  3. Requesting variables from Domoticz
14 Posts 4 Posters 5.4k Views 7 Watching
  • mfalkviddM Offline
    Since most of Sweden is watching eurovision, I'm programming away :)
    I want to set a variable in Domoticz that sets how long my node should sleep next time it reports in.
    I have looked at http://forum.mysensors.org/topic/1976/scrolling-text-sensor-node-with-new-v_text/2 to get an idea how this could work, but I've run into some problems.
    I am unable to compile my code in Arduino IDE. This is the error output:
    arduino-plantmoisture:22: error: 'V_TEXT' was not declared in this scope
    In file included from R:\Documents\Arduino\libraries\MySensors/MySensor.h:24:0,
                     from arduino-plantmoisture.ino:2:
    R:\Documents\Arduino\libraries\MySensors/Version.h:9:25: note: #pragma message: 1.5
     #define LIBRARY_VERSION "1.5"
    arduino-plantmoisture.ino:23:17: note: in expansion of macro 'LIBRARY_VERSION'
    arduino-plantmoisture.ino: In function 'void setup()':
    arduino-plantmoisture:47: error: 'S_INFO' was not declared in this scope
    arduino-plantmoisture:53: error: 'V_TEXT' was not declared in this scope
    arduino-plantmoisture.ino: In function 'void loop()':
    arduino-plantmoisture:76: error: 'V_TEXT' was not declared in this scope
    arduino-plantmoisture.ino: In function 'void incomingMessage(const MyMessage&)':
    arduino-plantmoisture:97: error: 'V_TEXT' was not declared in this scope
    This is my code (or at least the start of it):
    #define N_ELEMENTS(array) (sizeof(array)/sizeof((array)[0]))
    #define CHILD_ID_MOISTURE 0
    #define CHILD_ID_BATTERY 1
    #define CHILD_ID_SLEEP_TIME 2
    #define RADIO_DELAY 250
    #define DEFAULT_SLEEP_TIME 1800000 // Sleep time between reads (in milliseconds)
    #define MIN_SLEEP_TIME 1000 // Do not allow shorter sleep times than 1 second
    #define MAX_SLEEP_TIME 86400000 // Do not allow shorter sleep times longer than 24 hours
    #define STABILIZATION_TIME 1000 // Let the sensor stabilize before reading
    #define BATTERY_FULL 3000 // 3,000 millivolts for 2xAA
    #define BATTERY_ZERO 2800 // 1,900 millivolts (1.9V, limit for nrf24l01 without step-up. 2.8V limit for Atmega328 without BOD disabled))
    const int SENSOR_ANALOG_PINS[] = {A0, A1}; // Sensor is connected to these two pins. Avoid A3 if using ATSHA204. A6 and A7 cannot be used because they don't have pullups.
    MyMessage msg(CHILD_ID_MOISTURE, V_HUM);
    MyMessage sleeptimeMsg(CHILD_ID_SLEEP_TIME, V_TEXT);
    #pragma message LIBRARY_VERSION
    long oldvoltage = 0;
    byte direction = 0;
    int oldMoistureLevel = -1;
    unsigned long sleeptime_ms = DEFAULT_SLEEP_TIME;
      Serial.begin(BAUD_RATE);
      Serial.println("Begin");
      gw.begin(incomingMessage);
      Serial.println("Begone");
      gw.sendSketchInfo("Plant moisture w bat", "1.6");
      gw.present(CHILD_ID_MOISTURE, S_HUM);
      delay(RADIO_DELAY);
      gw.present(CHILD_ID_BATTERY, S_CUSTOM);
      for (int i = 0; i < N_ELEMENTS(SENSOR_ANALOG_PINS); i++) {
        pinMode(SENSOR_ANALOG_PINS[i], OUTPUT);
        digitalWrite(SENSOR_ANALOG_PINS[i], LOW);
      delay(RADIO_DELAY);
      Serial.println("Present sleep time");
      gw.present(CHILD_ID_SLEEP_TIME, S_INFO);
      delay(RADIO_DELAY);
      Serial.println("Send sleep time");
      gw.send(sleeptimeMsg.set(DEFAULT_SLEEP_TIME));
      delay(RADIO_DELAY);
      Serial.println("Ask for sleep time");
      gw.request(CHILD_ID_SLEEP_TIME, V_TEXT);
    Why isn't V_TEXT and S_INFO defined? The compiler does use the 1.5 version of MySensors (see the pragma message I added to verify).
