  3. Why continue to use NRF24L01?
17 Posts 8 Posters 11.7k Views 8 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    You will also find out that there is a limit in your WiFI AP(s) on how many nodes you can handle simultaneously.
    • Henk BakkerH
      Henk BakkerH
      Henk Bakker
      I'm using the NRF24L01 for my setup because I don't want my "security grid" to go offline if my router for example breaks down. Next to that it's safer in my eyes to keep the 2 networks separated. It's easier to hack a wifi network than your own custom build security network.
      • neechN
        neechN
        neech
        You could still do that with a separate WiFi router, right? I am starting to think about a new system that will have a dedicated router for my "things".
        Henk BakkerH TheoLT 2 Replies Last reply
        • neechN neech
          Henk BakkerH
          Henk BakkerH
          Henk Bakker
          @neech Sure.
          Depending on your router you could even make a different VLAN with a different SSID and keep it seperated in this way. Only allow the most essential ports from one network to the other.
          • neechN neech
            TheoLT
            TheoLT
            TheoL
            wrote on last edited by TheoL
            @neech I'm extending my local Intranet Of Things eco-system, my conclusion is the same as yours. I'll be adding a separate local router. By that I'm also creating a DMZ, which will make it harder for hackers to get to my local network. And I'll be able to add a VPN in the DMZ. With the VPN I'll be able to connect to my local network when I'm not at home.
            Since I already want an extra router, I'll have no extra costs when I'll be adding some ESP8266 sensors. But my point is, that most people don't know how to add an extra router, besides it adds cost at least 100 dollar or more your solution. I haven't checked how much cheaper the ESP8266 is, but you'll have to take the extra cost for purchasing an extra router and the power consumption of that router into account. How many NRF24L01 sensors can you build for that kind of money?
            • AnticimexA
              AnticimexA
              Anticimex
              What about battery power? Is it on par with nrf24 and rfm69 with respect to power consumption?
              • neechN
                neechN
                neech
                It is true that the NRF24L01 use a lot less power (apparently). I haven't used them so I would be concerned about the range of these types of devices? How many gateways would I have to build to cover my whole home?
                On the Ethernet side, I am looking to do smart outlets: for that the ESP8266 makes sense because I could use the 120VAC power and convert it to 5VDC with a pretty small board using one of those transformer-less DC power supplies.
                Maybe I'll test both scenarios before scaling up.
                neech
                TheoLT 1 Reply Last reply
                • AnticimexA
                  AnticimexA
                  Anticimex
                  You only need one GW. If nodes are out of reach, use relay nodes. That's the whole point. The radios provide a mesh network.
                  • neechN neech
                    neech
                    TheoLT
                    TheoLT
                    TheoL
                    @neech The first answer is 1 Gateway. Depending on the size of your house you might need some repeater nodes. But you could also use the radio's with the larger antenna's. I have one larger antenna which is currently mounted to my Gateway. I installed it recently. Didn't have any troubles concerning the distance. But I'm planning on building a weather station. It just a better safe than sorry thing.
                    For smart IoT devices a Pi or Pi zero would make much more sense than an ESP8266. At least in my opinion. Until this moment I'm more than happy with the NRF24L01+ wouldn't change it.
                    • Henk BakkerH
                      Henk BakkerH
                      Henk Bakker
                      here is someone that did a test: https://hallard.me/nrf24l01-real-life-range-test/
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        Another option, would be to go with rfm69.. It's sub gHz, so it would have longer range (Even compared to esp8266). Power consumption is equal to nrf24 (as far as I know).
