  3. Battery based atmega328p sensor with SMD nrf24l01+
mysensorsatmega328nrf24l01contest2016
22 Posts 5 Posters 9.8k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/46/Battery-based-atmega328p-sensor-with-SMD-nrf24l01
    • GertSandersG
      GertSandersG
      GertSanders
      Added BOM, EAGLE files, board image and a warning: untested board !
      • bisschopsrB
        bisschopsrB
        bisschopsr
        Hi Gert,
        Looks like an interesting design. Would be great if you could add the schematics as PDF (for the no- eagle users)
        Thx
        Ralph
        Domoticz, P1 meter interface, MySensors and more to come!
        • bisschopsrB bisschopsr
          Hi Gert,
          Thx
          Ralph
          GertSandersG
          GertSandersG
          GertSanders
          @bisschopsr
          Done :-)
          • bisschopsrB
            bisschopsrB
            bisschopsr
            Thx Gert. Very helpful!
            Ralph
            • alexsh1A
              alexsh1A
              alexsh1
              @GertSanders I think I may struggle with capacitors (100nf) as there are a few under the IC this time. I have the following ones:
              http://www.ebay.co.uk/itm/100nF-Ceramic-Disc-Capacitor-x10-/111609062446?hash=item19fc6b242e:g:iZMAAOSwBLlU8FK-
              Which ones are you using please? Do you think these would be ok:
              http://www.ebay.co.uk/itm/SparkyLabs-multilayer-100nF-0-1uF-ceramic-capacitors-various-quantities-10-/181288374594?var=&hash=item2a35a11142:m:mEo7ZMWSQSd4VxrmTONg4dg
              OR perhaps I should use 0805 SMD ones?
              • alexsh1A alexsh1
                GertSandersG
                GertSandersG
                GertSanders
                @alexsh1
                I'm using these:
                http://www.aliexpress.com/item/100pcs-Multilayer-ceramic-capacitor-X7R-100nF-0-1uF-104-50V-2-54mm-10/2000733997.html
                Any 100nF capacitor which fits inside a 100 mil footprint is fine. Maximum height should be 4mm.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  Ok, clear now. I have been really struggling with two ceramic 22pF capacitors in V2 node
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    My prototype boards for V3 have finally arrived. This weekend I will start assembling and testing. Alexsh1 has already confirmed that the drill size of JP1 is a bit too narrow for standard breakable 2.54mm spaced headers. Mine do fit, but just barely. Version V4 of this board is already uploaded to OSH Park, but not yet tested. On that I used another library for the headers which has larger holes.
                    So I will put that version available, version 3 is just for testing.
                    Another comment: if the 3V3 regulator is not mounted, do not forget to bridge the "3V3" solder pad.
                    And also: this board is made for battery holders with 2 batteries, not possible to mount two individual AAA battery holders any more.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @GertSanders Can you please summarise the difference between V3 and V4 please?
                      • alexsh1A alexsh1
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @alexsh1
                        In V3 I had two optional pull up resistors for pins D2 and D3.
                        In V4 I only have 1 pull up resistor for D2. But I gained space to add extra pins so that I have the 6 pin ISP layout included in the extention connector.
                        All the rest remained the same.
                        I uploaded the schematic to Openhardware.io (I think).
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          I have just noticed you have the INT solderpad. What is it for please?
                          • alexsh1A alexsh1
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @alexsh1
                            This is in the V3 version only.
                            That solderpad allows you to connect the INT pin on the NRF24L01+ to pin 2 of the ATMEGA328p. IF the software would allow it, you could then have the radio wake up the atmega328 via a hardware interrupt.
                            This is not used in MySensors, but could be used for direct communication via the RF24 library.
                            This solderpad is available in v3, but I removed it from v4, because I also do not use this interrupt capability in my sensors (all based on MySensors library).
                            It would make sense if the connector would allow an RF6x radio, but the SMD version has a specific connector layout, so no point to cater for possible INT use in my view.
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @GertSanders Thanks - I was wondering why you had it as it is not supposed by MySensors, but knowing your "board style" this hardly should come as a surprise - you really try to account for any eventuality. :+1:
                              EDIT: Was just browsing the boards looking for a new board for the GW.
                              I think its time to publish your board under the name of Gertino or something :)
                              Just an idea
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                @GertSanders Did you try EEPROM or ATSHA204a? I have got AT25512N-SH-T SOIC-8 which is slightly different one compare to your BOM and I wonder if this would be fine.
                                I also have a few 8 pins ATSHA204a, but they are not suitable for MySensors and 3 pin version is in post.
                                • alexsh1A alexsh1
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @alexsh1
                                  Nope, I did not yet try the Flash memory, nor the ATSHA204. I did received some three-pin versions recently, so I could try. But my gateways is directly a raspberry, not an atmega328 based one, so signed messages are not (yet) supported. For flash memory I'm in the same predicament as other contributors here. I can buy them from Mouser , but 20 USD for transport kills the idea of buying only 5 pcs.
                                  I would like to participate in a group buy. Maybe an idea for the meetup in Breda next month.
                                  alexsh1A 1 Reply Last reply
                                  • GertSandersG GertSanders
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @GertSanders Count me in for a group buy - excellent idea :+1:
                                    Do you think the IC I have (AT25512N-SH-T SOIC-8) would be working with your board?
                                    • alexsh1A alexsh1
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @alexsh1
                                      Really no idea. Someone with knowledge of the dual-optiboot workings should be able to confirm this.
                                      I have some Winbond flash memory, but did not yet have time to do a test yet (other projects are asking for priority).
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @GertSanders ATSHA204A is working fine on your node. I finally have built a full node with ATSHA204A and SPI EEPROM.
                                        Starting sensor (RNONAA, 2.0.0-beta)
                                        Radio init successful.
                                        Pressure Sensor1.1isMetric: 1
                                        send: 12-12-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.40
                                        send: 12-12-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:114
                                        send: 12-12-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,st=ok:FFFFFFFFFFFFFFFF0300
                                        Signing required
                                        send: 12-12-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                                        Waiting for GW to send signing preferences...
                                        Skipping security for command 3 type 15
                                        read: 0-0-12 s=255,c=3,t=15,pt=0,l=2,sg=0:
                                        Mark node 0 as one that do not require signed messages
                                        Mark node 0 as one that do not require whitelisting
                                        send: 12-12-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                                        send: 12-12-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        Skipping security for command 3 type 16
                                        read: 0-0-12 s=255,c=3,t=16,pt=0,l=0,sg=0:
                                        Signing backend: ATSHA204
                                        SHA256: A8457C04B9E7BAD1DC89908CB0127583D783B5-�¶
                                        Transmittng nonce
                                        send: 12-12-0-0 s=255,-�ÖÖ139
                                        Current nonce: A8457C04B9E7BAD1DC89908CB0127583D783B54D5B963B84E9AAAAAAAAAAAAAA
                                        HMAC: 78E50639CF4048466816DD0CD92E3B21BF--�j-�]
                                        Signature OK
                                        GertSandersG V 2 Replies Last reply
                                        • alexsh1A alexsh1
                                          Signing required
                                          Transmittng nonce
                                          Signature OK
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @alexsh1
                                          Excellent !!!
