  3. [Tutorial] How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5
86 Posts 20 Posters 119.7k Views 28 Watching
  • D drock1985
    Awesome @LastSamurai thanks.
    One other question: Is it possible to just use a standard USB to FTDI converter to flash the sketch? Ex: flash bootloader using an Uno, then install in a SlimNode and use the FTDI connector there to flash?
    L
    L
    LastSamurai
    @drock1985 Yes once it has a bootloader that should be possible (you need to use the right settings though ;) )
    D 1 Reply Last reply
    • L LastSamurai
      drock1985
      @LastSamurai
      What settings would those be? Would they be things outside of the tutorial?
      Sorry to ask so many questions. Never flashed an Arduino before outside of connecting a USB cable to an Uno or Nano
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      L 1 Reply Last reply
      • D drock1985
        @LastSamurai
        L
        L
        LastSamurai
        @drock1985 Mainly the baudrate but if you just burn the standard e.g. Arduino Uno bootloader and then use the IDE with the Uno settings everything should work fine. If you encounter errors you can still check your settings ;) They are in the boards.txt file of the IDE.
        Just try it though, it really isn't that hard ;)
        • siodS
          siodS
          siod
          very good work instruction, thank you !! :thumbsup:
          still learning...
          • rsachocR
            rsachocR
            rsachoc
            Hi there, and thanks for the tutorial. I'm trying this for the first time (the ATmega is going to be used in a slim temp node), and I'm receiving this message you mentioned:
            avrdude: Yikes! Invalid device signature.
            You mention we should try the following:
            Maybe your chip is configured to run on an external crystal clock. I tested with two values and it succeeded. I used 10Mhz and 20Mhz as I didn't have 16 Mhz.
            Connect the crystal to pin 9 and 10
            Note: You won't need the crystal except for the first time as the new bootloader is configured to run on internal 1Mhz or 8Mhz.
            I don't quite follow what this means? Do I need a 10mhz, 16mhz or 20mhz crystal attached to the breadboard like you show in the video? If so, is that the only change I would need to make?
            FYI I'm using an Arduino clone (Buono uno r3, set at 5V)
            • rsachocR rsachoc
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @rsachoc Maybe I need to rephrase the sentence :)
              I meant that any crystal value will work. I didn't have 16Mhz, but I had the values 10Mhz and 20 Mhz. So I tested with 10 Mhz and I bypassed the error and didn't come again. I wanted to know further whether the crystal value is important or not. So I got another chip with preloaded arduino bootloader, and tested with 20Mhz. Also I succeeded. Thus I assume that you can use any value for this step .
              I am also using Uno clone and this is the only thing I did regarding this issue. I didn't even add capacitors to the crystal. Just put any value and test.
              rsachocR 1 Reply Last reply
                rsachocR
                rsachocR
                rsachoc
                @ahmedadelhosni thanks! I'm going to grab a 10mhz and 16mhz to test later this evening. Just to confirm from what you've said, I don't need the capacitors? I know in the youtube vid there were capacitors used?
                ahmedadelhosniA 2 Replies Last reply
                • rsachocR rsachoc
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @rsachoc yes. I didn't also have caps and it worked :)
                  • rsachocR rsachoc
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    wrote on last edited by ahmedadelhosni
                    #24
                    @rsachoc ofcourse if you have 16Mhz and capacitors like the reference video, that would be great. but if you were in a hurry and lazy to buy some, so just do it like so.
                    Edit: 16* Mhz not 10 Mhz
                      rsachocR
                      rsachocR
                      rsachoc
                      @ahmedadelhosni I have some capacitors, but no crystals, so I'm picking a 10mhz and 16mhz up later today. I'll try with just the capacitors first and see how I go.
                      • rsachocR rsachoc
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @rsachoc edit: sorry I meant 16. Like the normal arduino board
                        • rsachocR
                          rsachocR
                          rsachoc
                          wrote on last edited by rsachoc
                          #27
                          C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
                                   System wide configuration file is "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf"
                                   Using Port                    : COM5
                                   Programmer Type : STK500
                                   Hardware Version: 2
                                   Firmware Version: 1.18
                                   Topcard         : Unknown
                                   Vtarget         : 0.0 V
                                   Varef           : 0.0 V
                                   Oscillator      : Off
                                   SCK period      : 0.1 us
                          avrdude: erasing chip
                          C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
                          avrdude: verifying ...
                          avrdude: reading input file "0x05"
                          avrdude: verifying efuse memory against 0x05:
                          avrdude: load data efuse data from input file 0x05:
                          avrdude: input file 0x05 contains 1 bytes
                          avrdude: reading input file "0xDE"
                          avrdude: verifying hfuse memory against 0xDE:
                          avrdude: load data hfuse data from input file 0xDE:
                          avrdude: input file 0xDE contains 1 bytes
                          avrdude: verifying lfuse memory against 0xFF:
                          avrdude: load data lfuse data from input file 0xFF:
                          avrdude done.  Thank you.
                                   Using Port                    : COM5
                                   Hardware Version: 2
                                   Topcard         : Unknown
                                   Vtarget         : 0.0 V
                                   Varef           : 0.0 V
                                   Oscillator      : Off
                                   SCK period      : 0.1 us
                          avrdude: reading input file "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex"
                          avrdude: writing flash (32768 bytes):
                          avrdude: 32768 bytes of flash written
                          avrdude: verifying flash memory against C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                          avrdude: load data flash data from input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                          avrdude: input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
                          avrdude: 32768 bytes of flash verified
                          avrdude: reading input file "0x0F"
                          Writing | ################################################## | 100% 0.02s
                          avrdude: verifying lock memory against 0x0F:
                          avrdude: load data lock data from input file 0x0F:
                          avrdude: input file 0x0F contains 1 bytes
                          Did I burn the bootloader successfully? The video indicates it should take longer, this literally took less than a second?
