  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.1k Views 16 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @Anticimex made an effort :-) not sure this is sufficient.
    @jemish read the Description on OpenHardware.io I have tried to be complete.
    @gyro You can not update the node over the air. It is too simple for that (it lacks the proper boot loader and flash memory for that). But simple nodes have their uses too, I do love my minions :-) Have fun with the soldering !
    AnticimexA 1 Reply Last reply
    • GertSandersG GertSanders
      AnticimexA
      AnticimexA
      Anticimex
      @GertSanders To be really strict, you also need "Licensed under CERN OHL v.1.2” on your silk or visible copper layer as specified in the howto. Obviously that might be difficult on your board :) but that is what the howto says. But I will leave it to you to decide which license to use. If you don't really care, you can always choose to skip a license alltogether :)
      • sundberg84S
        sundberg84S
        This thred is getting off topic... but
        @Anticimex You have probably seen the FAQ for Cern, but there is a question about the Cern on silk.
        "So to summarise, adding the licence notice is not a requirement, but as licensor, it is one of the best ways to make it known that the hardware is Open (Source) Hardware since it may well get ‘separated’ from the Documentation in its life. The licensee does not have to add the notice on the silkscreen, however if the licensor has put it there, he may not remove it."
        • sundberg84S sundberg84
          AnticimexA
          AnticimexA
          Anticimex
          @sundberg84 Good point. I did not see that in the faq I read. But that's great news for those who already did tape-out.
          As for the changes.txt, I just do a git log > changes.txt to generate it from the git history.
          • sundberg84S
            sundberg84S
            Yes - like me :)
            • carlierdC
              carlierdC
              carlierd
              Very good job !!
              I saw that you provide a bootloader. What specificities ?
              Other (very selfish) question: next version of your not will be compatible with RFM69HW ?? ;)
              David.
              • GertSandersG
                GertSandersG
                GertSanders
                @carlierd The only specific thing about the boot loader is that it flashes the LED on pin D8 when starting up and it expects a transfer rate of 78600 when uploading sketches. Apart from that it is standard Optiboot 6.2 for operation at 8Mhz.
                I only have and use NRF24L01+, so RFM69HW is not in my plans or tests for the moment.
                Update: 15-FEB-2016
                The original boot loader was wrongly compiled for 4MHz, so when you try to upload at 38400, it will fail. Uploading the boot loader at 76800 when running at 8MHz will work, but timing in the sketches will be twice as short as expected.
                I replaced the original boot loader with a version compiled for 8MHz and upload speeds of 38400.
                I also added a second boot loader (for version v1-1) which is made for 8Mhz operation and upload speeds of 38400. This second boot loader flashes LED on pin D6.
                carlierdC 1 Reply Last reply
                  Update: 15-FEB-2016
                  carlierdC
                  carlierdC
                  carlierd
                  @GertSanders I will try to modify your design to replace the NRF with a RFM69. Thanks.
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    Updated the design files with version 1-1. Explanation of what this version does will follow later (not that much more, but I2C extension is now an option).
                      meddie
                      Very nice! It would be perfect if it would get an atsha204a and a flash module.
                      Greets Eddie
                      • M meddie
                        Greets Eddie
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @meddie not sure that would even fit on the board, have you seen the size?
                          meddie
                          @GertSanders
                          the PCB must be a little bit longer. But the two chips are not big. The ATSHA201A is very small its a 3 PIN smd chip, and the flash chip is 8 pin.
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            @meddie I try to stay within the 50mm length limit, so that we can have the boards produced in a 50x50 format. Making it longer means we need to go to a 100x100mm format, and that makes it more costly (not necessarily per board, but some people do not need +50 sensor boards).
                            At the moment we get 5 of these nodes within the 50x50mm limit, so a prototype run already produces 50 boards.
                            Anyway, I'm not exscluding this idea, I just do not have a need for it now. The minimal node is meant to be minimal, not a complete MySensors node. If you need that, there is always the Sensebender Micro (which has it all built in).
                            • Carl HC
                              Carl HC
                              Carl H
                              @GertSanders I'm a fan of your boards. I have your 20x30mm board, AC/Capable 50x50mm board (my favorite) and now I ordered your v1.1 of your narrow board because you are agree my suggestion for I2C port with jumper ;)
                              • Carl HC
                                Carl HC
                                Carl H
                                wrote on last edited by Carl H
                                @GertSanders , 1 question, you have specified 1/8w resistor... did you know if 1/4w fit on narrow board ?
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @Carl H If the 1/4w resistor can fit in pads 7mm apart from each other, then should be no problem. But they need to stay flat to fit under the processor.
                                  • J
                                    J
                                    jacikaas
                                    Hello, @GertSanders I would like to ask. How I understand it is possible to load different sketch type to this board and then I could use it like one of MySensors sketches? For example could I load MyS humidity sketch? Thanks!
                                    • J jacikaas
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @jacikaas: to program the processor, you need to remove it from the board and program it on a breadboard or another board with ftdi interface.
                                      But you can load a sketch like the humidity sensor sketch if you add a I2C sensor like a SI7021. I plan to do just that.
                                      • GertSandersG
                                        GertSandersG
                                        GertSanders
                                        #24
                                        The very narrow boards v1-1 have arrived :-)
                                        • GertSandersG
                                          GertSandersG
                                          GertSanders
                                          The latest member of my growing sensor family, a reedswitch sensor with wakeup from power down by change on pin 2, wakeup every 23 hours to report battery voltage, and of course a blinky light when these things happen :-)
                                          Just tested and found to be OK. Next board will be set up for using a I2C module (will be my smallest temperature sensor yet). Time for a glas of WestVleeteren and rest.
                                          alexsh1A 1 Reply Last reply
