  3. My slim 2aa battery node tools
13 Posts 4 Posters 6.5k Views 5 Watching
  • alexsh1A alexsh1
    @AWI said:
    I will post some picture of a similar construction to program the @GertSanders very narrow node without removing the atmega from it's socket.
    @AWI Are these the ones you are talking about?
    https://www.youtube.com/watch?v=tU8sFUKugZ0
    It would nice to have it on @GertSanders narrow node as taking the chip out to reprogram on the breadboard is not ideal. Though I do have a programmer (http://www.boardstuff.co.uk/), which comes on top of my Arduino.
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    @alexsh1 Those are the ones. Pogo pins come in a number of variations.
    • AWIA
      AWIA
      AWI
      For (ftdi) programming @GertSanders very narrow and minimal switch node without removing the atmega I made a small board with pogo pins.
      The processor needs to be connected on reset, tx, rx, vcc and gnd for FTDI programming. so only need those connections (pin 1,2,3,7,8)
      0_1457103465132_upload-5aacacc6-a987-4fee-bdbb-bf6f6453713a
      soldering them neatly in the right position with the help of a few boards.
      0_1457103624263_upload-5b26596e-0319-4331-a137-0b3439f955e4
      I used this type of the pogo pin (looks a little agressive :angry: ) but there are many variations. It depends on how you want to contact.
      0_1457103866235_upload-5d4d7a8f-9062-4315-9096-68ff0442c8ff
      the connection to ftdi header and a few components to have the circuit reset from the dtr pin. (10k resistor to Vcc and 100nF capacitor to dtr).
      0_1457104018883_upload-53f6308c-cbf3-42f4-947d-cbc27d59937f
      and that is the first victim board attached. I need at least one hand to press it against the pins therefore not really happy with the design.
      • alexsh1A
        alexsh1A
        alexsh1
        @AWI clearly the board has not been designed for the FTDI connection :)
        • alexsh1A alexsh1
          GertSandersG
          GertSandersG
          GertSanders
          Indeed :-)
          • carlierdC
            carlierdC
            carlierd
            @AWI : may you post the schematic diagram of your reset circuit ?
            I got so many connection issue with my FTDI. I of course check internet but nothing is working correctly.
            Thanks !
            David.
            AWIA 1 Reply Last reply
            • carlierdC carlierd
              Thanks !
              David.
              AWIA
              AWIA
              AWI
              @carlierd courtesy @m26872 (My Slim 2AA batt node)
              0_1457899921050_upload-74132cfb-6d73-44f6-9fe5-2252d93a43d5
              carlierdC 1 Reply Last reply
              • AWIA AWI
                carlierdC
                carlierdC
                carlierd
                @AWI no surprise. It's what I've done except for the capacitor on AREF pin but I'm pretty sure there is no link.
                Perhaps a problem due to my Mac. I don't know how I can check the connection and isolate the problem.
                David.
                  David.
                  AWIA
                  AWIA
                  AWI
                  @carlierd you can try with a standard pro mini to get it working...
                  • AWIA AWI
                    carlierdC
                    carlierdC
                    carlierd
                    @AWI already done without problem ! I think I got problem with ATMEGA in DIP format ...
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @carlierd
                      I'm pretty sure that a Mac and the DIP version of the atmega328 like each other. I have only used the DIP version and I also work on a Mac.
                      • GertSandersG GertSanders
                        @carlierd
                        carlierdC
                        carlierdC
                        carlierd
                        @GertSanders I tried today and now I can download sketch correctly. One strange thing is that I have to open the serial monitor to have the arduino working after the download ...
                        In // I think I have a problem with a bad RFM69 ...
