  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
    If you are worried about Program Space you can turn off Serial debug to rid yourself of a bunch of overhead in the sketch. I am not using String class so there is PLENTY of RAM and I've been using this for a while with no stack corruption issues:
    #define DEBUG_ON   // comment out to surpress serial monitor output
    if you propose to turn ON the master valve when each valve is cycled on, then I believe all you need to do is add that valve to the bitmask (logical OR) each time you updateRelays().
    void updateRelays(int value)
      if(value)
        value |= 0b0000000010000000;  // master is the eighth relay, there are 7 controlled in this example (active HIGH in this example)
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
    not tested
    fusion_manF
    fusion_manF
    fusion_man
    @BulldogLowell
    By commenting out the DEBUG, it went from 99% to 63% used memory.
    The modification to void updateRelays worked very nicely. I only wish the master control valve would remain ON during cycling through each valve (subjected to VALVE_RESET_TIME) as I am using it to control a chemical feed pump to prevent hydrogen proxide (30%) from entering my irrigation system.
    Awesome job and I am very pleased with your design.
    The only problem I had when building the controller was getting the LCD to communicate.
    I added this comment to my program under Instructions.
    • If your LCD is unresponsive, download sketch http://forum.arduino.cc/index.php?topic=128635.0 then check serial monitor for LCD address. Insert your address below.
        if(value)
      not tested
      fusion_manF
      fusion_manF
      fusion_man
      @BulldogLowell
      I ended up going a different approach. I modified the program so I could use Arduino digital pin6 as an output powering my master valve relay. I then added digitalWrite (masterValvePin, HIGH) where you have updateRelays(BITSHIFT_VALVE_NUMBER) to turn ON the valve. To turn off the valve I added a delay then digitalWrite (masterValvePin, LOW) to if (state == STAND_BY_ALL_OFF). This has tested perfectly for my situation.
      The only thing missing from the Controller is the ability to add the RainBird rain sensor to the board. I think the way of achieving this is an input to my Vera controller.
      • fusion_manF fusion_man
        @BulldogLowell
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @fusion_man
        maybe we can add a rain sensor this season. It is a good idea to include it.
        fusion_manF 1 Reply Last reply
          @fusion_man
          fusion_manF
          fusion_manF
          fusion_man
          @BulldogLowell
          I already did and it is up and running. I used A0 as the input for the rain sensor. I can see the rain sensor in Vera as a motion sensor. I didn't post the code as I didn't want to offend the designer. Being a newbie, I didn't know how to handle this update.
            @BulldogLowell
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @fusion_man
            why not just post your code? I'm sure the guy who wrote the original code won't mind, if you include his original notes and credits.
            • Mark JeffordM
              Mark JeffordM
              Mark Jefford
              Quick question, semi also referenced on the openhab binding.
              Looking to use this with Openhab, I have managed to get it to work with the serial gateway, however i don't see a way i can pass out any configuration of a valve time, i can however trigger valves with a runtime of 0 seconds.
              Any ideas how i can amend this to either use a fixed runtime in the project (happy to run it in 1min increments trigged from openhab hydro sensor results)
              • Mark JeffordM Mark Jefford
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @Mark-Jefford
                In that case, I would just treat each zone as a separate relay/lamp and use Openhab to control the individual ON times... I think.
                johnecyJ Mark JeffordM 2 Replies Last reply
                  @Mark-Jefford
                  johnecyJ
                  johnecyJ
                  johnecy
                  can I use pin D6 instead ok pin D8 to control the shift register. I am making the controller on the easy/newbie pc board and there is nothing connected to pin D8 on this board.
                  • johnecyJ johnecy
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @johnecy
                    const int latchPin = 8;
                    I think you should be OK to try that
                    johnecyJ 1 Reply Last reply
                      @johnecy
                      johnecyJ
                      johnecyJ
                      johnecy
                      @BulldogLowell thanks for the reply i will post pictures when i get it finished
                        @Mark-Jefford
                        Mark JeffordM
                        Mark JeffordM
                        Mark Jefford
                        wrote on last edited by Mark Jefford
                        #126
                        @BulldogLowell
                        Gave up with using openhab now using domoticz which is a lot nicer, forced it to hard coded run times by doing this:
                        int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" = "));
                        DEBUG_PRINTLN(variable1);
                        allZoneTime[i] = variable1;
                              zoneTimeUpdate = true;
                            int variable2 = 5; //atoi(message.data);// RUN_SINGLE_ZONE time
                            DEBUG_PRINT(i);
                            DEBUG_PRINTLN(variable2);
                              valveSoloTime[i] = variable2;
                        one thing to note the shift register 0b0000000010000000 does not seem to work, will work out a plan around this as i need to run a 12 pump off the relay bank to draw water from the water butt.
