  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.8k Views 69 Watching
  • A arnoldg
    can i run it on 5V without any problem.
    For the RF433 interface i need 5V so i would like to make one that is powerd by an usb charger.
    m26872M
    m26872M
    m26872
    @arnoldg The nRf24L01+ is rated like 1.9-3.7V. So 5V will probably kill it.
    • A
      arnoldg
      Oke, that's tru i didn't think of that.
      but when i use a 5v - 3v power suply in between it could work.
        sensorchecker
        @m26872
        I have already tested the "reed switch sensor" and it works fine for me- but with a power consumption of 2mA ...:-(
        Is it possible that i have a problem with the bootloader or the fuses ?
        How can i check that ?
        Usually i use USBASP and avrdude for programming the processors on breadboards.
        Is it also possible to do the whole programming with the arduino IDE ?
        • S sensorchecker
          @m26872
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          @sensorchecker did you try changing your nrf ?
          • BartEB
            BartEB
            BartE
            @sensorchecker and @m26872 changing the NRF module did work for me as well.
            I was struggling a lot getting the power consumption down using all the trick and tips as described on the mysensors forum but nothing worked for by battery powered nodes (i have a couple these ).
            I was not able to bring the power consumption down below 2.4 mA (with the NFR mounted) finally i just, for an differnt experiment, i took a "fresh"NRF and just for the fun i measured the current and it was down to 0.05 mA for no reason. They came from the same batch.
            My theory now is that i broke the first radio module during programming of the node, although the FTDI serial module is in 3.3v mode it still measures around 4.5 volt. So the voltage might has damaged my NRF radio a bit (it still communicates).
              sensorchecker
              @ahmedadelhosni and @BartE and @m26872 you made my day...!
              Changing the NRF module was the solution, now my power consumption is about 8uA.
              Now waiting for the PCBs and parts to build 10- 15 nodes
              Thank you so much for your help
              • F
                F
                flopp
                There is no crystal?
                I haven't used Atmega328P as standalone but I have read that you need a crystal.
                m26872M 1 Reply Last reply
                • F flopp
                  m26872M
                  m26872M
                  m26872
                  wrote on last edited by m26872
                  #136
                  @flopp There's an internal 8MHz xtal in the uC. Infact often default set to be used by factory "fuse" settings. It's not as ambient condition stable and accurate as an external crystal, but quite good enough for our application.
                  F 1 Reply Last reply
                  • m26872M m26872
                    F
                    F
                    flopp
                    @m26872 thanks
                    • F
                      F
                      flopp
                      wrote on last edited by flopp
                      #138
                      What about these pF caps, why not use SMD tantalum instead of Solid electrolyte with legs?
                      Or can I use ATmega without caps, since I dont have an external crystal?
                      m26872M 2 Replies Last reply
                      • F flopp
                        m26872M
                        m26872M
                        m26872
                        @flopp I doubt there are any electrolytes in the pF range seen here. If you mean the pF caps in the example pictures, they are not part of the Slim Node base concept and just a random choice I did for myself. If you mean all the 100nF caps in the base concept, it's a matter of the "smd free" design criteria I apply from time to time.
                        • F flopp
                          m26872M
                          m26872M
                          m26872
                          @flopp ... or if you refer to the standard pair of 22pF caps used when there is an external crystal - no, you wont need them.
                          • m26872M m26872
                            F
                            F
                            flopp
                            OK. Yes, I saw that there was cap in pictures.
                            • m26872M m26872
                              F
                              F
                              flopp
                              OK, perfect
                                meddie
                                wrote on last edited by meddie
                                #143
                                Hi together,
                                as first i have to say, its a nice node, that you build.
                                So i tried to build one. I ordered an atmega 328p. Flashed the bootloader from the forum. This is the boards.txt:
                                atmega328_1mhz_4800baud.name=ATmega328 on a breadboard 1MHz internal clock, fast start, 1.8V BOD, 4800baud upload
                                atmega328_1mhz_4800baud.upload.protocol=arduino
                                atmega328_1mhz_4800baud.upload.maximum_size=32256
                                atmega328_1mhz_4800baud.upload.speed=4800
                                atmega328_1mhz_4800baud.bootloader.low_fuses=0x42
                                atmega328_1mhz_4800baud.bootloader.high_fuses=0xDE
                                atmega328_1mhz_4800baud.bootloader.extended_fuses=0x06
                                atmega328_1mhz_4800baud.bootloader.file=atmega/atmega328_1b.hex
                                atmega328_1mhz_4800baud.bootloader.unlock_bits=0x3F
                                atmega328_1mhz_4800baud.bootloader.lock_bits=0x2F
                                atmega328_1mhz_4800baud.build.mcu=atmega328p
                                atmega328_1mhz_4800baud.build.f_cpu=1000000L
                                atmega328_1mhz_4800baud.build.core=arduino:arduino
                                atmega328_1mhz_4800baud.build.variant=arduino:standard
                                atmega328_1mhz_4800baud.bootloader.tool=arduino:avrdude
                                atmega328_1mhz_4800baud.upload.tool=arduino:avrdude
                                Now i have measured the current draw, and the arduino alone draws 6.8mA (without crystal, nrf ...)
                                I tried some sketches, (binaryswitchsleepsensor) but the current is not really gone down.
                                The only sketch is this:
                                // **** INCLUDES *****
                                #include "LowPower.h"
                                    // No setup is required for this library
                                    // Enter power down state for 8 s with ADC and BOD module disabled
                                    // Do something here
                                    // Example: Read sensor, data logging, data transmission.
                                With this sketch is the current 0.02mA
                                OK, 0.02mA is not bad, but when i read that some of you have few µa, i dont understand why the current on my atmega is so "high"
                                Can somebody tell me what bootloader is good, wich fuses are good. And maybe what i have to do to get the current so small as possble
                                Thank you very much
                                Greets Eddie
                                • M meddie
                                  Hi together,
                                  Thank you very much
                                  Greets Eddie
                                  m26872M
                                  m26872M
                                  m26872
                                  @meddie I don't really get what you've ruled out in your troubleshooting. Do you "test the arduino alone" using MySensors lib and example sketches? Using Lowpower lib directly works ok as it seems. Next step would be to connect the nRF24L01+ and run some MySensors lib example.
                                  Ext fuses 0x07 (BOD disabled) instead of 0x06 (BOD 1.8V) could save you a few uA.
                                    meddie
                                    Yes, on the bredboard is only the atmega 328p. nothing else. Connected to 5v
                                    Yes using the LowPower lib i came down to 0.01mA current draw.
                                    Ok, i will try it today evening.
                                    OK, i try this too.
                                    Thank you very much.
                                    Greets Eddie
                                      meddie
                                      ok, i tried to burn with 0x07 Fuse. And i tried to power the atmega with 3.3 v and not 5v.
                                      Now i came down to 4µA in sleep mode with the lowpower sketch.
                                      When i try to flash a mysensors sketch the the atmega has a current draw 1mA.
                                      m26872M A 2 Replies Last reply
                                      • M meddie
                                        m26872M
                                        m26872M
                                        m26872
                                        @meddie It's still unclear whether you've got the nRF connected and the MySensors example and library fully working (sleeping) before you measure.
                                        • M meddie
                                          ar91
                                          @meddie If you have a extra nRF try using that, i had a similar issue and i tried replacing the nRF and it came from mA to uA.
