  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.4k Views 20 Watching
  • carlierdC
    carlierdC
    carlierd
    Hello @m26872 !
    I really loved your slim node ! Nice job !
    I will probably copy your design and replace the NRF by a RFM69. Actually I work with mini pro but as I don't want to desolder the LED and the regulator it's time to come-back with DIP format ;)
    The power consumption seems the same with the SI7021 and a DHT22 ?
    David.
    m26872M 1 Reply Last reply
    • carlierdC carlierd
      Hello @m26872 !
      David.
      m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      @carlierd You're welcome! It's "licensed" Public Domain, so use it as you wish. But of course - please make it open hardware if you come up with something.
      I only measure the sensor nodes total sleep mode consumption and since the DHT22 requires a 3.3V booster (Iq ~90uA) it's hard to tell if it's exactly the same.
      • carlierdC
        carlierdC
        carlierd
        @m26872 : I don't use booster. You think it's necessary ? 90uA is really important for battery operation.
        For the design off course I will make it open hardware :)
        David.
        m26872M A 2 Replies Last reply
          David.
          m26872M
          m26872M
          m26872
          @carlierd What's your setup then? The DHT22 is for 3.3-5.5V.
          carlierdC 1 Reply Last reply
          • A
            ar91
            wrote on last edited by ar91
            @m26872 I have built the Slim Node described above and i am using your exact sketch given above but when i look at the serial monitor, it is printing junk characters i tried different baud rates on the serial monitor but nothing works.
            I am connected to the slim node using FTDI board.
            Any thoughts?
            Thanks for your help.
            • A ar91
              Any thoughts?
              m26872M
              m26872M
              m26872
              @ar91 Did you change baud rate in MySensors config too?
              A 1 Reply Last reply
              • m26872M m26872
                I've tried to post some sensor examples in the main Slim Node thread. It's continuously growing and I think it's better to start new threads for as much as possible. Here's one. I used this Si7021 (GY-21 board).
                Sketch
                Apologize for still not having cleaned up the sketch yet ...
                by m26872, 20151109
                #include <SI7021.h>
                #include <RunningAverage.h>
                //#define DEBUG
                #ifdef DEBUG
                #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                #define CHILD_ID_TEMP 0
                #define CHILD_ID_HUM 1
                // #define SLEEP_TIME 15000 // 15s for DEBUG
                #define SLEEP_TIME 300000   // 5 min
                #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                #define VMIN 1900
                #define VMAX 3300
                #define AVERAGES 2
                int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                int measureCount = 0;
                float lastTemperature = -100;
                int lastHumidity = -100;
                SI7021 humiditySensor;
                  DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                  DEBUG_PRINT("Voltage: ");
                  DEBUG_PRINT(readVcc());
                  DEBUG_PRINTLN(" mV");
                  delay(500);
                  DEBUG_PRINTLN(" *C");
                  gw.begin(NULL,NODE_ID);
                  gw.sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
                  gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                  DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                  raHum.clear();
                  measureCount ++;
                  batteryReportCounter ++;
                  bool forceTransmit = false;
                  if (measureCount > FORCE_TRANSMIT_CYCLE) {
                	forceTransmit = true;
                  // Read and print internal temp
                  float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                  DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                  // Check battery
                  if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                	long batteryVolt = readVcc();
                	DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                	uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                	DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                	batteryReportCounter = 0;
                  gw.sleep(SLEEP_TIME);
                // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                long readVcc() {
                // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                  unsigned int wADC;
                  double t;
                  // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                  ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                  ADCSRA |= _BV(ADEN);  // enable the ADC
                  delay(20);            // wait for voltages to become stable.
                  ADCSRA |= _BV(ADSC);  // Start the ADC
                  while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                  wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                  t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                  return (t);   // The returned temperature in degrees Celcius.
                 * Parameters
                  bool tx = force;
                  float temperature = data.celsiusHundredths / 100.0;
                  if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                	gw.send(msgTemp.set(temperature,1));
                	measureCount = 0;
                	DEBUG_PRINTLN("T sent!");
                  raHum.addValue(humidity);
                  if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                	gw.send(msgHum.set(humidity));
                	lastHumidity = humidity;
                	measureCount = 0;
                	DEBUG_PRINTLN("H sent!");
                Notes
                Here (and often in other projects as well) the GY-21 board is used to provide the Si7021 sensor . I'm not sure about the identity of components on it, but apart from the sensor the board also includes a small 3.3V-regulator (LDO), mosfets for logic level convertion, supporting capacitors and pull-up resistors.
