  3. NRF24L01+ range of only few meters
81 Posts 21 Posters 53.5k Views 25 Watching
  • OitzuO
    OitzuO
    Oitzu
    @petewill great to hear. Let me know if you are successful. :)
    • pkjjnealP
      pkjjnealP
      pkjjneal
      This is great info. I actually had great luck with the chip antenna version with a mini pro and an UNO, and the range I wanted was just not there. I moved to the one with the PA+ ext antenna, and having a strange issue. If I swap out the chip antenna version for the PA+ ext antenna version on the mini pro, it only sends packets if I am physically touching the nRF board itself with my finger. The one connected to the UNO does not have this issue. It seems to be grounded sufficiently (only the GND pin on the nRF connector), and I changed the power source from the FTDI module to a separate 3.4V source with no difference in this behavior. Any ideas?
      OitzuO 1 Reply Last reply
      • pkjjnealP pkjjneal
        OitzuO
        OitzuO
        Oitzu
        Also read: http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/
        Its a typical behaviour i observed on badly shielded modules.
        pkjjnealP 1 Reply Last reply
        • G
          G
          gmccarthy
          I'm also getting poor range (Around 5m) and have tried most of the tricks. One thing with the homemade antenna from the video, which direction should the antenna be pointing?
          • Igor KatkovI
            Igor KatkovI
            Igor Katkov
            Typically you point it up. It gives you vertical polarization.
            You point both transmitter and received wire antennas same directions.
            It's possible that your chips are at fault, if non of other tricks worked (capacitors, clear power, enough current, short wires, lo-noise rf spectrum channel) try other transceivers.
            G 1 Reply Last reply
            • OitzuO Oitzu
              pkjjnealP
              pkjjnealP
              pkjjneal
              @Oitzu So I covered the nRF module in plastic and foil to create the shield. Previously, I had to touch a specific part of the board. Now I just touch any part of the foil, and it starts working. Makes sense, but I still cannot get transmissions without touching with my finger. I did try grounding the foil to the Arduino ground, but no change. The behavior makes me think I am on the correct path. Any other suggestions?
              • OitzuO
                OitzuO
                Oitzu
                @pkjjneal would try to let the foil touch the ground from the antenna socket.
                Grounding the foil on the arduino probably creates a ground loop.
                May also try to add a filter.
                Igor KatkovI 1 Reply Last reply
                • OitzuO Oitzu
                  Igor KatkovI
                  Igor KatkovI
                  Igor Katkov
                  @Oitzu
                  I though antenna ground and MCU ground is the same thing
                  • OitzuO
                    OitzuO
                    Oitzu
                    @Igor: Yes, that is right, but you are possible creating a ground loop.
                    Grounding something should ever be as short as possible, because also in the GND wires electrical charges can build up and create interferences.
                    • Igor KatkovI Igor Katkov
                      G
                      G
                      gmccarthy
                      wrote on last edited by gmccarthy
                      #52
                      I've tried the cling wrap and tin foil trick - this seems to have worked. Was getting 5m or so, now I"m getting constant readings from one side of the house to the other (through multiple walls!). 20m
                      Update: Just as I posted this the sensor stopped working :(
                      I'm really having major reliability issues with these sensors and am thinking of scrapping them altogether now. Its a pity these are such a hit and miss affair.
                      • G gmccarthy
                        I
                        I
                        Ironbar
                        @gmccarthy
                        My guess is if the sensors work and suddenly stop, you have something else interfering with the radios. Could be a microwave, AC unit, etc.
                        I about gave up on this project last year. I had several units built that worked fine and then one day all of them quit. After several frustrating weeks, I discovered my wifi router somehow was interfering with the units. It was an old unit and I needed to replace it. After it was gone, everything went back to working correctly.
                        • OitzuO
                          OitzuO
                          Oitzu
                          @gmccarthy don't give up. You seem to be on the right track and already got great results. :+1:
                          Maybe go bare bones and try the rf24 scanner,
                          https://maniacbug.github.io/RF24/scanner_8pde-example.html
                          to find the best nrf24 channel for your. :)
                          • OitzuO Oitzu
                            G
                            G
                            gmccarthy
                            Thanks. This looks interesting. Will give it a shot.
