  3. Help me choose smd components from mouser
9 Posts 3 Posters 4.2k Views 1 Watching
  • A Offline
    A Offline
    ahmedadelhosni
    I am trying to buy some components form mouser but I don't understand all parameters.
    Currently I want to select the 4.7uF smd capacitor in 603 size.
    http://www2.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/MLCCs-Multilayer-Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-bkrdv?P=1z0wrjcZ1yzmou6Z1z0wtpxZ1yx4avt&Keyword=4.7uf&FS=True&Ns=Pricing|0
    I chose the "case code - in" to be 0603. Is this correct ? I am confused because I found out that there is 0603 in mm and in Inch. So when I create my eagle files with 0603 package, is this inch or mm ? http://www.topline.tv/SizeChart.html
    I am also confused about the "Series" filter. I couldn't understand what it mean.
    Thank you.
    • A Offline
      A Offline
      ahmedadelhosni
      Can you help me in this please @tbowmo ?
      • T Offline
        T Offline
        TD22057
        Look at the filters - there is one for "case code-in" and one for "case code-mm". So if you pick 0603 in "case-code-in", you get a normal 0603 part (metric 1608). If you pick 0603 in "case-code-mm", you'll get the metric 0603 (imperial 0201).
        FYI I have ordered a lot 0805 cap's and resistors from this seller on aliexpress ($2-3 per 100) and haven't had any problems with them yet.
        In Eagle 0603 is going to be the imperial 0603 part.
        A 1 Reply Last reply
        • T Offline
          T Offline
          tbowmo
          Go with imperial sizes for components, otherwise you'll get a surprise when you get them. Made the mistake myself.. 0402 metric is damn small and impossible to do manual smd with :)
          • T TD22057
            A Offline
            A Offline
            ahmedadelhosni
            wrote on last edited by ahmedadelhosni
            Thanks a lot for the clear explanation. I understand now that I will do a filter "case code-in" equal to 0603 and this will get me the same size which is used by Eagle.
            Any idea what is the "Series" filter ?
            • T tbowmo
              A Offline
              A Offline
              ahmedadelhosni
              @tbowmo Yeah I read approx. 50 replies in the thread related to mysensor node, that's why I wanted to make sure before I order :)
              You suggest a specific type/or link from mouser for a 4.7uf for the radio ? I am afraid to choose a wrong value and I want to make like 50 boards :)
              • A Offline
                A Offline
                ahmedadelhosni
                @tbowmo I found now that my cart had components in 0603 metric :) Damn :)
                • T Offline
                  T Offline
                  tbowmo
                  @ahmedadelhosni
                  I chose a ceramic 4u7 capacitor.. Check prices, and voltage ratings.. For the voltage, choose something a little higher than the maximum supply voltage that you want to use.
                  for 5V supply, go with 6V or 10V (then there are some margins left). for 3v3 go for a 5/6V capacitor.
                  • T tbowmo
                    @ahmedadelhosni
                    A Offline
                    A Offline
                    ahmedadelhosni
                    @tbowmo Thanks a lot. It is just that "Series" filter which is confusing me :) I am searching to know what it means because I find that all factors are the same except for this filter, and the price varies.
