  3. [SOLVED] ESP8266 Gateway endless loop
9 Posts 6 Posters 3.6k Views 5 Watching
  • O
    O
    Opus40
    Hi every one
    I'm looking for some help. I have ESP8266 setup as a gateway and was having some issues as can be seen in this post
    http://forum.mysensors.org/topic/2265/esp8266-gateway-can-t-press-start-for-inclusion/7
    I got around it with the fixes i had writen but have built a few more sensors so thought i would up date the gateway so I could add the sensors with out so much reflashing. I downloaded the Latest Dev branch and did a clean install of every thing then uploaded the basic ESP8266 gateway sketch.
    when it boots up i am getting the following from serial output
    ü! m!„þæÊõþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with home, channel 1
    dhcp client start...
    .ip:192.168.1.211,mask:255.255.255.0,gw:192.168.1.254
    .IP: 192.168.1.211
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    .IP: 192.168.1.211
    ü! m!BÿÄ1õþ0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    it just goes in a loop.
    Any help would be much appreciated
    M tekkaT 2 Replies Last reply
    • O Opus40
      Hi every one
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      .IP: 192.168.1.211
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      .IP: 192.168.1.211
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 5
      cnt
      Mille
      @Opus40
      I have exactly the same problem.
      • E
        E
        emc2
        I have some problem as well with the last 2.1.0 ESP8266 board files.
        You may want to try by downgrading to 2.0.0, work in my case.
        • E emc2
          Mille
          @emc2
          Thank you. Worked for me too. :)
          But..before I downgraded to 2.0.0 I did a test with GatewayESP8266MQTTClient and that one did work with the 2.1.0 ESP8266 board version.
          So for me, with the latest bord files for the ESP:
          GatewayESP8266MQTTClient is OK
          GatewayESP8266 is not OK
          //Adam
          • O
            O
            Opus40
            thanks Emc2 and mille for the feed back, Ill give 2.0.0 a go
            • noelgeorgiN
              noelgeorgiN
              noelgeorgi
              I had the same problem after updating to 2.1.0. I was getting wdt reset error, @Admin @hek could you please look into the issue???
              • O
                O
                Opus40
                Thanks going down to 2.0.0 worked for me.
                • G
                  G
                  gmccarthy
                  Thanks - been racking by brain over this. Going back to 2.0.0 also works for me.
                  • O Opus40
                    Hi every one
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 5
                    cnt
                    .IP: 192.168.1.211
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 5
                    cnt
                    .IP: 192.168.1.211
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 5
                    cnt
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @Opus40 enabling MY_USE_UDP in ESP8266 prevents wdt from barking (but obviously not a solution for the gw)
