but I dont think the logging is working in the app with my eth GW. am I mising something?
              So. when I build a DEBUG version of the GW code I get this in the serial console hex size=29k so its bigger.
              0;0;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:71.6
              1;1;1;0;0;71.6
              0;0;3;0;9;read: 2-2-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
              2;1;1;0;16;0
              the NON DEBUG I get this. hex size = 26k
              1;1;1;0;0;69.8
              1;0;1;0;1;35.0
              1;1;1;0;0;71.6
              1;0;1;0;1;36.0
              1;1;1;0;0;73.4
              1;0;1;0;1;37.0
              2;1;1;0;16;0
              tekkaT 1 Reply Last reply
              • P p0lar
                1;1;1;0;0;71.6
                2;1;1;0;16;0
                1;1;1;0;0;69.8
                1;0;1;0;1;35.0
                1;1;1;0;0;71.6
                1;0;1;0;1;36.0
                1;1;1;0;0;73.4
                1;0;1;0;1;37.0
                2;1;1;0;16;0
                tekkaT
                tekkaT
                tekka
                1;1;1;0;0;71.6
                2;1;1;0;16;0
                that looks good :)
                • P
                  P
                  p0lar
                  #349
                  Still nothing in the MySensors Debug tab... and only the NON debug info in the log files. maybe this is a ethernet GW issue? So I get debug info in the Arduino Serial monitor but no debug via TCP?
                  [GENERAL]
                  VERSION=0.1.2.282
                  [COMMUNICATION]
                  COM=COM1
                  SPEED=4
                  IP=10.1.1.200
                  PORT=5003
                  TCPACTIVE=1
                  [STATUS]
                  LOGGING=1
                  DEBUGGING=1
                  SENDMSG=1
                  LOGPARSE=1
                  AUTOFW=0
                  AUTOID=1
                  UTCTIME=0
                  CLOSECONFIRM=0
                  FILTERLOG=1
                  SAVENODES=1
                  METRICSYSTEM=0
                    stebra
                    @tekka : I tested the ID reassign by hardcoding the functionality in the serial gw sketch. Reboot node 6, wait for FW_CONFIG_REQUEST, answer with FW_CONFIG_RESPONSE.
                    Works as expected & described in the MYSBootloader code. Please give me some hint why MYSController does not send the FW_CONFIG_RESPONSE packet with the bootloader commands after the reboot.
                    I trigger the reassign via the node´s context menu in the gui, MYSBootloader Commands --> reassign ID. Anything wrong with that ?
                    Maybe someone else has an idea what is happening/not happening ? @tekka could you find something in the log file?
                    Thanks a lot...
                      stebra
                      Has anyone tested successfully reassigning the node-id with MYSBootloader 1.1 and MYSController 1.2.282 ? Would give me some new motivation to hear it's possible and has been done before. At the very moment I m at a dead end.
                      If it is not working for you, I would also appreciate your feedback.
                      • greglG
                        greglG
                        gregl
                        @tekka
                        Is the (dev branch) MQTTClientGateway supported by MYSController?
                        I'm in the process of moving from Vera and Ethernet GW, to Openhab with MQTTClient gateway and would love to have the OTA functionality your bootloader and controller provides. I looked at this a while back, but ran out of time to play!
                        So yeah.. Can MYSController talk with the MQTTClientGateway ( over Ethernet) ?
                        Cheers,
                        Greg
                        • greglG
                          greglG
                          gregl
                          In answer to my own question... No..it doesnt seem to.. ;-(
                          I tried with the IP address of my MQTT client gateway board, and port 5003 ( same port that works for my 1.4 Ethernet GW )
                          It says it connects, but no data flows in....
                          @tekka @hek - Is it unlikely that the MQTTClient Gateway will be usable with MYSController??
                          If not, would this work?
                          Have two networks -
                          1 for MYSController to perform OTA's using a serial gateway on the PC we typically do sketch changes on.
                          2 for normal MySensors operation. When you want to invoke an update, you could send a I_REBOOT command ( MQTT message in my case), which would reboot the node and if i understand correctly, look for an update on the other network channel.
                          I guess you would loose all the other functionility of MYSController, but at least we could do OTA.
                          Cheers,
                          Greg
                          • S stebra
                            tekkaT
                            tekkaT
                            tekka
                            @stebra The log looks normal - is the node directly communicating with the gw or via a repeater? Does the clearEEPROM option work?
                            • greglG gregl
                              Have two networks -
                              Cheers,
                              Greg
                              tekkaT
                              tekkaT
                              tekka
                              @gregl MYSController is currently not supporting MQTT, I'll add it to my feature request w/o ETA.
                              crankyC 1 Reply Last reply
                                stebra
                                @tekka
                                No repeater, clear eeprom via MYSController gui does not work. Clear eeprom via sketch works, node gets new id after reboot.
                                My assumption is that MYSController does not respond to the FW_CONFIG_REQU after reboot.