                The voltage regulator is desoldered and bypassed in pictures above. This gained a node sleep current reduction from 10.7uA to ~6uA. This is the only modification necessary to do on the GY-21.
                The GY-21 board is obviously designed for 5V-projects, but removing-/bypassing the v-reg is enough for using it in our low power 3.3-1.9V applications. @riataman was the first to show the mod of the GY-21 board in this post. There's also a link to a board without the v-reg and level converter. If you design you own pcb you'll probably use the Si7021 bare chip instead of the GY-21 board.
                I had some thoughts about voltage dropout level and the level converter. In the end I still have thoughts, but my experiments show no issues. Here's a description of the level converter working principle. Remember that I don't know if these specs are equivalent, but looking at the mosfet datasheet, it says "Diode forward voltage drop 0.85-1.5V" and "Gate threshold voltage 1.0-2.5V". It's also an "Enhancment mode" FET, where the threshold voltage is important according to this. All together makes me worried about the High side capability to pull down Low side when High side volt is <2V instead of 5V. My tests show differently though. There are no real issues with this. The Si7021 worked down to ~1.7-1.8V with no significant difference whether the level converter was bypassed or not. Comparing one node with bypassed level converter to one without, showed ~1uA lower sleep mode current. But I assume it could just as well be a matter of the individual variations. If anyone like to bypass their level converter, here's a picture.
                GertSandersG
                GertSandersG
                GertSanders
                @m26872 There is another version of the SI7021 board without voltage regulator. This evening I will look up the link on Aliexpress. The boards are smaller then the GY-21 variant.
                • m26872M m26872
                  ar91
                  Thanks @m26872, I changed the baud rate on MyConfig.h and it started working.
                  • m26872M m26872
                    carlierdC
                    carlierdC
                    carlierd
                    @m26872 My nodes are working correctly for the moment. Actually one is at 2.8v. Perhaps I will have problem when voltage will be lower !
                    David.
                      David.
                      m26872M
                      m26872M
                      m26872
                      @carlierd Probably. That's why I ask what you use. DHT22 connected straight to 2AA will not utilize battery capacity. Higher battery voltage with step down regulator would be better - or maybe without, but with like 3AAs or so.
                        David.
                        ar91
                        @carlierd With Slim Node running at 1Mhz even with or without booster i am having hardtime making DHT22 work. I even tried different libraries but none of them works at 1Mhz. How did you get it work?
                        m26872M carlierdC 2 Replies Last reply
                        • A ar91
                          m26872M
                          m26872M
                          m26872
                          @ar91 I don't think there's a good reason to go below 8MHz if DHT22 doesn't work much below 3.3V ?
                          • m26872M m26872
                            carlierdC
                            carlierdC
                            carlierd
                            @m26872 Perhaps that with a caps I can go very low. I want to have at least one year on 2 AA. Wait and see !
                            • A ar91
                              carlierdC
                              carlierdC
                              carlierd
                              @ar91 Hello. I am using the arduino playground lib. No issue with it ! I can post a sketch if necessary.
                              David.
                                David.
                                ar91
                                @carlierd If you could share your code that will be great.
