  3. Battery based atmega328p sensor with SMD nrf24l01+
mysensorsatmega328nrf24l01contest2016
22 Posts 5 Posters 9.9k Views 4 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    Added BOM, EAGLE files, board image and a warning: untested board !
    • bisschopsrB
      bisschopsrB
      bisschopsr
      Hi Gert,
      Looks like an interesting design. Would be great if you could add the schematics as PDF (for the no- eagle users)
      Thx
      Ralph
      Domoticz, P1 meter interface, MySensors and more to come!
      • bisschopsrB bisschopsr
        Hi Gert,
        Thx
        Ralph
        GertSandersG
        GertSandersG
        GertSanders
        @bisschopsr
        Done :-)
        • bisschopsrB
          bisschopsrB
          bisschopsr
          Thx Gert. Very helpful!
          Ralph
          • alexsh1A
            alexsh1A
            alexsh1
            @GertSanders I think I may struggle with capacitors (100nf) as there are a few under the IC this time. I have the following ones:
            http://www.ebay.co.uk/itm/100nF-Ceramic-Disc-Capacitor-x10-/111609062446?hash=item19fc6b242e:g:iZMAAOSwBLlU8FK-
            Which ones are you using please? Do you think these would be ok:
            http://www.ebay.co.uk/itm/SparkyLabs-multilayer-100nF-0-1uF-ceramic-capacitors-various-quantities-10-/181288374594?var=&hash=item2a35a11142:m:mEo7ZMWSQSd4VxrmTONg4dg
            OR perhaps I should use 0805 SMD ones?
            • alexsh1A alexsh1
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1
              I'm using these:
              http://www.aliexpress.com/item/100pcs-Multilayer-ceramic-capacitor-X7R-100nF-0-1uF-104-50V-2-54mm-10/2000733997.html
              Any 100nF capacitor which fits inside a 100 mil footprint is fine. Maximum height should be 4mm.
              • alexsh1A
                alexsh1A
                alexsh1
                Ok, clear now. I have been really struggling with two ceramic 22pF capacitors in V2 node
                • GertSandersG
                  GertSandersG
                  GertSanders
                  My prototype boards for V3 have finally arrived. This weekend I will start assembling and testing. Alexsh1 has already confirmed that the drill size of JP1 is a bit too narrow for standard breakable 2.54mm spaced headers. Mine do fit, but just barely. Version V4 of this board is already uploaded to OSH Park, but not yet tested. On that I used another library for the headers which has larger holes.
                  So I will put that version available, version 3 is just for testing.
                  Another comment: if the 3V3 regulator is not mounted, do not forget to bridge the "3V3" solder pad.
                  And also: this board is made for battery holders with 2 batteries, not possible to mount two individual AAA battery holders any more.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @GertSanders Can you please summarise the difference between V3 and V4 please?
                    • alexsh1A alexsh1
                      GertSandersG
                      GertSandersG
                      GertSanders
                      @alexsh1
                      In V3 I had two optional pull up resistors for pins D2 and D3.
                      In V4 I only have 1 pull up resistor for D2. But I gained space to add extra pins so that I have the 6 pin ISP layout included in the extention connector.
                      All the rest remained the same.
                      I uploaded the schematic to Openhardware.io (I think).
                      • alexsh1A
                        alexsh1A
                        alexsh1
                        I have just noticed you have the INT solderpad. What is it for please?
                        • alexsh1A alexsh1
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1
                          This is in the V3 version only.
                          That solderpad allows you to connect the INT pin on the NRF24L01+ to pin 2 of the ATMEGA328p. IF the software would allow it, you could then have the radio wake up the atmega328 via a hardware interrupt.
                          This is not used in MySensors, but could be used for direct communication via the RF24 library.
                          This solderpad is available in v3, but I removed it from v4, because I also do not use this interrupt capability in my sensors (all based on MySensors library).
                          It would make sense if the connector would allow an RF6x radio, but the SMD version has a specific connector layout, so no point to cater for possible INT use in my view.
