  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.8k Views 16 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    @carlierd The only specific thing about the boot loader is that it flashes the LED on pin D8 when starting up and it expects a transfer rate of 78600 when uploading sketches. Apart from that it is standard Optiboot 6.2 for operation at 8Mhz.
    I only have and use NRF24L01+, so RFM69HW is not in my plans or tests for the moment.
    Update: 15-FEB-2016
    The original boot loader was wrongly compiled for 4MHz, so when you try to upload at 38400, it will fail. Uploading the boot loader at 76800 when running at 8MHz will work, but timing in the sketches will be twice as short as expected.
    I replaced the original boot loader with a version compiled for 8MHz and upload speeds of 38400.
    I also added a second boot loader (for version v1-1) which is made for 8Mhz operation and upload speeds of 38400. This second boot loader flashes LED on pin D6.
    carlierdC 1 Reply Last reply
    • GertSandersG GertSanders
      Update: 15-FEB-2016
      carlierdC
      carlierdC
      carlierd
      @GertSanders I will try to modify your design to replace the NRF with a RFM69. Thanks.
      • GertSandersG
        GertSandersG
        GertSanders
        Updated the design files with version 1-1. Explanation of what this version does will follow later (not that much more, but I2C extension is now an option).
          meddie
          Very nice! It would be perfect if it would get an atsha204a and a flash module.
          Greets Eddie
          • M meddie
            Greets Eddie
            GertSandersG
            GertSandersG
            GertSanders
            @meddie not sure that would even fit on the board, have you seen the size?
              meddie
              @GertSanders
              the PCB must be a little bit longer. But the two chips are not big. The ATSHA201A is very small its a 3 PIN smd chip, and the flash chip is 8 pin.
              • GertSandersG
                GertSandersG
                GertSanders
                @meddie I try to stay within the 50mm length limit, so that we can have the boards produced in a 50x50 format. Making it longer means we need to go to a 100x100mm format, and that makes it more costly (not necessarily per board, but some people do not need +50 sensor boards).
                At the moment we get 5 of these nodes within the 50x50mm limit, so a prototype run already produces 50 boards.
                Anyway, I'm not exscluding this idea, I just do not have a need for it now. The minimal node is meant to be minimal, not a complete MySensors node. If you need that, there is always the Sensebender Micro (which has it all built in).
                • Carl HC
                  Carl HC
                  Carl H
                  @GertSanders I'm a fan of your boards. I have your 20x30mm board, AC/Capable 50x50mm board (my favorite) and now I ordered your v1.1 of your narrow board because you are agree my suggestion for I2C port with jumper ;)
                  • Carl HC
                    Carl HC
                    Carl H
                    wrote on last edited by Carl H
                    @GertSanders , 1 question, you have specified 1/8w resistor... did you know if 1/4w fit on narrow board ?
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      @Carl H If the 1/4w resistor can fit in pads 7mm apart from each other, then should be no problem. But they need to stay flat to fit under the processor.
                      • J
                        J
                        jacikaas
                        Hello, @GertSanders I would like to ask. How I understand it is possible to load different sketch type to this board and then I could use it like one of MySensors sketches? For example could I load MyS humidity sketch? Thanks!
                        • J jacikaas
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @jacikaas: to program the processor, you need to remove it from the board and program it on a breadboard or another board with ftdi interface.
                          But you can load a sketch like the humidity sensor sketch if you add a I2C sensor like a SI7021. I plan to do just that.
                          • GertSandersG
                            GertSandersG
                            GertSanders
                            #24
                            The very narrow boards v1-1 have arrived :-)
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              The latest member of my growing sensor family, a reedswitch sensor with wakeup from power down by change on pin 2, wakeup every 23 hours to report battery voltage, and of course a blinky light when these things happen :-)
                              Just tested and found to be OK. Next board will be set up for using a I2C module (will be my smallest temperature sensor yet). Time for a glas of WestVleeteren and rest.
                              alexsh1A 1 Reply Last reply
                              • carlierdC
                                carlierdC
                                carlierd
                                Very nice !!
                                I just started learning Eagles to modify your board for RFM69 compatibility. The road will be long ;)
                                Could be good also to add ATSHA204A but in a second time !
                                David.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @GertSanders
                                  Westvleteren Blonde is very nice :)
                                  Can you please remind me the difference berwrrn v1 and 1-1?
                                  I think it would be good to add FTDI connection, but the space is very limited
                                  GertSandersG 2 Replies Last reply
                                  • alexsh1A alexsh1
                                    @GertSanders
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    #28
                                    @alexsh1 FTDI would be nice to reprogram more easily, but in my case I have a stable sketch which is loaded 1 time, and then the node is deployed. No point in providing extra pins or using boardspace if it is only used once or twice.
                                    I saw that @AWI mentioned pogo-pins to make connections. Also a nice idea. In any case, my node is not designed to be flexible, and after programming I want to forget it. These nodes are sitting on doors and windows and need to do 1 thing only: show status of the reed-switched that are connected to them.
                                    But adding some pads so that pogo pins can make contact to RX, TX and !RESET would still be possible.
                                    It will be nice to see if a RFM69 radio can be connected by @carlierd . Looking forward to some pictures :-)
                                    AWIA 1 Reply Last reply
                                    • alexsh1A alexsh1
                                      @GertSanders
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      #29
                                      @alexsh1
                                      The difference between v1-0 and V1-1:
                                      V1-0:
                                      has 4 pins connected to VCC, GND, D2, D3 (in this sequence).
                                      LED is connected to D8
                                      V1-1:
                                      has 4 pins, of which 2 are fixed. Vcc and GND are at the outside (closest to board edge).
                                      The two pins in the middle (pin1 and pin2) can be connected to two different pins each by using the solder jumper.
                                      pin1 can be connected to SDA/A4 or to D2
                                      pin2 can be connected to SCL/A5 or to GND
                                      LED is connected to D6
                                        AWIA
                                        AWIA
                                        AWI
                                        @GertSanders A bit off a hassle, but I don't need pads... ;-)
                                        0_1457102582398_upload-7fc04aa0-f360-48dd-b170-601e208392ee
                                        • AWIA AWI
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @AWI very nice, where did you buy the pins ?
