  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 75.0k Views 33 Watching
  • FrancoisF
    FrancoisF
    Francois
    Hi I am new to openHAB how do you configure a relay node? I do see the node in the logs but the relay don't what to switch on or off. I have my temp and humidity sensors working already.
    18:38:50.450 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Dimmable device of some kind): node-id=95, sensor-id=0 with type S_DIMMER
     * Example item: 95;0;V_STATUS             - Binary status. (on/off)
     * Example item: 95;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
     * Example item: 95;0;V_WATT               - Watt value for power meters
    Regards
    Francois
    • Mark JeffordM
      Mark JeffordM
      Mark Jefford
      Quick question, trying to integrate the mysprinkler project into openhab.
      getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
      i have the triggering working, just can't configure the runtime.
      any help appreciated.. will do a guide if it get it working :)
      • Harry GomezH
        Harry GomezH
        Harry Gomez
        I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
        2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
        2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
        [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
        [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
        [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
        [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
        [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
        [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
        regards
        Harry
        • Harry GomezH Harry Gomez
          regards
          Harry
          ted
          @Harry-Gomez
          From https://github.com/openhab/openhab/wiki/Serial-Binding
          If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
          -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0
          whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
          Harry GomezH 1 Reply Last reply
          • T ted
            @Harry-Gomez
            Harry GomezH
            Harry GomezH
            Harry Gomez
            I tried that but it did not work - this is how part of the /etc/init.d/openhab looks - any other ideas - i did not needed this with the RPi2 and wheezy
            JAVA_ARGS_DEFAULT="-Dosgi.clean=true
            -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0
            -Declipse.ignoreApp=true
            -Dosgi.noShutdown=true
            -Djetty.port=${HTTP_PORT}
            -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
            -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
            -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
            -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
            -Djetty.home="${OPENHAB_DIR}"
            -Djetty.port.ssl=${HTTPS_PORT}
            -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
            -Djetty.logs="${OPENHAB_LOG_DIR}"
            -Djetty.rundir="${OPENHAB_DIR}"
            -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
            -Dfelix.fileinstall.filter=.*\.jar
            -Djava.library.path="${OPENHAB_DIR}/lib"
            -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
            -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
            -Dequinox.ds.block_timeout=240000
            -Dequinox.scr.waitTimeOnBlock=60000
            -Dfelix.fileinstall.active.level=4
            -Djava.awt.headless=true
            -jar ${LAUNCHER}
            -configuration ${OPENHAB_WORKSPACE_DIR}
            -data ${OPENHAB_WORKSPACE_DIR}
            -console ${TELNET_PORT}"
              -jar ${LAUNCHER}
              ted
              @Harry-Gomez
              What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
              Harry GomezH zeblongZ 2 Replies Last reply
              • T ted
                @Harry-Gomez
                Harry GomezH
                Harry GomezH
                Harry Gomez
                @ted
                Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
                Thanks!!
                • FrancoisF
                  FrancoisF
                  Francois
                  wrote on last edited by Francois
                  #32
                  Hi what is the syntax for a relay in openhab using this binding?
                  This in what I get in the log but the light do not switch on or off.
                  2016-03-27 20:37:00.068 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                  2016-03-27 20:37:00.889 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                  2016-03-27 20:37:01.622 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                  2016-03-27 20:37:02.407 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                  2016-03-27 20:37:03.247 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                  This is the syntax that I am use and it is not working. Also try V_LIGHT without any luck.
                  Switch LightSwitch_GF_Study	"Study Light  [%s]"				<light> 	(GF_Study)			{mysensors="41;1;V_BINARY"}
                  andredtsA bklB 2 Replies Last reply
                  • FrancoisF Francois
                    andredtsA
                    andredtsA
                    andredts
                    @Francois
                    Hi, I use {mysensors="12;0;V_STATUS"}. Remember to give your node a ID, because OH does not give one.
                      bklB
                      bklB
                      bkl
                      Hi @Francois
                      The syntax look OK.
                      This is what i have working.
                      Switch  Relay_10_0              "Relay 1"                       <none>                                  {mysensors="10;0;V_STATUS"}
                      Try and turn on debug log for mysensors
                      Add this to logback.xml
                      <logger name="org.openhab.binding.mysensors" level="DEBUG" />
                      • FrancoisF
                        FrancoisF
                        Francois
                        Hi @bkl
                        Are you using the standard relay sketch with this binding or did you change anything in the sketch as I just don't get my relay to work.
