  3. NRF24L01+ range of only few meters
81 Posts 21 Posters 53.5k Views 25 Watching
  • OitzuO Oitzu
    @pkjjneal would try to let the foil touch the ground from the antenna socket.
    Grounding the foil on the arduino probably creates a ground loop.
    May also try to add a filter.
    Igor KatkovI
    Igor KatkovI
    Igor Katkov
    @Oitzu
    I though antenna ground and MCU ground is the same thing
    • OitzuO
      OitzuO
      Oitzu
      @Igor: Yes, that is right, but you are possible creating a ground loop.
      Grounding something should ever be as short as possible, because also in the GND wires electrical charges can build up and create interferences.
      • Igor KatkovI Igor Katkov
        Typically you point it up. It gives you vertical polarization.
        You point both transmitter and received wire antennas same directions.
        It's possible that your chips are at fault, if non of other tricks worked (capacitors, clear power, enough current, short wires, lo-noise rf spectrum channel) try other transceivers.
        G
        G
        gmccarthy
        wrote on last edited by gmccarthy
        #52
        I've tried the cling wrap and tin foil trick - this seems to have worked. Was getting 5m or so, now I"m getting constant readings from one side of the house to the other (through multiple walls!). 20m
        Update: Just as I posted this the sensor stopped working :(
        I'm really having major reliability issues with these sensors and am thinking of scrapping them altogether now. Its a pity these are such a hit and miss affair.
        I 1 Reply Last reply
        • G gmccarthy
          I
          I
          Ironbar
          @gmccarthy
          My guess is if the sensors work and suddenly stop, you have something else interfering with the radios. Could be a microwave, AC unit, etc.
          I about gave up on this project last year. I had several units built that worked fine and then one day all of them quit. After several frustrating weeks, I discovered my wifi router somehow was interfering with the units. It was an old unit and I needed to replace it. After it was gone, everything went back to working correctly.
          • OitzuO
            OitzuO
            Oitzu
            @gmccarthy don't give up. You seem to be on the right track and already got great results. :+1:
            Maybe go bare bones and try the rf24 scanner,
            https://maniacbug.github.io/RF24/scanner_8pde-example.html
            to find the best nrf24 channel for your. :)
            G 1 Reply Last reply
            • OitzuO Oitzu
              G
              G
              gmccarthy
              Thanks. This looks interesting. Will give it a shot.
              N 1 Reply Last reply
              • G gmccarthy
                N
                N
                nunver
                @gmccarthy As far as I know, NRF channels above 100 should not have interference from Wifi 2.4 Ghz. I was getting 2-3 meters at best. I changed the channel to 110 and corrected the power supply a little. I am yet to implement cling wrap.
                I get 10-15 meters between two standard modules inside an apartment. The apartment is like a faraday cage and sometimes I cannot get wifi on the outer extremes while router is in the middle. I am getting sensor readings from one end to the other now, passing through the area where I have the router. So, I think interference is critical in distance.
                • L
                  L
                  LastSamurai
                  Hey guys I seem to have similar (but even worse) problems here. I am building a rgbwController and have huge problems connecting that to my gateway although it's only ~3m and no obstacle away.
                  I am using 4,7uF caps on both sides. Stepdown from 12V + another cap on the rgbwController's side and the arduino uno's 3.3V on the other side. I also tried another external 3.3V power source here (but that did not help either).
                  I tried changing the channel to 111 but that seems to have made it even worse.
                  Any ideas how to debug that or what to change?
                  It's really sad to have the setup up and running and then being unable to really use it due to radio problems ;(
                  • OitzuO
                    OitzuO
                    Oitzu
                    @LastSamurai Which nrf24l01+ modules are you using on which side?
                    Whats the typical error pattern you get? (Failed transmission from gw to node or from node to gw?)
                    Need to know your exact construction, before guessing what could be wrong.