    Since I want to store an unsigned long, V_TEXT isn't the best choice but I thought I'd stick as closely to AWI's scrolling text sketch as possible to start with.
      Ah, found it. Had to copy the V_TEXT and S_INFO lines from the dev branch to MyMessage.h. It works now.
        ok, so on to the next problem.
        I am powering using usb through ftdi 3.3V and have a 4.7uF cap on the radio.
        This is the serial output:
        Begin
        send: 10-10-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
        send: 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        sensor started, id=10, parent=0, distance=1
        Begone
        send: 10-10-0-0 s=255,c=3,t=11,pt=0,l=20,sg=0,st=ok:Plant moisture w bat
        send: 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.6
        send: 10-10-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
        send: 10-10-0-0 s=1,c=0,t=23,pt=0,l=0,sg=0,st=fail:
        read: 0-0-10 s=255,c=3,t=6,pt=0,l=2,sg=0:M
        Present sleep time
        send: 10-10-0-0 s=2,c=0,t=36,pt=0,l=0,sg=0,st=ok:
        Ask for sleep time
        send: 10-10-0-0 s=2,c=2,t=47,pt=0,l=0,sg=0,st=fail:
        Send default sleep time
        send: 10-10-0-0 s=2,c=1,t=47,pt=0,l=18,sg=0,st=fail:DEFAULT_SLEEP_TIME
        send: 10-10-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:0.0
        send: 10-10-0-0 s=1,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.483
        send: 10-10-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=fail:86
        This is my code:
        #define BUF_SIZE 25 // max payload for MySensors(NRF24l01)
        #define THRESHOLD 1.1 // Only make a new reading with reverse polarity if the change is larger than 10%.
        #define DEFAULT_CONFIG_TIME 86400000 // Sleep time between config updates (in milliseconds)
        #define MAX_SLEEP_TIME 86400000 // Do not allow sleep times longer than 24 hours
        byte direction = 0;
        unsigned long sleeptime_ms = 0;
        unsigned long configtime_ms = DEFAULT_CONFIG_TIME;
        unsigned long lastConfigCheckTime = 0;
        char newMessage[BUF_SIZE];
          gw.wait(RADIO_DELAY);
          fetchConfig();
        void fetchConfig() {
          // Request latest sleep time
          gw.wait(RADIO_DELAY); // Hopefully we'll get an incoming message during this wait
          // If we didn't get any sleeptime, sleeptime will be 0.
          // Ask the controller to create the variable by sending the default value
          if (sleeptime_ms == 0) {
            Serial.println("Send default sleep time");
            gw.send(sleeptimeMsg.set("DEFAULT_SLEEP_TIME")); // TODO: Send value as string instead
          lastConfigCheckTime = millis();
        To troubleshoot this, I cross-reference the source and the serial API, right? (I really wish there was an easier way than to cross-reference the position in the debug output with the three-line command in the source and then cross-reference that with the the serial api.)
        So
        means the following:
        • 10: the sender was node 10
        • 10: the message comes directly from node 10
        • 0: the message is sent to node 0 (the gateway)
        • 0: the message final destination is 0
        • s=1: the message is from sensor 1
        • c=0: the command is 0 - are commands documented somewhere? I've seen c=0, c=1, c=2 and c=3)
        • t=23: the message type is 23 - which isn't a valid message type according to the serial API documentation
        • pt=0: the payload type is 0, which means S_DOOR - I don't use S_DOOR anywhere in my sketch so where did this come from?
        • l=0: the length of the payload is 0
        • sg=0: the payload is not signed
        • st=fail: the message failed
        • : the payload is empty
        Can anyone explain the values for c, t, and pt?