                        Here is my log with the above string in my logback.xml.
                        17:28:48.825 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor node found: node-id=15
                         * Example item: 15;255;I_BATTERY_LEVEL      - Use this to report the battery level 0-100 (%)
                         * Example item: 15;255;I_SKETCH_NAME        - Sketch name that can be used to identify sensor
                         * Example item: 15;255;I_SKETCH_VERSION     - Sketch version that can be reported to keep track of the version of sensor
                        17:28:48.827 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        17:28:50.856 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=11,pt=0,l=25,sg=0:Main Bedroom Relay & Butt
                        17:28:50.858 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_NAME"
                        17:28:50.860 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
                        17:28:50.862 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_VERSION"
                        17:28:50.864 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                        17:28:50.867 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Binary device (on/off)): node-id=15, sensor-id=1 with type S_BINARY
                         * Example item: 15;1;V_STATUS             - Binary status. (on/off)
                         * Example item: 15;1;V_WATT               - Watt value for power meters
                        17:28:51.457 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'LightSwitch_GF_Study' with state 'ON' in rrd4j database (again)
                        17:28:51.460 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                        17:28:51.500 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                        17:28:51.503 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        17:28:51.719 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:29.1
                        17:28:51.722 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Hum_GF_Study = 29.1
                        17:28:51.729 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'Hum_GF_Study' with state '29.1' in rrd4j database
                        17:28:51.760 [INFO ] [runtime.busevents             :26   ] - Hum_GF_Study state updated to 29.1
                        17:28:51.762 [DEBUG] [.b.m.internal.MySensorsBinding:248  ] - internalReceiveUpdate(Hum_GF_Study,29.1) is called!
                        17:28:51.862 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                        17:28:51.864 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        17:28:52.045 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                        17:28:52.075 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                        17:28:52.077 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        17:28:52.252 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                        17:28:52.255 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        17:28:52.448 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                        17:28:52.451 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        17:28:52.648 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        17:28:52.650 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                        17:28:52.654 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        17:28:52.659 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Motion_GF_Study = ON
                        17:28:52.662 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'Motion_GF_Study' with state 'OFF' in rrd4j database (again)
                        • bklB bkl
                          @BastienVH
                          Note2: If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                          skatunS
                          skatunS
                          skatun
                          @bkl
                          So my question (linux newbie) is what is the best way to attach my Arduino nano to rpi, so that it always find it on reboot or if it is unplugged/replugged.
                          Is this correct and will this work with the binding?
                          /etc/udev/rules.d/99-usb-serial.rules"
                          with my device info:
                          SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A40360T2", SYMLINK+="ttyUSB99"
                          • T ted
                            @Harry-Gomez
                            zeblongZ
                            zeblongZ
                            zeblong
                            @ted
                            Hi
                            I use RASPBIAN JESSIE.
                            Command minicom -b 115200 -o -D /dev/ttyUSB0 show traffic from serial gateway.
                            I write -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 to /usr/share/openhab/bin/openhab.sh and /etc/init.d/openhab but still 'Unable to find Serial port '/dev/ttyUSB0''.
                            Please help me
                            • zeblongZ zeblong
                              @ted
                              Hi
                              Please help me
                              Harry GomezH
                              Harry GomezH
                              Harry Gomez
                              wrote on last edited by Harry Gomez
                              #38
                              @zeblong
                              for me I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0\ right at the begining for it to work at usr/share/openhab/bin/openhab.sh - i removed from /etc/init.d/openhab it did not make a difference. below is how it looks for me. also check the output if dmesg for changes in tty. I also use jessie on a RPi3
                              -Duser.timezone=America/Los_Angeles
                              -jar ${LAUNCHER}
                              -console ${TELNET_PORT}" \
                              ~ $ dmesg |grep tty
                              [ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x71ef84a5 smsc95xx.macaddr=B8:27:EB:EF:84:A5 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                              [ 0.001288] console [tty1] enabled
                              [ 0.267235] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
                              [ 0.919548] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
                              [ 2.166808] systemd[1]: Starting system-getty.slice.
                              [ 2.170421] systemd[1]: Created slice system-getty.slice.
                              [ 3.635870] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
                              zeblongZ bklB 2 Replies Last reply
                                @zeblong
                                -jar ${LAUNCHER}
                                ~ $ dmesg |grep tty
                                zeblongZ
                                zeblongZ
                                zeblong
                                @Harry-Gomez
                                That's all well done. does not work. It may be necessary to install any more bindings or the Java packages?
