  3. Domoticz
  4. Can not see my Humidity sensor
16 Posts 6 Posters 5.4k Views 3 Watching
    singinglarvae
    Hi and thanks for the quick reply.
    Debug is enabled I guess (see the 2 outputs in my first post), am I right?
    • F
      F
      flopp
      Sensor should say more, I think.
      I am very new to MySensor, since last week.
      • F
        F
        flopp
        Can you put your code here, for sensor
        • F
          F
          flopp
          wrote on last edited by flopp
          Isn't there a setting in Domoticz to "open" that a Device can be added?
            singinglarvae
            Tried to change the Arduino Mini used by the sensor for a Arduino Uno. Nothing changed (here goes the log):
            sensor started, id=255, parent=255, distance=255
            find parent
            send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            find parent
            find parent
            find parent
            find parent
            T: 19.00
            find parent
            H: 65.50
            find parent
            H: 65.60
            find parent
            H: 65.80
            find parent
            H: 65.50
            find parent
            T: 19.10
            find parent
            H: 65.70
            The sensor can not indeed see the parent (see 1st line). I guess the NRF24L01 module is somehow not working (I doubled check all my wires and they are fine). Shame I do not have another one :disappointed:
            • F
              F
              flopp
              Looks ok except that you don't get any response.
              Do you have more NRF, then change.
              • sundberg84S
                sundberg84S
                255 indicated that you dont recieve/asking for a node ID for that node.
                What does your GW log looks like when you start the node? Do you see any presentation?
                Maybe you also can post your code or is it unchanged from the humidity sensor?
                • crankyC
                  crankyC
                  cranky
                  If you open up a serial console with the SerialGateway, you can respond with the following
                  255;255;3;0;4;[ID you want it to have]
                  And then the ID will be copied into EEprom on the sensor and then work as that ID number you assign it.
                  • F
                    F
                    flopp
                    Do you have a capacitor on nRF24L01+?
                      singinglarvae
                      Thanks all for your replies :smiley:
                      I was indeed waiting for new NRF24L01 modules and I just received them this morning. I so performed few more trials. Here goes the results:
                      Done, but no change at all :disappointed:
                      GW log remains completely empty: no presentation at all. The code from the humidity sensor is unchanged.
                      Not pretty sure on what you mean. This command is performed on the gateway, or the sensor? I did it first on the sensor using the serial monitor, but nothing changed (I did it with id 0, with the one of the GW). And I tried on the sensor as well later on. But results were the same: a complete failure
                      I do not. I think it will be the next step!
                      As far as I understood, I do not have any communication between the GW and the sensor, and this either my wiring (but I already tripled check them) or my nRF24L01 (got them on Ebay, the quality is maybe poor). Am I right?
                      Thanks anyhow for all the advices!
                      F 1 Reply Last reply
                      • S singinglarvae
                        F
                        F
                        flopp
                        eBay items can be good and can be bad. I have only two NRF both are working but one is consuming a lot more than the other one.
                        Try to put the cap and see.
                          singinglarvae
                          Ok, it is solved :smiley:
                          On the GW, my wiring were good, but loose (but really, just a bit!). I soldered most of the wires on the arduino and now I receive information from the sensor!
                          Thanks all for the advices. I remember one of my US supervisor who use to say "Trust, but check, check and triple check". He is right indeed!
                          Nb; is it the habit on this forum to edit the title to [SOLVE]?
                          • S singinglarvae
                            I wouldn't say it is a habit, but it is definitely appreciated :-)
                            • ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              Lately I begun to face the same issue. I have my GW in a fixed place on my desk and I have two nodes for testing. The first one find the parent at once, and the second one doesn't. I retry resetting both and again the behavior is repeated. THen I tried moving the wires of the GW several times and suddenly the second one begun working.
                              Don't really know what is this but this happened twice this week :)