        • B Offline
          B Offline
          BartE
          wrote on last edited by BartE
          @mfalkvidd well it is explained here
          c=message type
          0 = presentation Sent by a node when they present attached sensors. This is usually done in setup() at startup.
          1 = (set) This message is sent from or to a sensor when a sensor value should be updated
          2 = (req) Requests a variable value (usually from an actuator destined for controller).
          3 = (interal) This is a special internal message. (like batery level, time, version, config etc...)
          4 = Used for OTA firmware updates
          t=sub type
          0 should send the V_TEMP
          23 should send the V_LIGHT_LEVEL
          pt=payload type
          0 = STRING
          1 = BYTE
          2 = INT16
          3 = UINT16
          4 = LONG32
          5 = ULONG32,
          6= CUSTOM,
          7 = FLOAT32
          • B BartE
            c=message type
            t=sub type
            pt=payload type
            0 = STRING
            1 = BYTE
            2 = INT16
            3 = UINT16
            4 = LONG32
            5 = ULONG32,
            6= CUSTOM,
            7 = FLOAT32
            @BartE I know parts of it is explained in the serial API. That's why I linked to the serial API :-)
            However, that page does not explain that c= in the debug output is message type.
            But it seems I got a off by one error when trying to cross-reference the debug output with the source code I linked to. The person who write this comment seems to be as confused as I am.
            Anyway, thanks for taking time to explain. I'll do some more troubleshooting and report back.
              martinhjelmareM Offline
              martinhjelmare
              @mfalkvidd
              This confusion is why I asked you to add the information from my post below, to the troubleshooting sticky post:
              http://forum.mysensors.org/topic/2579/about-serial-api-1-5/2
                @mfalkvidd
                Thanks! I knew I has seen an explanation that made sense somewhere :-) Must have lost that task. I have updated the troubleshooting post now.
                  martinhjelmare
                  @mfalkvidd
                  Great, thanks. It would be even better if it got merged into the top post, but at least it's in a topic where people can find it more easy now.
                    The first post is already quite heavy, I don't want to add to the big wall of text. But maybe having a separate post isn't better.
                    I'll see if I can merge it in a nice way. I'll also change the links to the source code to point to a specific commit. The line number references will not make any sense in the future if the links point to HEAD.
                      martinhjelmare
                      @mfalkvidd
                      I think adding headers to different sections in the post, will make it easier to read:
                      Header 1
                      Header 1
                      Header 2
                      Header 2
                      http://kramdown.gettalong.org/syntax.html#headers
                      Don't know if all this markdown is supported.
                      Good to update the links to be futureproof. :thumbsup:
                        futureproof links fixed - @martinhjelmare could you please check that I found the right lines (your links were already obsolete :) )
                        Have added a header as well, great suggestion. Will look at merging with the first post later, I think it will require some re-formatting of the first post to look good.
                          martinhjelmare
                          @mfalkvidd
                          Looks good!
                          When you merge this info, to make it complete, I think you should add what the three digits after "read" or "send" mean:
                          "0;0;3;0;9;read: 3-3-0 s=0,c=1,t=24,pt=0,l=11,sg=0:27"
                          Those are the node ids of sender_node - last_node - destination_node from left to right. So in the example it's node 3 that sent the message, and node 3 was also the last node before the gateway received the message, and it's the gateway (node 0) that is the destination.
                          Edit:
                          For sending there are four digits: 0-0-3-3
                          sender - last - to - destination
                          where to is similar to last, ie the node after the first hop in the network, if I understand correctly.
                            Begin
                            Begone
                            Present sleep time
                            Ask for sleep time
                            This is my code:
                            byte direction = 0;
                              fetchConfig();
                            So
                            M Offline
                            M Offline
                            MikeF
                            Following your comment earlier in this thread, I copied V_TEXT and S_INFO from the development branch into MyMessage.h. V_TEXT occupies position 47 in the typedef enum for '//Type of sensor data' in my version of MyMessage.h - when you copied it, did it go into position 23?
                            • M MikeF
                              @MikeF I don't have access to the code now, but you are probably right. I need to copy the whole enum, selectively copying doesn't work.
                              12.1k
