  3. Gateway serial port commands in one message. How can the recive and send it?
10 Posts 3 Posters 3.0k Views 4 Watching
  • Marat KhM Offline
    Marat KhM Offline
    Marat Kh
    Hi!
    I need to send 16 commands from gateway to nodes.
    When i send in com port Gateway command like:
    ->1;2;1;0;2;1\n1;11;1;0;2;1\n1;1;1;0;2;0\n1;2;1;0;2;0\n1;14;1;0;2;0\n1;16;1;0;2;1\n
    the gateway recive only first command in line 1;2;1;0;2;1\n
    i think becouse:
    examples/SerialGateway/SerialGateway.ino
    void serialEvent() {
    while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
    if (inChar == '\n') {
    inputString[inputPos] = 0;
    commandComplete = true;
    // add it to the inputString:
    inputString[inputPos] = inChar;
    inputPos++;
    inputPos = 0;
    But after this, the gate send command to node by NRF24 module.
    How can i recive and send multiple commands in one message?
    THNX!
    • hekH Offline
      hekH Offline
      It's a newline character you're sending between the commands right? Not the string"\n"
      Marat KhM 1 Reply Last reply
      • Marat KhM Offline
        Marat KhM Offline
        Marat Kh
        This is \n
        _serialPort.WriteLine(GateCommand);
        string command = "" + nodename + ";" + neonnumber + ";1;0;2;" + powerstatus;
        // NODE_NAME, NUMBER_NEON, 1(set), 0 - без доставки, 2 - V_STATUS, VALUE (1- on, 2 - off);
        return command;
          Marat KhM Offline
          Marat KhM Offline
          Marat Kh
          @hek This is \n i think in the logger look like
          ->1;11;1;0;2;1#0A1;10;1;0;2;1#0A1;9;1;0;2;1#0A1;8;1;0;2;1#0A1;7;1;0;2;1#0A1;6;1;0;2;1#0A1;5;1;0;2;1#0A1;4;1;0;2;1#0A
          I don't khew why C# code sent multiple command in 1 line,
          i wrote once commande:
          GateCommand - It one command lke 1;16;1;0;2;1\n
          Bit in one tread in one time moment
          • hekH Offline
            hekH Offline
            Hmm.. it should probably be a
            return;
            after
            Thanks for reporting. I see we have the same issue in the development branch.
            • hekH Offline
              hekH Offline
              https://github.com/mysensors/Arduino/pull/400
                Marat KhM Offline
                Marat KhM Offline
                Marat Kh
                @hek Thnx.
                But can you explane how can i use this now in my code (from example):
                  checkInclusionFinished();
                  if (commandComplete) {
                    // A command wass issued from serial interface
                    // We will now try to send it to the actuator
                    parseAndSend(gw, inputString);
                    commandComplete = false;
                    inputPos = 0;
                  SerialEvent occurs whenever a new data comes in the
                 hardware serial RX.  This routine is run between each
                 time loop() runs, so using delay inside loop can delay
                 response.  Multiple bytes of data may be available.
                        inputPos++;
                        inputPos = 0;
                I mean function serialEvent in one package can see only first command, from 0 possition to \n.
                Thnx so much
                • hekH Offline
                  hekH Offline
                  I wrote exactly how you should change it above.
                    Marat KhM Offline
                    Marat KhM Offline
                    Marat Kh
                    @hek
                    Ok! Thnx so much!!!
                    • R Offline
                      R Offline
                      robosensor
                      @hek, I suspect that there is something wrong with this pull request. If you just returning true, then protocolParse() will not be called and gatewayTransportReceive() function in MyGatewayTransport.cpp will receive previously parsed message.
                      11.8k
                      113.2k
