  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.8k Views 69 Watching
  • m26872M m26872
    @ahmedadelhosni Welcome back! Yes I remember you had to struggle and could not buy common 433MHz remote controlled switches. Makes sense to do diy projects then I guess.
    Hope you get your new nodes running. Please share your result.
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @m26872 You are right.
    I'll go tomorrow and try to get the approval :) Well back soon
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      wrote on last edited by ahmedadelhosni
      #160
      Finally !
      11 pcbs. But I am really angry and feel bad from what happened by DHL.
      I paid 29$ for shipping and here in Egypt i paid stupid fees for customs and several things equal to 38$ !!!!! I dont know wether this is something related to my country Egypt or not :(
      I' ll try to forget all what I paid when I do my first node.
      • E
        E
        ericvdb
        @ahmedadelhosni that really sucks :disappointed:
        • B
          B
          betonishard
          wrote on last edited by betonishard
          #162
          Hello all,
          I have been struggling with this for a couple of weeks now and I just can seem to figure out a good way to upload sketches to the arduio328p-pu. First of all I use this setup;
          I use arduino for mac 1.6.5
          I use a breadboard with a crystal, two capacitors and a resistor between reset and 5v.
          An arduino to burn bootloader (with the chip inserted and sketch arduinoISP uploaded).
          I use the same hex files as you guys with 1a. I used the optiboot 9600 BOD, just the 9600 and the 4800. Uploading the bootloader is no problem at all. Arduino ide burns the bootloader without any problems. However when I try to upload the sketches I get different errors. The “Yikes” version in which it states that my device signature is not ok and programmer not responding. I use upload using programmer.
          So, I tried to upload the arduino uno version to rule out all miscabling. So what I did was upload the arduino uno bootloader, tried to upload the blink sketch afterwards and it works. So my cables are ok….
          I thought to repeat the exact same process with the boot version above. However no succes, I keep getting stuck at uploading sketches. Is it just not possible?
          I read about setting the fuse options and I read that when you define these in the boards.txt, they will be set as the fuseparameters. When I check the boards txt above i see that fuse settings are: L0x62,H0xde,E0x07, however when I open the png file (first post, fuse settings) it states L0x62,H0xDE,E0xFF. Furthermore the lockbits are at 0xCF, compared to the boards.txt 0x2F. What is true and how should I set these. I don’t see a possibility in arduino ide (I use another arduino to upload, so I don’t have a tiny or USBASP.
          Help would be much appreciated here because I have like 30 boards sitting catching dust.
          m26872M M 2 Replies Last reply
            @ahmedadelhosni : no luck! Here same for us in France. I think it's because they handle our package from airport to house...but have we not already paid for this! There is vat of course too, but here vat+15euro extra mystical handle fee.
            Fun, is when you want to make a joke to the dhl person and you ask why fees, I don't want pay, give me my package, no come back!! ahaha they are not funny :) At less, if they were doing right their job, 4times/10 they say "you were not here"??? yep, but I was there..and where is the paper in my mailbox, nothing...arrgh! what do you think I will wait you on the road???
            No matter, looking at your package, I think you will have lot of fun :)
            • scalzS scalz
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              #164
              @scalz Seeing that someone else had the same issue made me better hahaha :)
              The problem that I went myself to take it today and they told me that I have to buy for the customs and the government.
              I need to calm down and have fun better. Thanks :)
              • B betonishard
                Hello all,
                m26872M
                m26872M
                m26872
                @betonishard A few "unused" bits of the Ext fuses are differently written in avrdude (Arduino IDE) and Atmel IDE programmer implemetation. That's why the same settings can look different. You have to know which one you use.
                Search for "Avr fuse calculator" on the internet and some will show you fuses for both methods.
                I also had issues with avrdude when I started and never got it to work. A lot of others do of course, but I found the Atmel way easier for me. Hence only this is shown in the pictures. The bootloading business is not easy and a lot of info is availible on the arduino forums. I think the only way is to read and study.
                • B betonishard
                  Hello all,
                  meddie
                  @betonishard said:
                  Hello all,
                  Hi, i had the same problem, but then i tried the 1b hex and since i burned this it works for me.
