  3. [SOLVED] Gateway as a sensor node in v1.6
23 Posts 4 Posters 9.6k Views 4 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    No I understood your answer from the beggining. Thanks a lot :)
    I was just chatting about what I really wanted the library to support.
    Thanks a lot for your time.
    • mfalkviddM
      From some of your posts, it sounds like you should just add a second gateway and you're done. But you keep calling it a repeater and I 'm unable to figure out how to proceed.
      • mfalkviddM
        https://www.mysensors.org/about/network might help a little bit
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          Yeah that was the answer for my question at the beginning.
          After your answer - which is above - I understood that the concept which I need is not supported. I will draw a diagram showing why I called it a repeater sometimes.
          • mfalkviddM
            A picture would be great :-) Thanks for your patience.
            • ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              0_1453657946793_upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6
              I hope this explains my request :)
              First half shows the normal MYsensor library where S1 needs to pass through RC > RB > RA to reach GW1. Also it shows another example to use only one repeater so that S2 reached GW1 through RD. All of this needs several repeaters to be placed at different distances to conver a long distance.
              I guess we agree to this :)
              My question was about the second half in the picture. I have GW1 which is UNO + W5100 connected to a network switch. Then there is the Yellow and Blue thing. Imagine replacing all these repeater nodes by another UNO + W5100 which is the Yellow and Blue circle. Thus S1 needs to pass by this yellow and blue circle (2) to reach GW1. That's why I named it as a repeater, as it sends data from a long distance to the GW. Don't know what is the correct description for this :)
              Thus my thoughts were : The yellow and blue thing since it is connected to a network it can communicate with the ethernet gateway through network. ( Actually I found that this is implemented using ESP ) I guess the ESP itself can be used as a repeater node. So it can be placed in a far place and send data to the GW through the network. I didn't use the ESP with MYs but I guess it is a valid example :)
              Hope this simplifies my question.
              • mfalkviddM
                Thanks for explaining. So if I understand you correctly, you want a simple way for Domoticz to reach S1?
                I hope this picture shows what the network would look like with a second gateway.
                0_1453660466990_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd.png
                That's it. You're done. No need for a new Yellow and Blue thing.
                I must be missing something.
                • mfalkviddM
                  Maybe this better describes how adding a second gateway would work
                  0_1453662278625_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd2.png
                  • ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    wrote on last edited by ahmedadelhosni
                    Yeah you solved this issue now. That's exactly what I needed :)
                    The second picture explains it all. I wasn't able to understand how will I have several GWs although you explained it above from the beginning, but I wasn't aware how to do it. I remembered now from your last picture that domoticz can support several hardware. Thus I can make another GW and add it to the hardware in Domoticz as you have explained in your last picture.
                    Thanks a lot for your time. Now it is very clear :)
                    • mfalkviddM
                      Victory! :trophy:
                      You're welcome :)
                      • jeylitesJ
                        jeylitesJ
                        jeylites
                        Should a Repeater have it's on unique ID or the same ID as the NODE that it's repeating?
                        • mfalkviddM
                          #23
                          It has its own id. Please don't post the same question in multiple places. It wastes people's time.
