  3. influxdb and grafana on raspberrypi
16 Posts 6 Posters 19.6k Views 8 Watching
  • F
    F
    Fabien
    @mfalkvidd : very old version
    @tbowmo : can you post your error ? I compile influx and grafana few days ago with success on odroid C1 (armv7) and debian Jessie.
    • tbowmoT
      tbowmoT
      tbowmo
      @Fabien
      This is the last lines from my build log.. I followed the description on the link that you posted above.. But I see the same regardless of what recipe I follow.
      Also it complained about go1.4.3 was needed, when I started to compile influxdb.. So I installed that as well (besides 1.4.2 / 1.5.2 as in the recipe)
      can't load package: package github.com/influxdb/influxdb/tsdb: code in directory /home/thomas/.gvm/pkgsets/go1.5.2/influxdb/src/github.com/influxdb/influxdb/tsdb expects import "github.com/influxdata/influxdb/tsdb"
      can't load package: package github.com/influxdb/influxdb/tsdb/engine: code in directory /home/thomas/.gvm/pkgsets/go1.5.2/influxdb/src/github.com/influxdb/influxdb/tsdb/engine expects import "github.com/influxdata/influxdb/tsdb/engine"
      can't load package: package github.com/influxdb/influxdb/tsdb/engine/tsm1: code in directory /home/thomas/.gvm/pkgsets/go1.5.2/influxdb/src/github.com/influxdb/influxdb/tsdb/engine/tsm1 expects import "github.com/influxdata/influxdb/tsdb/engine/tsm1"
      can't load package: package github.com/influxdb/influxdb/uuid: code in directory /home/thomas/.gvm/pkgsets/go1.5.2/influxdb/src/github.com/influxdb/influxdb/uuid expects import "github.com/influxdata/influxdb/uuid"
      Build failed, unable to create package -- aborting
      • F
        F
        Fabien
        @tbowmo : in package.sh change line 70 to go1.5.2. This is the only modification i made.
        • tbowmoT
          tbowmoT
          tbowmo
          @Fabien
          I found the problem.. github.com/influxdb is renamed to github.com/influxdata, and all guides that I have followed pointed to influxdb. Tried to go with the influxdata instead. And I got it to build..
          So the recipe that I followed is the following (Taken from the French site that you mentioned above, and modified with my findings)
          $ wget https://raw.githubusercontent.com/moovweb/gvm/master/binscripts/gvm-installer
          $ chmod +x gvm-installer
          $ ./gvm-installer
          Cloning from https://github.com/moovweb/gvm.git to /home/pi/.gvm
          No existing Go versions detected
          Installed GVM v1.0.22
          Please restart your terminal session or to get started right away run
           `source /home/pi/.gvm/scripts/gvm`
          $ source /home/pi/.gvm/scripts/gvm
          # Install Go 1.4 before Go 1.5 : https://github.com/moovweb/gvm/issues/155
          $ gvm install go1.4.2
          Downloading Go source...
          Installing go1.4.2...
           * Compiling...
          $ gvm use go1.4.2 --default
          Now using version go1.4.2
          $ gvm install go1.5.3
          Updating Go source...
          Installing go1.5.3...
          * Compiling...
          $ gvm use go1.5.3 --default
          Now using version go1.5.3
          $ sudo apt-get install bison
          $ sudo apt-get install ruby-dev gcc
          $ sudo gem install fpm # Cf https://github.com/influxdb/influxdb/issues/3557
          $ gvm pkgset create influxdb
          $ gvm pkgset use influxdb
          Now using version go1.5.3@influxdb
          $ go get github.com/tools/godep
          $ go get -t -d github.com/influxdata/influxdb
          $ cd .gvm/pkgsets/go1.5.2/influxdb/src/github.com/influxdata/influxdb
          # Update to use go1.5.3 instead of 1.4.3
          $ sed -i -- 's/go1.4.3/go1.5.3/g' package.sh
          $ ./package.sh -t deb -p 0.9.6
          $ sudo dpkg -i influxdb_0.9.6_armhf.deb
          $ sudo mkdir /var/lib/influxdb
          $ sudo chown influxdb. /var/lib/influxdb
          $ sudo mkdir /var/log/influxdb
          $ sudo systemctl enable influxdb
          $ sudo systemctl start influxdb
          $ /opt/influxdb/influx
          Connected to http://localhost:8086 version 0.9.6
          InfluxDB shell 0.9.6
          • F
            F
            Fabien
            Thank you @tbowmo It will help me when I will compile the last version.
            • D
              drock1985
              wrote on last edited by drock1985
              Not sure if this works for sure or not but, if you are looking for a shortcut.... here is a .deb package made for Ubuntu arm.
              http://launchpadlibrarian.net/218115203/influxdb_0.9.4+dfsg1-1_armhf.deb
              Anyone have any tips for Grafana on an Rpi by chance?
              My Projects
              2 Door Chime Sensor
              Washing Machine Monitor
              • tbowmoT
                tbowmoT
                tbowmo
                @drock1985
                that's a rather old influxdb version, latest is 0.10
                I finally succeeded in getting both influxdb and grafana to install.. (Influx 0.10 and grafana 2.6.0). So now it's graphing time :)
                I have setup node-red to push data into influxdb, so it's independent on the controller that I choose to use..
                Right now it's stored to the sdcard on my raspberry, but since I push electrical utility measurements every second, I believe that I have to setup some kind of external storage, otherwise the sdcard would be worn out..
                • tbowmoT tbowmo
                  @drock1985
                  @tbowmo What's the performance of this setup on RPi?
                  I use a real server (dual core Athlon, 4Gb Ram, SSD) to run InfluxDB and Grafana on and even sometimes find it rather slow with large datasets.
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Yveaux
                    I haven't got that large data amount right now.. Right now only 5 sensors are writing to the influx db:
                    4 sensebenders (temperature / humidity). One of them also barometric pressure.. These are only transmitting when temperature / humidity changes..
                    1 Electrical utility meter.. this writes a couple of times each second (every time the LED blinks on my utility meter :))
                    So far I can't see any issues with speed, but it might change when I've got logs for 6 months in the database.
                    I haven't set up a retention plan yet, so currently I keep all data forever..
                    • A
                      Alexander
                      @tbowmo how did you finally manage to install Grafana on the RPI?
                      Some time ago I tried to do the same on the Domoticz image but gave it up...
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Alexander
                        I used the description that @fabien linked to in the first reply in this thread. I did however install go 1.5.3 instead of 1.5.2 as mentioned in that article.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Just found out that influxdata, is now making builds for armhf platform, from version 0.11..
                          So no need to compile stuff yourself for that part..
                          News are on their blog here https://influxdata.com/blog/announcing-influxdb-0-11-ga-kapacitor-telegraf/
                          And install instructions for ubuntu / debian is here https://docs.influxdata.com/influxdb/v0.9/introduction/installation/#ubuntu-debian
