  3. 💬 Very narrow and minimal switch node
mysensorsbinary switchesi2cnrf24l01
66 Posts 19 Posters 34.8k Views 16 Watching
  • J
    J
    jacikaas
    Hello, @GertSanders I would like to ask. How I understand it is possible to load different sketch type to this board and then I could use it like one of MySensors sketches? For example could I load MyS humidity sketch? Thanks!
    • J jacikaas
      GertSandersG
      GertSandersG
      GertSanders
      @jacikaas: to program the processor, you need to remove it from the board and program it on a breadboard or another board with ftdi interface.
      But you can load a sketch like the humidity sensor sketch if you add a I2C sensor like a SI7021. I plan to do just that.
      • GertSandersG
        GertSandersG
        GertSanders
        #24
        The very narrow boards v1-1 have arrived :-)
        • GertSandersG
          GertSandersG
          GertSanders
          The latest member of my growing sensor family, a reedswitch sensor with wakeup from power down by change on pin 2, wakeup every 23 hours to report battery voltage, and of course a blinky light when these things happen :-)
          Just tested and found to be OK. Next board will be set up for using a I2C module (will be my smallest temperature sensor yet). Time for a glas of WestVleeteren and rest.
          alexsh1A 1 Reply Last reply
          • carlierdC
            carlierdC
            carlierd
            Very nice !!
            I just started learning Eagles to modify your board for RFM69 compatibility. The road will be long ;)
            Could be good also to add ATSHA204A but in a second time !
            David.
            • GertSandersG GertSanders
              alexsh1A
              alexsh1A
              alexsh1
              @GertSanders
              Westvleteren Blonde is very nice :)
              Can you please remind me the difference berwrrn v1 and 1-1?
              I think it would be good to add FTDI connection, but the space is very limited
              GertSandersG 2 Replies Last reply
              • alexsh1A alexsh1
                @GertSanders
                GertSandersG
                GertSandersG
                GertSanders
                #28
                @alexsh1 FTDI would be nice to reprogram more easily, but in my case I have a stable sketch which is loaded 1 time, and then the node is deployed. No point in providing extra pins or using boardspace if it is only used once or twice.
                I saw that @AWI mentioned pogo-pins to make connections. Also a nice idea. In any case, my node is not designed to be flexible, and after programming I want to forget it. These nodes are sitting on doors and windows and need to do 1 thing only: show status of the reed-switched that are connected to them.
                But adding some pads so that pogo pins can make contact to RX, TX and !RESET would still be possible.
                It will be nice to see if a RFM69 radio can be connected by @carlierd . Looking forward to some pictures :-)
                AWIA 1 Reply Last reply
                • alexsh1A alexsh1
                  @GertSanders
                  GertSandersG
                  GertSandersG
                  GertSanders
                  #29
                  @alexsh1
                  The difference between v1-0 and V1-1:
                  V1-0:
                  has 4 pins connected to VCC, GND, D2, D3 (in this sequence).
                  LED is connected to D8
                  V1-1:
                  has 4 pins, of which 2 are fixed. Vcc and GND are at the outside (closest to board edge).
                  The two pins in the middle (pin1 and pin2) can be connected to two different pins each by using the solder jumper.
                  pin1 can be connected to SDA/A4 or to D2
                  pin2 can be connected to SCL/A5 or to GND
                  LED is connected to D6
                    AWIA
                    AWIA
                    AWI
                    @GertSanders A bit off a hassle, but I don't need pads... ;-)
                    0_1457102582398_upload-7fc04aa0-f360-48dd-b170-601e208392ee
                    • AWIA AWI
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @AWI very nice, where did you buy the pins ?
                        AWIA
                        AWIA
                        AWI
                        @GertSanders I used these pins. These work for me but there are many other types in the same store which could serve your needs better.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @GertSanders - my idea to use exactly for windows. I was thinking about z-wave ones, but £32 a pot is just way too expensive given I need quite a few. How do you power them?
                          • alexsh1A alexsh1
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @alexsh1 I power them similar to @m26872 , but with AAA batteries. They fit the 16x16mm cable guide by Legrand (which is a known brand for this in Belgium), available is most DIY stores.
                            • Dombo71D
                              Dombo71D
                              Dombo71
                              Dear
                              I ordered a few...:-)
                              Do you have a working sketch that is using less power?
                              Perhaps wit a motionsensor and a DHt ore something
                              I hope i get you hardware working..
                              alexsh1A GertSandersG 3 Replies Last reply
                              • Dombo71D Dombo71
                                Dear
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Dombo71 said:
                                Dear
                                @Dombo71
                                You can find a few working sketches in the 'Build' section of the website. However, don't you have an idea what it is exactly you'd like to build? I would be useful to know before throwing any sketch.
                                FYG DHT is by far not a favourite one for a battery use in my view. There are others - SI7120 or BME280
                                • Dombo71D Dombo71
                                  Dear
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @Dombo71
                                  What do you mean with "using less power"?
                                  D 1 Reply Last reply
                                  • Dombo71D Dombo71
                                    Dear
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @Dombo71
                                    Motion sensors are also not so low power and as mentioned before, DHT are power hungry. SI7021 is much better for low power/low voltage use.
                                      @Dombo71
                                      Dylano
                                      @GertSanders said:
                                      SI7021
                                      I hope i can make a 3 in 1 sensor
                                      Motion / contact.
                                      temp and humanity
                                      Better should be a multisensor, with a lot of option so we can choose .
                                      The examples on my sensor are most 1 sensor...
                                      And then work on a battery[s] for a year
                                      Thanks for the SI7021 tip..
                                      Domoticz, with a lot of working hardware, include mysensors :-)
                                      OpenPLI, RuneAudio, Solarmeter, etc......
                                      Not a great builder of software and hardware, more a user...
                                      Only i try to do my best :-(
                                      • D Dylano
                                        @GertSanders said:
                                        SI7021
                                        Motion / contact.
                                        temp and humanity
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        #40
                                        @Dylano
                                        This board is not meant for more then 1 function.
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Dylano Have a look at this board - this would let you program via FTDI and connect several sensors.
                                          http://forum.mysensors.org/topic/2744/battery-based-atmega328p-sensor-no-smd
