  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.5k Views 30 Watching
  • noelgeorgiN noelgeorgi
    @Anticimex @hek is it possible to encrypt the data sent over nrf modules using this https://github.com/DavyLandman/AESLib ???
    AnticimexA
    AnticimexA
    Anticimex
    @noelgeorgi AES encryption is already supported for both NRF24 and RFM69 radios. See MyConfig.h on the development branch for the flag to use. Doyxgen documentation I link to in this thread on the topic post also contain the personalization instructions for encryption on the development branch.
    noelgeorgiN 1 Reply Last reply
    • AnticimexA Anticimex
      noelgeorgiN
      noelgeorgiN
      noelgeorgi
      Thanks for the info.
      I'm getting the following errors when compiling securitypersonalizer:
      Arduino: 1.6.7 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
      /home/technoman/Arduino/libraries/MySensors/examples/SecurityPersonalizer/SecurityPersonalizer.ino:83:28: fatal error: sha204_library.h: No such file or directory
       #include <sha204_library.h>
      compilation terminated.
      exit status 1
      Error compiling.
      doesnt the ATSHA204 library has ATSHA204.h
      AnticimexA 1 Reply Last reply
        exit status 1
        Error compiling.
        AnticimexA
        AnticimexA
        Anticimex
        @noelgeorgi master or development branch?
          noelgeorgiN
          noelgeorgiN
          noelgeorgi
          @Anticimex development branch
            AnticimexA
            AnticimexA
            Anticimex
            @noelgeorgi have you made changes to the sketch? Jenkins builds it without problems.
              noelgeorgiN
              noelgeorgiN
              noelgeorgi
              @Anticimex no, I'm using the sketch from the examples.....:confused:
              am i missing some libraries????
                AnticimexA
                AnticimexA
                Anticimex
                @noelgeorgi if you have cloned the arduino git you have everything you need. I can build that sketch myself and have used it many times. I suspect you have a problem with your environment if you get compilation errors in it. We continously test the repository and build all examples nightly to make sure it all works as it is supposed to. You can see this at ci.mysensors.org
                  noelgeorgiN
                  noelgeorgiN
                  noelgeorgi
                  @Anticimex sorry for the interruption, i was using rsync to get eveything synced and i might have messed something uop, sha204 library was missing from my libraries folder, now everything works, thanks for the prompt and fast support.
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    :thumbsup:
                    • TD22057T
                      TD22057T
                      TD22057
                      @Anticimex - thanks for this. I finally got around to enabling signing on everything while I was testing out my new board design. I followed your schematic from your board design when I built mine and I just went through the instructions to configure the crypto chip and everything went smoothly. Thanks for the work and the good instructions!
                      • TD22057T TD22057
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @TD22057 that's really nice to hear! Are you using a stable release or the development/beta channel?
                        TD22057T 1 Reply Last reply
                          TD22057T
                          TD22057T
                          TD22057
                          @Anticimex
                          I used the signing sketch on the dev branch - I'm in the process of shifting my stuff over to the dev branch from 1.5 now.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            Ok, cool. As you might have noticed, personalization has changed a bit on development. Also, whitelisting works slightly differently/better.
                            • Pierre PP
                              Pierre PP
                              Pierre P
                              Isn't blacklisting cool too to use ?
                              Like, if we know the "name" of the sensor lost, we push it to the black list and voila ? This way, we don't have to put a long list a agreed sensors if we have only two nodes outside the house.
                              ... I think.
                              No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
                              • Pierre PP Pierre P
                                ... I think.
                                AnticimexA
                                AnticimexA
                                Anticimex
                                #219
                                @Pierre-P because if a node is lost, you no longer control that node. So anyone could reprogram it to have it identify itself in any way possible. We have to assume an attacker has full source code access, so they can rewrite the signing algorithm to use a fake serial as salt for the signature to trick the GW to believe it is a new node. A whitelist mean the attacker has to know the ID/serial of one of the nodes you trust. Which they won't know unless they can get access to that node.
                                • Pierre PP
                                  Pierre PP
                                  Pierre P
                                  Thanks for the complet answer !
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @Pierre-P you are welcome. Security is best when it is totally open and the implementation is aware of this. That makes it quite difficult to circumvent, and it also allows to be challenged. That way, with many eyes examining it, it gets stronger and stronger :) I welcome all attempts to crack it. White or black hat style.
                                    • SoloamS
                                      SoloamS
                                      Soloam
                                      Hello all! What would require less flash memory? Signing by ATSHA204A Chip or by software?
                                      • AnticimexA
                                        AnticimexA
                                        Anticimex
                                        Signing by ATSHA204A require less flash memory, but takes longer to execute (at least on 8MHz AtMega328).
                                        • SoloamS
                                          SoloamS
                                          Soloam
                                          wrote on last edited by Soloam
                                          #224
                                          @Anticimex assumed that, but this post on the forum got me confused: http://forum.mysensors.org/topic/2005/software-aes-encryption-for-nrf24/19
                                          According to that post, he uses software on the SenseBender with Encryption because, according to him "...encryption and ATSHA204A is to big for the SenseBender... ".
                                          I would like to add Signing and encryption to my nodes, but I don't know if it will fit on my Atmega328 flash!