                                • zeblongZ zeblong
                                  @Harry-Gomez
                                  Harry GomezH
                                  Harry GomezH
                                  Harry Gomez
                                  @zeblong
                                  Do you have the serial package installed --> org.openhab.io.transport.serial-1.8.2.jar?
                                  Did you add openhab to dialout group -> sudo usermod -a -G dialout openhab
                                  What is the error on you logs?
                                  zeblongZ 1 Reply Last reply
                                  • FrancoisF
                                    FrancoisF
                                    Francois
                                    #41
                                    All my temp motion and humidity sensor work but my relay and dimmer sensor don't work, why will this be the case? Here is the log:
                                    2016-04-03 09:25:07.928 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:07.930 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:08.186 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:08.406 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:08.527 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:08.539 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:08.584 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:08.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:08.625 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:08.802 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:09.247 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:09.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:10.421 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:10.899 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:11.410 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:11.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:11.594 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:11.829 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:12.513 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:12.840 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:12.841 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                    2016-04-03 09:25:13.145 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                    2016-04-03 09:25:13.394 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:13.422 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:17.880 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:17.882 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:18.025 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:18.536 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:18.538 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:18.541 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:22.736 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:22.737 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                    2016-04-03 09:25:23.021 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:1
                                    2016-04-03 09:25:23.022 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = ON
                                    2016-04-03 09:25:23.033 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                    2016-04-03 09:25:23.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,ON) is called!
                                    2016-04-03 09:25:23.765 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=5,c=1,t=38,pt=7,l=5,sg=0:2.90
                                    2016-04-03 09:25:23.766 [DEBUG] [.b.m.internal.MySensorsBinding] - MotionBatVcc_GF_Study = 2.90
                                    2016-04-03 09:25:23.937 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(MotionBatVcc_GF_Study,2.90) is called!
                                    2016-04-03 09:25:26.984 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:26.985 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:27.203 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:27.648 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=17,pt=5,l=4,sg=0:315
                                    2016-04-03 09:25:27.651 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_WATT"
                                    2016-04-03 09:25:27.653 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:29.284 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=24,pt=5,l=4,sg=0:2718269
                                    2016-04-03 09:25:29.286 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_VAR1"
                                    2016-04-03 09:25:31.838 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:31.840 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                    2016-04-03 09:25:32.184 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                    2016-04-03 09:25:33.022 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:0
                                    2016-04-03 09:25:33.024 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = OFF
                                    2016-04-03 09:25:33.326 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,OFF) is called!
                                    2016-04-03 09:25:35.140 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:35.141 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:35.447 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:35.556 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                    2016-04-03 09:25:35.557 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                    2016-04-03 09:25:35.561 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                    2016-04-03 09:25:36.738 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:36.851 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:37.297 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:37.324 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:37.758 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:37.962 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:38.434 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:38.454 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                    2016-04-03 09:25:38.877 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                    2016-04-03 09:25:39.995 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:40.045 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                    2016-04-03 09:25:40.341 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                    2016-04-03 09:25:40.590 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:40.591 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                                    2016-04-03 09:25:40.595 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                                    2016-04-03 09:25:41.596 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.4
                                    2016-04-03 09:25:41.597 [DEBUG] [.b.m.internal.MySensorsBinding] - Hum_GF_Study = 43.4
                                    2016-04-03 09:25:41.852 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Hum_GF_Study,43.4) is called!
                                    2016-04-03 09:25:43.390 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                    2016-04-03 09:25:43.392 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                                    2016-04-03 09:25:43.395 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                                    bklB 1 Reply Last reply
                                      @zeblong
                                      zeblongZ
                                      zeblongZ
                                      zeblong
                                      @Harry-Gomez
                                      Many thanks.
                                      Line 'sudo usermod -a -G dialout openhab' helped me.
                                        bklB
                                        bklB
                                        bkl
                                        Hi @Francois
                                        Yes i am using the standard relay sketch.
                                        I thing i found you problem, try and change V_BINARY to V_STATUS
                                          @zeblong
                                          -jar ${LAUNCHER}
                                          ~ $ dmesg |grep tty
                                          bklB
                                          bklB
                                          bkl
                                          Hi @Harry-Gomez
                                          If you make a guide to make openhab work with a non standard serial port, then i will make it part of the first post.