                                • A ar91
                                  carlierdC
                                  carlierdC
                                  carlierd
                                  @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
                                  /* Temperature, humidity and luminosity measurements.                                 */
                                  /* Version     : 1.1.6        */
                                  /* Date        : 10/01/2016                                                           */
                                  /* Modified by : David Carlier                                                        */
                                  /*                            RST |             |  A5                                 */
                                  /*                            RX  |             |  A4                                 */
                                  /*                            TX  |   ARDUINO   |  A3                                 */
                                  /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                                  /*            DHT22 --------- D3  |             |  A1                                 */
                                  /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
                                  /*              +3v --------- VCC |             | GND --------- GND                   */
                                  /*              GND --------- GND |  8MHz int.  | REF                                 */
                                  /*                            OSC |             | VCC --------- +3v                   */
                                  /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                                  /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                                  /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                                  /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                                  /*                            D8  |             |  D9                                 */
                                  /* Power = Vcc for LDR.                                                               */
                                  /* +3v = 2*AA        */
                                  #include <dht.h>
                                  #include <MyTransportRFM69.h>
                                  #define CHILD_ID_HUM 0
                                  #define CHILD_ID_TEMP 1
                                  #define CHILD_ID_LIGHT 2
                                  #define CHILD_ID_VOLTAGE 3
                                  #define POWER_PIN 4
                                  //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
                                  unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
                                  //Construct MySensors library
                                  MySigningAtsha204Soft signer;
                                  MyHwATMega328 hw;
                                  MyTransportRFM69 transport;
                                  MySensor gw(transport, hw, signer);
                                  dht DHT;
                                  MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
                                  MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                                  /* Initialization        */
                                    //Get time (for setup duration)
                                    #ifdef DEBUG
                                      unsigned long startTime = millis();
                                    //Start MySensors
                                    gw.begin();
                                    //Send the Sketch Version Information to the Gateway
                                    gw.sendSketchInfo("GHAS sensor", "1.1.5");
                                    //Register all sensors to gw (they will be created as child devices)
                                    gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                                    //Delay for DHT22
                                    delay(1500);
                                    //Print setup debug
                                    #ifdef DEBUG
                                      int duration = millis() - startTime;
                                      Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                                  /* Main loop        */
                                    //Get time (for a complete loop)
                                    #ifdef DEBUG
                                    //Power on
                                    powerOnPeripherals();
                                    //Get DHT22 data
                                    int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                                    switch (dht22Result)
                                      case DHTLIB_OK:
                                                  //Serial.println("OK,\t");
                                      case DHTLIB_ERROR_CHECKSUM:
                                                  #ifdef DEBUG
                                                    Serial.println("Checksum error,\t");
                                      case DHTLIB_ERROR_TIMEOUT:
                                                  #ifdef DEBUG
                                                    Serial.println("Time out error,\t");
                                      case DHTLIB_ERROR_CONNECT:
                                                  #ifdef DEBUG
                                                    Serial.println("Connect error,\t");
                                      case DHTLIB_ERROR_ACK_L:
                                                  #ifdef DEBUG
                                                    Serial.println("Ack Low error,\t");
                                      case DHTLIB_ERROR_ACK_H:
                                                  #ifdef DEBUG
                                                    Serial.println("Ack High error,\t");
                                      default:
                                                  #ifdef DEBUG
                                                    Serial.println("Unknown error,\t");
                                    //Get temperature and humidity
                                    float temperature = 0;
                                    float humidity = 0;
                                    if (dht22Result == DHTLIB_OK)
                                      temperature = DHT.temperature;
                                      humidity = DHT.humidity;
                                    //Get power before luminosity to use real voltage
                                    float realVoltage = getVoltage() / 100.0;
                                    int batteryPcnt = realVoltage * 100 / 3.0;
                                    if (batteryPcnt > 100) {batteryPcnt = 100;}
                                    int lux = computeIlluminance(realVoltage);
                                    //Power off
                                    powerOffPeripherals();
                                    //Send data to gateway
                                    gw.send(msgLum.set(lux));
                                    gw.send(msgVolt.set(realVoltage, 2));
                                    //Print debug
                                    #ifdef DEBUG
                                      Serial.print(temperature, 1);
                                      Serial.print(" degC");
                                      Serial.print("   ");
                                      Serial.print(humidity, 1);
                                      Serial.print(" %");
                                      Serial.print("   ");
                                      Serial.print(lux);
                                      Serial.print(" lx");
                                      Serial.print("   ");
                                      Serial.print(realVoltage);
                                      Serial.print(" v");
                                      Serial.print("   ");
                                      Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                                      Serial.flush();
                                    //Sleep
                                  /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
                                  int computeIlluminance(float realVoltage)
                                    //Get luminosity
                                    int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
                                    //Calculating the voltage in the input of the ADC
                                    double voltage = realVoltage * ((double)luminosity / 1024.0);
                                    //Calculating the resistance of the photoresistor in the voltage divider
                                    double resistance = (10.0 * realVoltage) / voltage - 10.0;
                                    //Calculating the intensity of light in lux and return it
                                    int illuminance = 255.84 * pow(resistance, -10/9);
                                    return illuminance;
                                  /* Allows to get the real Vcc (return value * 100).                                   */
                                  int getVoltage()
                                    const long InternalReferenceVoltage = 1056L;
                                    ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                                    delay(50);  // Let mux settle a little to get a more stable A/D conversion
                                    //Start a conversion
                                    ADCSRA |= _BV( ADSC );
                                    //Wait for it to complete
                                    while (((ADCSRA & (1<<ADSC)) != 0));
                                    //Scale the value
                                    int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                                    return result;
                                  /* Allows to power ON peripherals.                                                    */
                                  void powerOnPeripherals()
                                    //Power-up
                                    pinMode (POWER_PIN, OUTPUT);
                                    digitalWrite (POWER_PIN, HIGH);
                                    delay(1);
                                  /* Allows to power OFF peripherals.                                                   */
                                  void powerOffPeripherals()
                                    //Power off
                                    digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
                                    digitalWrite (POWER_PIN, LOW);
                                    pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
                                    pinMode (POWER_PIN, INPUT);
                                  Hope it helps !