                                • tekkaT tekka
                                  crankyC
                                  crankyC
                                  cranky
                                  @tekka You might not have to. I've been working on Node-Red as a controller and more.
                                  With my kit, you need Node-Red, node-red-contrib-mysensors , Mosquitto, and some of my flows which I have available ( http://forum.mysensors.org/topic/2802/flow-to-turn-serialgateway-into-mqtt-serialgateway ).
                                  And it makes this:
                                  http://forum.mysensors.org/topic/2815/flow-to-turn-serialgateway-with-mqtt-flow-to-ethernetgateway
                                  The only flaw is that when you first connect MYSController, you need to send a junk topic so that MYSController can receive data. It's a bug/peculiarity with Node-Red, but honestly not a big deal. I'm also working on how to fix even that.
                                    stebra
                                    @tekka
                                    Can you verify it works for you? Do you see any response packets with the bl commands in your log?
                                    • sundberg84S
                                      sundberg84S
                                      #359
                                      First time i try OTA. Everything went well until fw update (Pro mini). It sends/recieve like 20-30 packages, and then ends. I need to reconnect Myscontroller and it will start to flow again. I can see there is requests from node on gw led, but nothing comes through in Myscontroller (.282). Using 2.0b ethernet gw. Its just like either GW stops sending to Myscontroller or Myscontroller doesnt accept it. Also getting in domoticz that "MySensors: Connection reset!" Do i need to disconnect Domoticz while I do updates?
                                      Any clues?
                                      Edit: Sorry, jepp - needs to disconnect Domoticz and it works... I bet its those new gateway pings from Domoticz killing it.
                                      • sundberg84S
                                        sundberg84S
                                        #360
                                        A quick one: How long does the OTA takes for Blink sketch?
                                        I press update FW, it start rolling and the node changes status from "fw updating" to "booting" but then goes back to fw updating... have been going like this for a long time now (1000 packages sent/recieved).
                                        Also - is it possible to upload via fdti with MYSBootloader or you need to use OTA?
                                        Edit: somethings is not right, its rebooting or starting over again:
                                        2016-01-16 21:09:41	RX	14;255;4;0;2;0A0001002F00
                                        2016-01-16 21:09:43	TX	14;255;4;0;3;0A0001002F008083E1EBF0E0808184608083E0EBF0E0
                                        2016-01-16 21:09:43	RX	14;255;4;0;2;0A0001002F00
                                        2016-01-16 21:09:45	DEBUG	Undefined firmware/type for node=14
                                        2016-01-16 21:09:45	INFO	BL version=257
                                        2016-01-16 21:09:45	INFO	Send FW info to node 14: type=A, version=1, blocks=0x0048, CRC=0xD098
                                        2016-01-16 21:09:45	TX	14;0;4;0;1;0A000100480098D0
                                        2016-01-16 21:09:45	RX	14;255;4;0;0;FFFFFFFFFFFFFFFF0101
                                        2016-01-16 21:09:46	DEBUG	FW update started, node id = 14
                                        2016-01-16 21:09:46	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
                                        2016-01-16 21:09:46	RX	14;255;4;0;2;0A0001004700
                                        2016-01-16 21:09:47	TX	14;255;4;0;3;0A0001004700E1F30E940000F9CF0895F894FFCFFFFF
                                        2016-01-16 21:09:47	RX	14;255;4;0;2;0A0001004700
                                        2016-01-16 21:09:48	TX	14;255;4;0;3;0A00010046002C020E947000C0E0D0E00E948B002097
                                          stebra
                                          @tekka
                                          Fortunately a helpful guy gave me your bootloader 1.3 beta, which fixes the problem with nonworking bootloader commands. It seems I was not the first one asking you...
                                          For all others trying the bootloader commands in bootloader 1.1 : this does not work at all, and you are only wasting your time.
                                          I would really appreciate if the code for bl 1.3 was on github also. I do not mind if its beta only...
                                          Below the working debug output for a reassign nodeid 8 --> nodeid 88
                                          16.01.2016 23:06:46	RX	8;255;3;0;9;0108A000B9F7FFFEDA7221F0001E950F09
                                          16.01.2016 23:06:48	RX	0;0;3;0;9;read: 8-8-0 s=255,c=4,t=0,pt=6,l=10,sg=0:1E00010048047AA801
                                          16.01.2016 23:06:48	INFO	BL version=259
                                          16.01.2016 23:06:48	INFO	Executing bootloader command section
                                          16.01.2016 23:06:48	TX	8;255;4;0;1;0200580000007ADA
                                          16.01.2016 23:06:48	RX	8;255;4;0;0;1E00010048047AA80103
                                          16.01.2016 23:06:48	RX	0;0;3;0;9;send: 0-0-8-8 s=255,c=4,t=1,pt=6,l=8,sg=0,st=ok:02005800000
                                          16.01.2016 23:06:48	RX	0;0;3;0;9;read: 88-88-255 s=255,c=3,t=7,pt=1,l=1,sg=0:0
