  3. [SOLVED] Gateway as a sensor node in v1.6
23 Posts 4 Posters 9.6k Views 4 Watching
    @Dwalt A gateway that has sensors directly connected to it needs to use 1.6 (=development version).
    You can have several gateways and the gateways don't need to use the same version. If the gateways have nrf24 radios, the radios need to be configured to use different channels though. But that's not an issue if you don't connect a radio to the new gateway.
    Sensor nodes do not need to use the same MySensor version as the gateway, they can use higher or lower version.
    I hope that answers your question :-)
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @mfalkvidd if the second GW has another channel, by this it wont be communicating with the first GW ?
    In another words. I am just thinking about having a main GW and sub GWs for large distance converage. So they shall be on the same channel, right ?
    • mfalkviddM
      There is no such thing as a sub gw. There can only be one gw per channel. Gws cannot communicate with eachother.
      To me it sounds like you want repeater nodes.
      • ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        Yeah i want to use them as repeater nodes but I just thought that if I can add a wires etheenet repeater 60m (for example) away from the gateway rather than adding 2 or 3 nodes as a repeater nodes to cover a distance of 60m.
          @ahmedadelhosni there is no such thing as an ethernet repeater in the MySensors world.
          I'm sorry but I think I've run out of ways to explain this.
          • ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            No I understood your answer from the beggining. Thanks a lot :)
            I was just chatting about what I really wanted the library to support.
            Thanks a lot for your time.
            • mfalkviddM
              From some of your posts, it sounds like you should just add a second gateway and you're done. But you keep calling it a repeater and I 'm unable to figure out how to proceed.
              • mfalkviddM
                https://www.mysensors.org/about/network might help a little bit
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  Yeah that was the answer for my question at the beginning.
                  After your answer - which is above - I understood that the concept which I need is not supported. I will draw a diagram showing why I called it a repeater sometimes.
                  • mfalkviddM
                    A picture would be great :-) Thanks for your patience.
                    • ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      0_1453657946793_upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6
                      I hope this explains my request :)
                      First half shows the normal MYsensor library where S1 needs to pass through RC > RB > RA to reach GW1. Also it shows another example to use only one repeater so that S2 reached GW1 through RD. All of this needs several repeaters to be placed at different distances to conver a long distance.
                      I guess we agree to this :)
                      My question was about the second half in the picture. I have GW1 which is UNO + W5100 connected to a network switch. Then there is the Yellow and Blue thing. Imagine replacing all these repeater nodes by another UNO + W5100 which is the Yellow and Blue circle. Thus S1 needs to pass by this yellow and blue circle (2) to reach GW1. That's why I named it as a repeater, as it sends data from a long distance to the GW. Don't know what is the correct description for this :)
                      Thus my thoughts were : The yellow and blue thing since it is connected to a network it can communicate with the ethernet gateway through network. ( Actually I found that this is implemented using ESP ) I guess the ESP itself can be used as a repeater node. So it can be placed in a far place and send data to the GW through the network. I didn't use the ESP with MYs but I guess it is a valid example :)
                      Hope this simplifies my question.
                      • mfalkviddM
                        Thanks for explaining. So if I understand you correctly, you want a simple way for Domoticz to reach S1?
                        I hope this picture shows what the network would look like with a second gateway.
                        0_1453660466990_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd.png
                        That's it. You're done. No need for a new Yellow and Blue thing.
                        I must be missing something.
                        • mfalkviddM
                          Maybe this better describes how adding a second gateway would work
                          0_1453662278625_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd2.png
                          • ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            wrote on last edited by ahmedadelhosni
                            Yeah you solved this issue now. That's exactly what I needed :)
                            The second picture explains it all. I wasn't able to understand how will I have several GWs although you explained it above from the beginning, but I wasn't aware how to do it. I remembered now from your last picture that domoticz can support several hardware. Thus I can make another GW and add it to the hardware in Domoticz as you have explained in your last picture.
                            Thanks a lot for your time. Now it is very clear :)
                            • mfalkviddM
                              Victory! :trophy:
                              You're welcome :)
                              • jeylitesJ
                                jeylitesJ
                                jeylites
                                Should a Repeater have it's on unique ID or the same ID as the NODE that it's repeating?
                                • mfalkviddM
                                  #23
                                  It has its own id. Please don't post the same question in multiple places. It wastes people's time.