                    L 1 Reply Last reply
                    • OitzuO Oitzu
                      L
                      L
                      LastSamurai
                      wrote on last edited by LastSamurai
                      #59
                      @Oitzu
                      I am using the "standard" ones on both sides ("sodial" ones. I think these). My logs from the controller from my thread look like this:
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                      0;0;3;0;9;read: 123-123-0 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                      123;1;1;1;2;1
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:0
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                      0;0;3;0;9;read: 123-123-0 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                      123;1;1;1;2;0
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
                      123;1;1;1;2;0
                      123;1;1;1;2;1
                      123;1;1;1;2;0
                      123;1;1;1;2;0
                      123;1;1;1;2;0
                      123;1;1;1;2;1
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=41,pt=0,l=9,sg=0,st=fail:#00000
                      0;0;3;0;9;read: 123-123-0 s=1,c=1,t=41,pt=0,l=9,sg=0:#000000FF
                      123;1;1;1;41;#000000FF
                      0;0;3;0;9;send: 0-0-123-123 s=1,c=1,t=3,pt=0,l=3,sg=0,st=fail:100
                      123;1;1;1;2;0
                      123;1;1;1;2;1
                      Sometimes I get a fail message but the lights are reacting (so I guess the ack didn't reach the gateway). I wasn't able to debug the rgbw controller in its position yet because it's sitting on top of a cupboard.
                      If you need more infos just tell me.
                      I'll try out another arduino as gateway later.
                      PS according to this post they might be "fake" though ;) Although others seemed to have used them for mysensors too (comments)
                      • L
                        L
                        LastSamurai
                        Something seems to be off with the controller. I tried the same code on another arduino uno and it worked just fine. A little less distance perhaps but no errors at all. I'll try to do some hardware testing and measuring tomorrow.
                        • OitzuO
                          OitzuO
                          Oitzu
                          @LastSamurai also keep in mind that if you are using the LM2596 buck converter that you need to use a post ripple filter.
                          I explained that here: http://blog.blackoise.de/2016/03/building-a-lc-filter-for-your-nrf24l01-palna-module/.
                          • OitzuO Oitzu
                            L
                            L
                            LastSamurai
                            @Oitzu Thanks for the hint! That might actually have been a reason why it worked for some time and then stoped, right? I have ordered the components needed and will test it soon.
                            I don't actually use the LM2596 modules but these smaller ones but I guess they use similar parts.
                            Did you have similar issues?
                            • OitzuO
                              OitzuO
                              Oitzu
                              @LastSamurai can't really say for this modules.
                              The datasheet for the LM2596 says you should use a post ripple filter for low noise, because it generates sawtooth ripple at its switching frequency (150khz). The china-clones of the lm2596 seem to be even worse generating even greater ripple with 50khz.
                              Whats the ic on the mini dc-dc converter called? The ebay offer says it has a output ripple of 30mV bute more then often these values are the best case. Maybe a datasheets is available.
                              • NuubiN
                                NuubiN
                                Nuubi
                                It would be so useful to be able to measure the supply voltages with an oscilloscope. So far all my transmission problems have been related to the power supplies. Only after using a scope I fully realized that. No more freezing or poor function of the nodes.
                                Also, using a brand supply doesn't necessarily mean a clean signal. This (again) is an illustrative post about USB supplies, worth to take a look at:
                                http://www.righto.com/2012/10/a-dozen-usb-chargers-in-lab-apple-is.html
                                AWIA 1 Reply Last reply
                                • OitzuO
                                  OitzuO
                                  Oitzu
                                  You are totally right! Unfortunately i also don't own a oscilloscope. But a cheaper usb oscilloscope is on my need to have list because of a all the trouble and testing i had with this...
                                  Igor KatkovI 1 Reply Last reply
                                  • OitzuO Oitzu
                                    Igor KatkovI
                                    Igor KatkovI
                                    Igor Katkov
                                    @Oitzu DSO138 scope is like $25 from aliexpress
                                    • OitzuO
                                      OitzuO
                                      Oitzu
                                      @Igor-Katkov said:
                                      DSO138
                                      Was thinking of something like the Hantek 6022BE. Most EE guys would say "eh... crap", but oh well.. it's just a hobby and i'm not willing to pay hundreds of dollars for it. :D
                                      • Igor KatkovI
                                        Igor KatkovI
                                        Igor Katkov
                                        One might think that to measure ripple noise of $2 Chinese power supply ~$70 unit is an overkill :-)
                                        • OitzuO
                                          OitzuO
                                          Oitzu
                                          @Igor-Katkov eh... now you just sound like my gf. :P
                                          No, you're right. But it may come handy in some other situations. :)