                          • rsachocR rsachoc
                                     Using Port                    : COM5
                                     Hardware Version: 2
                                     Topcard         : Unknown
                                     Vtarget         : 0.0 V
                                     Varef           : 0.0 V
                                     Oscillator      : Off
                                     SCK period      : 0.1 us
                                     Using Port                    : COM5
                                     Hardware Version: 2
                                     Topcard         : Unknown
                                     Vtarget         : 0.0 V
                                     Varef           : 0.0 V
                                     Oscillator      : Off
                                     SCK period      : 0.1 us
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            @rsachoc I haven't burned a bootloader since I have did this topic, but I do remember that it took like 2 seconds. It was really fast.
                            You can try flashing the code to verify that it works well.
                              rsachocR
                              rsachocR
                              rsachoc
                              @ahmedadelhosni good idea, I hadn't thought of that. I'm going to have to build a slim temp node first, as my current chip is soldered to the board with no bootloader.
                              • L
                                L
                                LastSamurai
                                Hey guys, I have been building my own sensor nodes that should consume as little power as needed, so I burned a 1MHz bootloader with lower BOD settings which I found in the "slime 2AA battery node" thread (I guess this here is the same one).
                                I had some problem with the node afterwards, which I fixed by setting the baudrate of the mysensors library to 9600. It seems like that is needed (too), beside settings the upload speeds. Can you guys confirm that? If so I would suggest adding that to the (great) manual!
                                rsachocR ahmedadelhosniA 2 Replies Last reply
                                • L LastSamurai
                                  rsachocR
                                  rsachocR
                                  rsachoc
                                  #31
                                  @LastSamurai I've been advised that setting the baud rate in myconfig.h is the correct way to get things working when uploading sketches to the slim node. Don't think it matters when burining the bootloader though.
                                  • L LastSamurai
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @LastSamurai I have faced this problem a couple of times but I don't remember how do I solve it. I just keep trying different solution. But I have to say thay I am using development branch and I don't redefine the baud rate if I don't wan't the serial debug.
                                    • siodS
                                      siodS
                                      siod
                                      wrote on last edited by siod
                                      #33
                                      thx for the tutorial. I perfomred every step you described, but I get errors when trying to upload a sketch:
                                      And I also get this error message:
                                      I tried to upload the 1MHz version
                                      edit:
                                      some more info form verbose mode output:
                                      edit2:
                                      Another problem: I could burn the bootloader on to one of my ATMega328 MCU´s but I needed to use a 16MHz Crystal when uploading for the first time. Now I can just burn and burn the bootloader again. Here ist the output:
                                      But it is the only MCU that works, all the other give the "Yikes" error, also when 16MHz Crystal is connected:
                                      Any explanation?
                                      - bootloader burning problem solved by rebuilding the wiring.
                                      - for some reason I could upload the sketch now, don´t ask me why. In the end I just reuploaded again and again...I hope I will be able to upload sketches to the next MCU´s as well
                                      Sorry for asking so many questions, but after spending hours and hours of setting up a raspberry pi with openhab, MQTT Broker and MQTT Gateway I am so close to finishing my first standalone sensor and it´s not going any further, I could cry :cry:
                                      still learning...
                                      • D
                                        drock1985
                                        Maybe someone in here can help me. I can't seem to compile any sketches on my Arduino IDE and keep getting errors spit at me. I can burn the bootloader with no problem but not any sketches. Any advice/ideas please? I'm running out of things to try. :(
                                        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\derri\AppData\Local\Arduino15\packages" -hardware "F:\Users.New\Derrick\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\derri\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "F:\Users.New\Derrick\Documents\Arduino\libraries" -fqbn=MySensors:avr:apm96 -ide-version=10608 -build-path "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\derri\AppData\Local\Temp\untitled808982838.tmp\sketch_apr18a\sketch_apr18a.ino"
                                        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\derri\AppData\Local\Arduino15\packages" -hardware "F:\Users.New\Derrick\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\derri\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "F:\Users.New\Derrick\Documents\Arduino\libraries" -fqbn=MySensors:avr:apm96 -ide-version=10608 -build-path "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\derri\AppData\Local\Temp\untitled808982838.tmp\sketch_apr18a\sketch_apr18a.ino"
                                        Board MySensors:avr:apm96 doesn't define a 'build.board' preference. Auto-set to: AVR_APM96
                                        Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++"  -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -DF_CPU=1000000L -DARDUINO=10608 -DARDUINO_AVR_APM96 -DARDUINO_ARCH_AVR         "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\cores\arduino" "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\variants\standard" "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp" -o "nul"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++"  -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -DF_CPU=1000000L -DARDUINO=10608 -DARDUINO_AVR_APM96 -DARDUINO_ARCH_AVR         "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\cores\arduino" "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\variants\standard" "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp" -o "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                        C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp:1:21: fatal error: Arduino.h: No such file or directory
                                         #include <Arduino.h>
                                        compilation terminated.
                                        exit status 1
                                        Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
                                        My Projects
                                        2 Door Chime Sensor
                                        • sundberg84S
                                          sundberg84S
                                          @drock1985 - please dont crosspost, see forum guidelines.
