  3. [Tutorial] How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5
86 Posts 20 Posters 119.6k Views 28 Watching
  • D
    drock1985
    hi @ahmedadelhosni
    Thank you for the tutorial. Quick question: Is it possible to just take the Atmega 328 chip with the freshly flashed bootloader, and just stick in in the Arduino Uno to program a sketch?
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    L 1 Reply Last reply
    • D drock1985
      hi @ahmedadelhosni
      L
      L
      LastSamurai
      @drock1985 I think I have done just that. It only needs to have a bootloader (you could just flash one there though).
      • F
        F
        flopp
        I have successfully burned a new bootloader to a pro mini clone, now I can run it down to 1,8V(I think) tried 2,6V and it still works
        Thanks for a great tut
        • D
          drock1985
          Awesome @LastSamurai thanks.
          One other question: Is it possible to just use a standard USB to FTDI converter to flash the sketch? Ex: flash bootloader using an Uno, then install in a SlimNode and use the FTDI connector there to flash?
          My Projects
          2 Door Chime Sensor
          • D drock1985
            L
            L
            LastSamurai
            @drock1985 Yes once it has a bootloader that should be possible (you need to use the right settings though ;) )
            D 1 Reply Last reply
            • L LastSamurai
              drock1985
              @LastSamurai
              What settings would those be? Would they be things outside of the tutorial?
              Sorry to ask so many questions. Never flashed an Arduino before outside of connecting a USB cable to an Uno or Nano
              My Projects
              2 Door Chime Sensor
              • D drock1985
                @LastSamurai
                L
                L
                LastSamurai
                @drock1985 Mainly the baudrate but if you just burn the standard e.g. Arduino Uno bootloader and then use the IDE with the Uno settings everything should work fine. If you encounter errors you can still check your settings ;) They are in the boards.txt file of the IDE.
                Just try it though, it really isn't that hard ;)
                • siodS
                  siodS
                  siod
                  very good work instruction, thank you !! :thumbsup:
                  still learning...
                  • rsachocR
                    rsachocR
                    rsachoc
                    Hi there, and thanks for the tutorial. I'm trying this for the first time (the ATmega is going to be used in a slim temp node), and I'm receiving this message you mentioned:
                    avrdude: Yikes! Invalid device signature.
                    You mention we should try the following:
                    Maybe your chip is configured to run on an external crystal clock. I tested with two values and it succeeded. I used 10Mhz and 20Mhz as I didn't have 16 Mhz.
                    Connect the crystal to pin 9 and 10
                    Note: You won't need the crystal except for the first time as the new bootloader is configured to run on internal 1Mhz or 8Mhz.
                    I don't quite follow what this means? Do I need a 10mhz, 16mhz or 20mhz crystal attached to the breadboard like you show in the video? If so, is that the only change I would need to make?
                    FYI I'm using an Arduino clone (Buono uno r3, set at 5V)
                    • rsachocR rsachoc
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      @rsachoc Maybe I need to rephrase the sentence :)
                      I meant that any crystal value will work. I didn't have 16Mhz, but I had the values 10Mhz and 20 Mhz. So I tested with 10 Mhz and I bypassed the error and didn't come again. I wanted to know further whether the crystal value is important or not. So I got another chip with preloaded arduino bootloader, and tested with 20Mhz. Also I succeeded. Thus I assume that you can use any value for this step .
                      I am also using Uno clone and this is the only thing I did regarding this issue. I didn't even add capacitors to the crystal. Just put any value and test.
                      rsachocR 1 Reply Last reply
                        rsachocR
                        rsachocR
                        rsachoc
                        @ahmedadelhosni thanks! I'm going to grab a 10mhz and 16mhz to test later this evening. Just to confirm from what you've said, I don't need the capacitors? I know in the youtube vid there were capacitors used?
