  3. [SOLVED] No message after few hours
7 Posts 4 Posters 2.2k Views 5 Watching
  • ? Offline
    ? Offline
    A Former User
    I'm testing the network with domoticz on a raspberry and a couple of arduino nano with dht11 sensors.
    Everything works fine, but after few hours it seems my nodes stop transmitting. Robooting arduino solves the problem.
    Any idea?
    M Y 2 Replies Last reply
    • ? A Former User
      Any idea?
      M Offline
      M Offline
      m26872
      @gerseun DHT reading issue? Transmit batteryLevel or some other heartbeat message every hour to find out.
      • ? Offline
        ? Offline
        A Former User
        I am a newbie with arduino, what is a heartbeat message?
        • ? A Former User
          M Offline
          M Offline
          m26872
          @gerseun I just mean anything that tells you it's alive. Any kind of message sent to you at a known interval. It could be a flashing LED, radio message logged by controller or whatever.
          • ? A Former User
            Any idea?
            Y Offline
            Y Offline
            @gerseun Are all your radio id's unique?
            See here http://forum.mysensors.org/topic/2868/solved-mqtt-esp8266-gateway-1-6
            • ? Offline
              ? Offline
              A Former User
              I think I solved it.
              The reading from the sensor is good bad the trasmission stop randomly, so I tried to add coupling capacitors on the wirless module.
              It's more then 24h without problem so I think this solves it.
              • mfalkviddM Offline
                Yes not using capacitors usually causes problems. Great that you got it working. Thanks for reporting back!