                            N 1 Reply Last reply
                            • G gmccarthy
                              N
                              N
                              nunver
                              @gmccarthy As far as I know, NRF channels above 100 should not have interference from Wifi 2.4 Ghz. I was getting 2-3 meters at best. I changed the channel to 110 and corrected the power supply a little. I am yet to implement cling wrap.
                              I get 10-15 meters between two standard modules inside an apartment. The apartment is like a faraday cage and sometimes I cannot get wifi on the outer extremes while router is in the middle. I am getting sensor readings from one end to the other now, passing through the area where I have the router. So, I think interference is critical in distance.
                              • L
                                L
                                LastSamurai
                                Hey guys I seem to have similar (but even worse) problems here. I am building a rgbwController and have huge problems connecting that to my gateway although it's only ~3m and no obstacle away.
                                I am using 4,7uF caps on both sides. Stepdown from 12V + another cap on the rgbwController's side and the arduino uno's 3.3V on the other side. I also tried another external 3.3V power source here (but that did not help either).
                                I tried changing the channel to 111 but that seems to have made it even worse.
                                Any ideas how to debug that or what to change?
                                It's really sad to have the setup up and running and then being unable to really use it due to radio problems ;(
                                • OitzuO
                                  OitzuO
                                  Oitzu
                                  @LastSamurai Which nrf24l01+ modules are you using on which side?
                                  Whats the typical error pattern you get? (Failed transmission from gw to node or from node to gw?)
                                  Need to know your exact construction, before guessing what could be wrong.
                                  L 1 Reply Last reply
                                  • OitzuO Oitzu
                                    L
                                    L
                                    LastSamurai
                                    wrote on last edited by LastSamurai
                                    #59
                                    @Oitzu
                                    I am using the "standard" ones on both sides ("sodial" ones. I think these). My logs from the controller from my thread look like this:
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                                    0;0;3;0;9;read: 123-123-0 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                    123;1;1;1;2;1
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:0
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                                    0;0;3;0;9;read: 123-123-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                    123;1;1;1;2;0
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                                    123;1;1;1;2;0
                                    123;1;1;1;2;1
                                    123;1;1;1;2;0
                                    123;1;1;1;2;0
                                    123;1;1;1;2;0
                                    123;1;1;1;2;1
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=41,pt=0,l=9,sg=0,st=fail:#00000
                                    0;0;3;0;9;read: 123-123-0 s=1,c=1,t=41,pt=0,l=9,sg=0:#000000FF
                                    123;1;1;1;41;#000000FF
                                    0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=3,pt=0,l=3,sg=0,st=fail:100
                                    123;1;1;1;2;0
                                    123;1;1;1;2;1
                                    Sometimes I get a fail message but the lights are reacting (so I guess the ack didn't reach the gateway). I wasn't able to debug the rgbw controller in its position yet because it's sitting on top of a cupboard.
                                    If you need more infos just tell me.
                                    I'll try out another arduino as gateway later.
                                    PS according to this post they might be "fake" though ;) Although others seemed to have used them for mysensors too (comments)
                                    • L
                                      L
                                      LastSamurai
                                      Something seems to be off with the controller. I tried the same code on another arduino uno and it worked just fine. A little less distance perhaps but no errors at all. I'll try to do some hardware testing and measuring tomorrow.
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        @LastSamurai also keep in mind that if you are using the LM2596 buck converter that you need to use a post ripple filter.
                                        I explained that here: http://blog.blackoise.de/2016/03/building-a-lc-filter-for-your-nrf24l01-palna-module/.
                                        • OitzuO Oitzu
                                          L
                                          L
                                          LastSamurai
                                          @Oitzu Thanks for the hint! That might actually have been a reason why it worked for some time and then stoped, right? I have ordered the components needed and will test it soon.
                                          I don't actually use the LM2596 modules but these smaller ones but I guess they use similar parts.
                                          Did you have similar issues?