                        ahmedadelhosniA 2 Replies Last reply
                        • rsachocR rsachoc
                          ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          @rsachoc yes. I didn't also have caps and it worked :)
                          • rsachocR rsachoc
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            wrote on last edited by ahmedadelhosni
                            #24
                            @rsachoc ofcourse if you have 16Mhz and capacitors like the reference video, that would be great. but if you were in a hurry and lazy to buy some, so just do it like so.
                            Edit: 16* Mhz not 10 Mhz
                              rsachocR
                              rsachocR
                              rsachoc
                              @ahmedadelhosni I have some capacitors, but no crystals, so I'm picking a 10mhz and 16mhz up later today. I'll try with just the capacitors first and see how I go.
                              • rsachocR rsachoc
                                ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                @rsachoc edit: sorry I meant 16. Like the normal arduino board
                                • rsachocR
                                  rsachocR
                                  rsachoc
                                  wrote on last edited by rsachoc
                                  #27
                                  C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
                                           System wide configuration file is "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf"
                                           Using Port                    : COM5
                                           Programmer Type : STK500
                                           Hardware Version: 2
                                           Firmware Version: 1.18
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  avrdude: erasing chip
                                  C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
                                  avrdude: verifying ...
                                  avrdude: reading input file "0x05"
                                  avrdude: verifying efuse memory against 0x05:
                                  avrdude: load data efuse data from input file 0x05:
                                  avrdude: input file 0x05 contains 1 bytes
                                  avrdude: reading input file "0xDE"
                                  avrdude: verifying hfuse memory against 0xDE:
                                  avrdude: load data hfuse data from input file 0xDE:
                                  avrdude: input file 0xDE contains 1 bytes
                                  avrdude: verifying lfuse memory against 0xFF:
                                  avrdude: load data lfuse data from input file 0xFF:
                                  avrdude done.  Thank you.
                                           Using Port                    : COM5
                                           Hardware Version: 2
                                           Topcard         : Unknown
                                           Vtarget         : 0.0 V
                                           Varef           : 0.0 V
                                           Oscillator      : Off
                                           SCK period      : 0.1 us
                                  avrdude: reading input file "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex"
                                  avrdude: writing flash (32768 bytes):
                                  avrdude: 32768 bytes of flash written
                                  avrdude: verifying flash memory against C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                                  avrdude: load data flash data from input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                                  avrdude: input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
                                  avrdude: 32768 bytes of flash verified
                                  avrdude: reading input file "0x0F"
                                  Writing | ################################################## | 100% 0.02s
                                  avrdude: verifying lock memory against 0x0F:
                                  avrdude: load data lock data from input file 0x0F:
                                  avrdude: input file 0x0F contains 1 bytes
                                  Did I burn the bootloader successfully? The video indicates it should take longer, this literally took less than a second?
                                  • rsachocR rsachoc
                                             Using Port                    : COM5
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                             Using Port                    : COM5
                                             Hardware Version: 2
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @rsachoc I haven't burned a bootloader since I have did this topic, but I do remember that it took like 2 seconds. It was really fast.
                                    You can try flashing the code to verify that it works well.
                                      rsachocR
                                      rsachocR
                                      rsachoc
                                      @ahmedadelhosni good idea, I hadn't thought of that. I'm going to have to build a slim temp node first, as my current chip is soldered to the board with no bootloader.
                                      • L
                                        L
                                        LastSamurai
                                        Hey guys, I have been building my own sensor nodes that should consume as little power as needed, so I burned a 1MHz bootloader with lower BOD settings which I found in the "slime 2AA battery node" thread (I guess this here is the same one).
                                        I had some problem with the node afterwards, which I fixed by setting the baudrate of the mysensors library to 9600. It seems like that is needed (too), beside settings the upload speeds. Can you guys confirm that? If so I would suggest adding that to the (great) manual!
                                        rsachocR ahmedadelhosniA 2 Replies Last reply
                                        • L LastSamurai
                                          rsachocR
                                          rsachocR
                                          rsachoc
                                          #31
                                          @LastSamurai I've been advised that setting the baud rate in myconfig.h is the correct way to get things working when uploading sketches to the slim node. Don't think it matters when burining the bootloader though.
