  3. Why continue to use NRF24L01?
17 Posts 8 Posters 11.6k Views 8 Watching
  • TD22057T
    TD22057T
    TD22057
    @neech said:
    TD22057, I love this idea. However, how are you going to power the ESP? I'd like to do the same thing but don't want to take the thing out to replace a battery. I also don't want to try and fit a 5v or 3.3v power supply in there...just curious if you thought of that yet.
    Search for HLK-PM01 - there are a bunch of threads on how to power from 120/240V mains.
    • AnticimexA
      AnticimexA
      Anticimex
      You will also find out that there is a limit in your WiFI AP(s) on how many nodes you can handle simultaneously.
      • Henk BakkerH
        Henk BakkerH
        Henk Bakker
        I'm using the NRF24L01 for my setup because I don't want my "security grid" to go offline if my router for example breaks down. Next to that it's safer in my eyes to keep the 2 networks separated. It's easier to hack a wifi network than your own custom build security network.
        • neechN
          neechN
          neech
          You could still do that with a separate WiFi router, right? I am starting to think about a new system that will have a dedicated router for my "things".
          Henk BakkerH TheoLT 2 Replies Last reply
          • neechN neech
            Henk BakkerH
            Henk BakkerH
            Henk Bakker
            @neech Sure.
            Depending on your router you could even make a different VLAN with a different SSID and keep it seperated in this way. Only allow the most essential ports from one network to the other.
            • neechN neech
              TheoLT
              TheoLT
              TheoL
              wrote on last edited by TheoL
              @neech I'm extending my local Intranet Of Things eco-system, my conclusion is the same as yours. I'll be adding a separate local router. By that I'm also creating a DMZ, which will make it harder for hackers to get to my local network. And I'll be able to add a VPN in the DMZ. With the VPN I'll be able to connect to my local network when I'm not at home.
              Since I already want an extra router, I'll have no extra costs when I'll be adding some ESP8266 sensors. But my point is, that most people don't know how to add an extra router, besides it adds cost at least 100 dollar or more your solution. I haven't checked how much cheaper the ESP8266 is, but you'll have to take the extra cost for purchasing an extra router and the power consumption of that router into account. How many NRF24L01 sensors can you build for that kind of money?
              • AnticimexA
                AnticimexA
                Anticimex
                What about battery power? Is it on par with nrf24 and rfm69 with respect to power consumption?
                • neechN
                  neechN
                  neech
                  It is true that the NRF24L01 use a lot less power (apparently). I haven't used them so I would be concerned about the range of these types of devices? How many gateways would I have to build to cover my whole home?
                  On the Ethernet side, I am looking to do smart outlets: for that the ESP8266 makes sense because I could use the 120VAC power and convert it to 5VDC with a pretty small board using one of those transformer-less DC power supplies.
                  Maybe I'll test both scenarios before scaling up.
                  neech
                  TheoLT 1 Reply Last reply
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    You only need one GW. If nodes are out of reach, use relay nodes. That's the whole point. The radios provide a mesh network.
                    • neechN neech
                      neech
                      TheoLT
                      TheoLT
                      TheoL
                      @neech The first answer is 1 Gateway. Depending on the size of your house you might need some repeater nodes. But you could also use the radio's with the larger antenna's. I have one larger antenna which is currently mounted to my Gateway. I installed it recently. Didn't have any troubles concerning the distance. But I'm planning on building a weather station. It just a better safe than sorry thing.
                      For smart IoT devices a Pi or Pi zero would make much more sense than an ESP8266. At least in my opinion. Until this moment I'm more than happy with the NRF24L01+ wouldn't change it.
                      • Henk BakkerH
                        Henk BakkerH
                        Henk Bakker
                        here is someone that did a test: https://hallard.me/nrf24l01-real-life-range-test/
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Another option, would be to go with rfm69.. It's sub gHz, so it would have longer range (Even compared to esp8266). Power consumption is equal to nrf24 (as far as I know).