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            @GertSanders Thanks - I was wondering why you had it as it is not supposed by MySensors, but knowing your "board style" this hardly should come as a surprise - you really try to account for any eventuality. :+1:
                            EDIT: Was just browsing the boards looking for a new board for the GW.
                            I think its time to publish your board under the name of Gertino or something :)
                            Just an idea
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @GertSanders Did you try EEPROM or ATSHA204a? I have got AT25512N-SH-T SOIC-8 which is slightly different one compare to your BOM and I wonder if this would be fine.
                              I also have a few 8 pins ATSHA204a, but they are not suitable for MySensors and 3 pin version is in post.
                              • alexsh1A alexsh1
                                GertSandersG
                                GertSandersG
                                GertSanders
                                @alexsh1
                                Nope, I did not yet try the Flash memory, nor the ATSHA204. I did received some three-pin versions recently, so I could try. But my gateways is directly a raspberry, not an atmega328 based one, so signed messages are not (yet) supported. For flash memory I'm in the same predicament as other contributors here. I can buy them from Mouser , but 20 USD for transport kills the idea of buying only 5 pcs.
                                I would like to participate in a group buy. Maybe an idea for the meetup in Breda next month.
                                alexsh1A 1 Reply Last reply
                                • GertSandersG GertSanders
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @GertSanders Count me in for a group buy - excellent idea :+1:
                                  Do you think the IC I have (AT25512N-SH-T SOIC-8) would be working with your board?
                                  • alexsh1A alexsh1
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @alexsh1
                                    Really no idea. Someone with knowledge of the dual-optiboot workings should be able to confirm this.
                                    I have some Winbond flash memory, but did not yet have time to do a test yet (other projects are asking for priority).
                                    • alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @GertSanders ATSHA204A is working fine on your node. I finally have built a full node with ATSHA204A and SPI EEPROM.
                                      Starting sensor (RNONAA, 2.0.0-beta)
                                      Radio init successful.
                                      Pressure Sensor1.1isMetric: 1
                                      send: 12-12-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.40
                                      send: 12-12-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:114
                                      send: 12-12-0-0 s=255,c=4,t=0,pt=6,l=10,sg=0,st=ok:FFFFFFFFFFFFFFFF0300
                                      Signing required
                                      send: 12-12-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                                      Waiting for GW to send signing preferences...
                                      Skipping security for command 3 type 15
                                      read: 0-0-12 s=255,c=3,t=15,pt=0,l=2,sg=0:
                                      Mark node 0 as one that do not require signed messages
                                      Mark node 0 as one that do not require whitelisting
                                      send: 12-12-0-0 s=255,c=0,t=17,pt=0,l=10,sg=0,st=ok:2.0.0-beta
                                      send: 12-12-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                      Skipping security for command 3 type 16
                                      read: 0-0-12 s=255,c=3,t=16,pt=0,l=0,sg=0:
                                      Signing backend: ATSHA204
                                      SHA256: A8457C04B9E7BAD1DC89908CB0127583D783B5-�¶
                                      Transmittng nonce
                                      send: 12-12-0-0 s=255,-�ÖÖ139
                                      Current nonce: A8457C04B9E7BAD1DC89908CB0127583D783B54D5B963B84E9AAAAAAAAAAAAAA
                                      HMAC: 78E50639CF4048466816DD0CD92E3B21BF--�j-�]
                                      Signature OK
                                      GertSandersG V 2 Replies Last reply
                                      • alexsh1A alexsh1
                                        Signing required
                                        Transmittng nonce
                                        Signature OK
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @alexsh1
                                        Excellent !!!
                                        • alexsh1A alexsh1
                                          Signing required
                                          Transmittng nonce
                                          Signature OK
                                          V
                                          V
                                          vikasjee
                                          @alexsh1 Can you please publish your full node design (SCH+BRD) or/and PDFs with ATSHA204A and SPI EEPROM? I am really interested in checking it out! Also the relevant sketch to understand how the battery operations are really supported esp. with interrupt handler et al.
