  3. nRF24L01+ will not start
6 Posts 4 Posters 3.6k Views 5 Watching
  • whitedrag0nW
    whitedrag0nW
    whitedrag0n
    Specify your environment:
    Arduino Nano Mega328 16mhz
    Arduino IDE 1.6.7, Windows 10
    Mysesnors library 1.5
    Hi, I am trying to build a simple serial gateway however when I read the debug information back from the nano. I get the following message.
    "0;0;3;0;9;radio init fail"
    The nano is wired up correctly and I have tried 3 radios they all give the same error.
    My nano is wired as below. All connection buzzed out from chip to chip.
    What am I doing wrong?
    • C
      C
      Carl Durr
      maybe try removing "IRQ" connection? as its not needed.
      also i had the some issues, but i had my wires mixed up..
      Follow this Tut:
      https://www.mysensors.org/build/connect_radio
      • whitedrag0nW
        whitedrag0nW
        whitedrag0n
        Looks like i have found the issue.
        The parts i ordered where nrf24l01+ but what i was sent was nrf24l01.
        Is there any way i can use the non plus version
        • ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          I am not really sure but I guess it won't differ.
          Radio init will happen if there is a connection problem. Make sure your wires are really connected and in place.
          Next thing try to solder 10uF between Vcc and GND of the nrf itself.
          Try with an example from the library to be sure that your sketch is written correctly.
            @whitedrag0n These radios are different. See http://forum.mysensors.org/topic/1887/what-s-the-difference-between-nrf24l01-and-nrf24l01
            They can probably be put to work by using correct settings. See http://forum.mysensors.org/topic/2838/mysensors-1-5-and-nrf24l01-without
            • YveauxY Yveaux
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @Yveaux Thanks. That was totally new to me :)