                                  David.
                                  A siodS 3 Replies Last reply
                                    /*                            RST |             |  A5                                 */
                                    /*                            RX  |             |  A4                                 */
                                    /*                            D8  |             |  D9                                 */
                                    /* +3v = 2*AA        */
                                    #include <dht.h>
                                    #define POWER_PIN 4
                                    MyHwATMega328 hw;
                                    dht DHT;
                                      #ifdef DEBUG
                                      //Start MySensors
                                      gw.begin();
                                      //Delay for DHT22
                                      delay(1500);
                                      //Print setup debug
                                      #ifdef DEBUG
                                    /* Main loop        */
                                      #ifdef DEBUG
                                      //Power on
                                      //Get DHT22 data
                                        case DHTLIB_OK:
                                                    #ifdef DEBUG
                                                    #ifdef DEBUG
                                                    #ifdef DEBUG
                                                    #ifdef DEBUG
                                                    #ifdef DEBUG
                                        default:
                                                    #ifdef DEBUG
                                      float humidity = 0;
                                      //Power off
                                      //Print debug
                                      #ifdef DEBUG
                                        Serial.print("   ");
                                        Serial.print(" %");
                                        Serial.print("   ");
                                        Serial.print(lux);
                                        Serial.print("   ");
                                        Serial.print(" v");
                                        Serial.print("   ");
                                        Serial.flush();
                                      //Sleep
                                      //Get luminosity
                                      return illuminance;
                                    int getVoltage()
                                      //Scale the value
                                      return result;
                                      //Power-up
                                      delay(1);
                                      //Power off
                                    Hope it helps !
                                    David.
                                    ar91
                                    @carlierd Thank you very much. I really like your comment on the top :+1:
                                    • rsachocR
                                      rsachocR
                                      rsachoc
                                      Progress!
                                      http://imgur.com/zRvXvrN
                                      http://imgur.com/KpB7daz
                                      A question though. To get to this point, I copied the pictures posted above, but where do I now add these resistors?
                                      http://imgur.com/6mKJcgE
                                      Also, if I want to add a 2AA battery cage, where do I connect the red and black wires to?
                                      Thanks! And sorry for the newb questions!
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @rsachoc What you show are not resistors, they look like capacitors. 104 means 100nF (I think). Can you measure their value ?
                                          /*                            RST |             |  A5                                 */
                                          /*                            RX  |             |  A4                                 */
                                          /*                            D8  |             |  D9                                 */
                                          /* +3v = 2*AA        */
                                          #include <dht.h>
                                          #define POWER_PIN 4
                                          MyHwATMega328 hw;
                                          dht DHT;
                                            #ifdef DEBUG
                                            //Start MySensors
                                            gw.begin();
                                            //Delay for DHT22
                                            delay(1500);
                                            //Print setup debug
                                            #ifdef DEBUG
                                          /* Main loop        */
                                            #ifdef DEBUG
                                            //Power on
                                            //Get DHT22 data
                                              case DHTLIB_OK:
                                                          #ifdef DEBUG
                                                          #ifdef DEBUG
                                                          #ifdef DEBUG
                                                          #ifdef DEBUG
                                                          #ifdef DEBUG
                                              default:
                                                          #ifdef DEBUG
                                            float humidity = 0;
                                            //Power off
                                            //Print debug
                                            #ifdef DEBUG
                                              Serial.print("   ");
                                              Serial.print(" %");
                                              Serial.print("   ");
                                              Serial.print(lux);
                                              Serial.print("   ");
                                              Serial.print(" v");
                                              Serial.print("   ");
                                              Serial.flush();
                                            //Sleep
                                            //Get luminosity
                                            return illuminance;
                                          int getVoltage()
                                            //Scale the value
                                            return result;
                                            //Power-up
                                            delay(1);
                                            //Power off
                                          Hope it helps !
                                          David.
                                          ar91
                                          @carlierd Are you running your Atmega at 1Mhz, Because I tried to use your sketch and i am getting "Checksum Error".