                  • GertSandersG GertSanders
                    Makes sense to me. By closing the contact you get a path from 3V3 via the pullup resistor to ground.
                    The current is (for a pullup resistor value around 30KOhm) around 100uA.
                    Try NOT using the internal pullup resistor of pin D3, and using an external pullup resistor of 1MOhm or more.
                    You will see lower current when the contact is closed.
                    meddie
                    wrote on last edited by meddie
                    #167
                    The current is (for a pullup resistor value around 30KOhm) arounda lot of 100uA.
                    Yesterday i get a lot of resistors, now i testen 1Mohm and the current draw is around 4 µa, but now the arduino do not recognize when the reedcontact is closed or open. When the contact is closed the current draw is 4 µa when opened 1.2µa
                    do i have to edit the sketch in order to get it to work?
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      @meddie
                      The pull up 1MOhm resistor should go from Vcc - resistor - D2
                      The switch should be connected to D2 and Gnd
                      D2 needs to be defined as INPUT, no need to add the statement with PULLUP.
                      Post your sketch so we can have a look.
                        meddie
                        #define SKETCH_MAJOR_VER "1"
                        #define SKETCH_MINOR_VER "0"
                        #define PRIMARY_CHILD_ID 3
                        #define SECONDARY_CHILD_ID 4
                        MySensor sensor_node;
                          sensor_node.begin();
                          // Setup the buttons
                          // Activate internal pull-ups
                          sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
                          sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
                          uint8_t value;
                          static uint8_t sentValue=2;
                          static uint8_t sentValue2=2;
                          sensor_node.sleep(5);
                          if (value != sentValue) {
                             sentValue = value;
                          if (value != sentValue2) {
                             sentValue2 = value;
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          #170
                          If you use the external pull up, you need to comment out these two lines like so:
                          // digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
                          // digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
                          No need for an internal pullup if you use an external pull up.
                          In the above I'm assuming you have an external pullup resistor for each digital pin, one for D2 and one for D3.
                          • m26872M m26872
                            @ahmedadelhosni You know that the nRF pins are not centered? That means if you rotate it like this it will no longer be straight above the "slim node motherboard".
                            What height do you expect it to be?
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            I understood now what you meant by "not centered". Thanks for notifying me.
                            I'll take care of that.
                            • B
                              B
                              betonishard
                              #172
                              @meddie are you also using the optiboot 9600 NOBOD in boards.txt the same as in the first post (fuse settings I mean)? And are you using avrdude arduino ide for mac?
                              I tried your solution but i get the same results.. Yikes!
                              If you use the same setup, can you post your boards.txt? Did you also make changes to the hex file?
                              Thanks in advance.
                              • B
                                B
                                betonishard
                                @m26872 Thanks for your answer... The problem is I read a lot about it (which makes me kinda stupid that I still haven't achieved this).
                                I tried to find atmel studio (I believe you are referring to atmel studio?) I couldn't find a proper mac version. I checked on the fuse calculator and still no success. Maybe some one could give me the correct fuse settings for AVR or a proper mac download link for atmel studio.
                                OI know I am asking a lot, but it would help me a lot. Thanks.!!
                                m26872M 1 Reply Last reply
                                • B betonishard
                                  m26872M
                                  m26872M
                                  m26872
                                  @betonishard Yes, of course ask if you have problem. But I suggest you also make a new separate thread in General-, Hw- or Troubleshooting section about your issues.
                                  Maybe it's a good idea to ask in arduino forum as well.
                                  • ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    Hello @m26872
                                    I succeeded now to burn the bootloader which you used (1Mhz). I just don't understand a phrase which you mentioned above.
                                    According to this you should use minimal startup time to reduce power in every 8s sleep cycle, but for the moment I don't care and stick to the default 65ms.
                                    Can you explain what is this ? and whether it is affecting badly on something or not ?
                                    Thanks..
                                      meddie
                                      its the fuse, which defines the rising time. the oscillator needs some time to come to the correct frequency. If you dont wait this time its possble that your sketch dont work correctly. But the microcontroller is the 65 ms longer not in sleep mode and need more battery power. but works more stable.
                                        meddie
                                        YEAH, YEAH YEAH! Thank you all for the help a big thanks to GertSanders. Now it seems to work perfectly. The current draw is now 4.6µa. Now i have to transfer from bredboard to pcb.
