  3. Sensebender Micro as gateway on raspberry pi
7 Posts 5 Posters 3.4k Views 5 Watching
  • G
    G
    gloob
    I want to use the sensebender micro as a Gateway on the raspberry pi.
    I have connected the rx and tx line directly to the I/Os of the raspberry and also the 3.3V for the power.
    In the controller I can connect to the gateway and receive data, but when I trie to send a value, nothing is send out.
    Also assigning an ID to a new sensor fails.
    It seems that the transmission from the raspberry to the sensebender is not working.
    Does anybody have an idea how to solve this?
    • G
      G
      gloob
      Did nobody use the internal serial connection of the raspberry pi?
      andredtsA 1 Reply Last reply
        I think you might be the first! Most people use USB serial connection.
        • G gloob
          andredtsA
          andredtsA
          andredts
          @gloob
          I use it, but with one ATmega connected internally. If you have everything connected correctly, TX to RX and RX to TX, maybe you need to add the port /dev/ttyAMA0 to your controller.
          I use Openhab, and for this one, you have to add "-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 " on start.sh before the line with ".jar".
            Stric
            Lower the speed from 115200 to 19200, 9600 or similar. The frequency of the arduino is not able to match 115200 baud exactly, so the arduino and rpi are mis-communicating.
            From another thread; http://wormfood.net/avrbaudcalc.php?postclock=8&hidetables=1
            Solved it for me.
            • T
              ToniA
              Yes, it's about the baud rate. 38400 works for me, and I even made a pull request (not yet merged, though): https://github.com/mysensors/Arduino/pull/391
              Recent Domoticz beta's also have a feature to select the baud rate for MySensors serial gateway (default 115200, 38400 as an alternative). This of course needs to match with the baud rate on the gateway itself.
              • S Stric
                Solved it for me.
                andredtsA
                andredtsA
                andredts
                @Stric
                Good to know! I don't have this kind of problem because I use a Atmega328 with external 16MHz clock. The Sensebender Micro uses internal clock and run as low as 1MHz, so there is your problem.