                                        Thank you very much!!!!!!
                                          meddie
                                          Here
                                          Hi no i use the ide for Windows i dont have a mac.
                                          Here is the hex File
                                          :107E0000112484B714BE81FFE6D085E08093810001
                                          :107E100082E08093C00088E18093C10086E0809377
                                          :107E2000C20089E18093C4008EE0BFD0259A86E02D
                                          :107E300023EC3FEF91E0309385002093840096BBC4
                                          :107E4000B09BFECF1D9AA8958150A9F7EE24FF2480
                                          :107E5000AA24A394B5E0CB2EA1E1BA2EF3E0DF2E45
                                          :107E600098D0813461F495D0082FA5D0023829F13B
                                          :107E7000013811F485E001C083E083D07FC08234F3
                                          :107E800011F484E103C0853419F485E09CD076C0F8
                                          :107E9000853579F47ED0E82EFF247BD0082F10E0C2
                                          :107EA000102F00270E291F29000F111F84D07801E1
                                          :107EB00065C0863521F484E086D080E0DECF84364C
                                          :107EC00009F040C066D065D0082F63D080E0E81686
                                          :107ED00080E7F80618F4F701D7BEE895C0E0D1E0D6
                                          :107EE00058D089930C17E1F7F0E0EF16F0E7FF06A2
                                          :107EF00018F0F701D7BEE8955ED007B600FCFDCFBD
                                          :107F0000A701A0E0B1E02C9130E011968C9111977F
                                          :107F100090E0982F8827822B932B1296FA010C0160
                                          :107F2000A7BEE89511244E5F5F4FF1E0A038BF0770
                                          :107F300051F7F701C7BEE89507B600FCFDCFB7BE05
                                          :107F4000E8951CC0843761F424D023D0082F21D0B9
                                          :107F500032D0F70185917F0114D00150D1F70EC0C6
                                          :107F6000853739F428D08EE10CD085E90AD08FE02E
                                          :107F700084CF813511F488E018D01DD080E101D084
                                          :107F80006FCF982F8091C00085FFFCCF9093C600E3
                                          :107F900008958091C00087FFFCCF8091C00084FDD0
                                          :107FA00001C0A8958091C6000895E0E6F0E098E150
                                          :107FB000908380830895EDDF803219F088E0F5DF4B
                                          :107FC000FFCF84E1DECF1F93182FE3DF1150E9F7D5
                                          :107FD000F2DF1F910895282E80E0E7DFEE27FF27CC
                                          :027FE000099402
                                          :027FFE0000057C
                                          :0400000300007E007B
                                          :00000001FF
                                          Just create a new txt file put this code in there and rename the file to atmega328_1b.hex
                                          this is my boards.txt:
                                          atmega328_1mhz_4800baud.name=ATmega328 on a breadboard 1MHz internal clock, fast start, 1.8V BOD, 4800baud upload
                                          atmega328_1mhz_4800baud.upload.protocol=arduino
                                          atmega328_1mhz_4800baud.upload.maximum_size=32256
                                          atmega328_1mhz_4800baud.upload.speed=4800
                                          atmega328_1mhz_4800baud.bootloader.low_fuses=0x42
                                          atmega328_1mhz_4800baud.bootloader.high_fuses=0xDE
                                          atmega328_1mhz_4800baud.bootloader.extended_fuses=0x07
                                          atmega328_1mhz_4800baud.bootloader.file=atmega/atmega328_1b.hex
                                          atmega328_1mhz_4800baud.bootloader.unlock_bits=0x3F
                                          atmega328_1mhz_4800baud.bootloader.lock_bits=0x2F
                                          atmega328_1mhz_4800baud.build.mcu=atmega328p
                                          atmega328_1mhz_4800baud.build.f_cpu=1000000L
                                          atmega328_1mhz_4800baud.build.core=arduino:arduino
                                          atmega328_1mhz_4800baud.build.variant=arduino:standard
                                          atmega328_1mhz_4800baud.bootloader.tool=arduino:avrdude
                                          atmega328_1mhz_4800baud.upload.tool=arduino:avrdude
                                          this worked for me!
                                          B 1 Reply Last reply