                          @BulldogLowell
                          DEBUG_PRINT(i);
                              DEBUG_PRINT(i);
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          Can you explain more? is there a bug?
                          Mark JeffordM 1 Reply Last reply
                            Mark JeffordM
                            Mark JeffordM
                            Mark Jefford
                            @BulldogLowell
                            Hi! :)
                            Rather than using valve 8, i am using only a block of 4, but currently have a 2 channel for testing.
                            My reading into shift registers showed 0b0000000010000000 is 2x 8 bit outputs, B0-B7
                            tried configuing B0 and B7 to try and activate relay 1, was still seeing 5V on all pins apart from the output pin for the zone in use (EG zone 2 expecting Zone1 to alway be on)
                            or am i doing this completely wrong? :)
                              @BulldogLowell
                              Hi! :)
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @Mark-Jefford
                              hmmm... are your relays ACTIVE HIGH (actuate wiht a 5V signal) or ACTIVE LOW (actuate when brought to ground) type?
                                @Mark-Jefford
                                Mark JeffordM
                                Mark JeffordM
                                Mark Jefford
                                @BulldogLowell
                                Oh, well this is strange, if i disconnect the pin to the relay, it does not activate when unpowered.
                                but from the shift register it is +5 when the zone is not active, and 0V when active, so i assume its an active low not active high by your example... surely removing the 5V feed to the relay pin should make it activate.. not sure whats going on there, some sort of black magic :P
                                My reading of shift registers has made my brain hurt.. do i need to reverse the 0000000010000000 for 1111111101111111?
                                • rechin304R
                                  rechin304R
                                  rechin304
                                  Dear all,
                                  i have trying to make the irrigation controller to start all zones in same time and run for the specified. I'm using version for domoticz. Can you please help me out with hint of what i can change in the code ?
                                  Another thing is that from domoticsz when i start a zone that zone start and previous is stopped but that status is not updated.
                                  Thank you in advance.
                                  P.S. I will post some pictures of the hardware build soon.
                                  • rechin304R rechin304
                                    Dear all,
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @rechin304
                                    have you tried changing the eight to one?
                                    #define NUMBER_OF_VALVES 8  // Change this to set your valve count up to 16.
                                    trigger all your relays with the same output.
                                    • rechin304R
                                      rechin304R
                                      rechin304
                                      Well, that's not the point.
                                      I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they will finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
                                      To start all valve at once when is trigger all zones i did change:
                                          if (lastValve != valveNumber)
                                                gw.send(msg1valve.setSensor(i).set(true), false);
                                                gw.send(msg1valve.setSensor(i).set(false), false);
                                          lastValve = valveNumber;
                                          fastToggleLed();
                                          if (state != lastState)
                                            valveNumber = 1;
                                            updateRelays(ALL_VALVES_OFF);
                                      with
                                                gw.send(msg1valve.setSensor(i).set(true), false); //to update domoticz
                                          fastToggleLed();
                                            valveNumber = 1;
                                            updateRelays(0); //all outputs will be on
                                            fastToggleLed();
                                              valveNumber = 1;
                                        with
                                            fastToggleLed();
                                              valveNumber = 1;
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        I will have 4 zones that need different type of water needs. For example one zone will be with micro irrigation watering, another one with lawn sprinkler. i do not understand why not to start all zones at once and they wi finish according to the time set and not to start one after other. Another thing is why to wait for a zone to finish when you trigger another one.
                                        I see your point an understand your questions. The purpose of zone cycling is to be able to have enough pressure in each zone independently while also having pressure for household use. Drawing water to every zone (in my case 9) makes the pressure so low, there may not be enough to open the individual pop-up valves, much less fill the washing machine.
                                        The wait period (which you may set) is there to allow the time for hydraulic actuation of solenoid valves. These types of valves close slowly, and since they are in a manifold, the next valve to start opens faster if the water pressure at the manifold is allowed time to reach normal static pressure.
                                        The beauty of open source is that you get to do it your way. If you have the pressure to run all your valves at the same time, with enough to spare to take a shower, then you are fortunate!
                                        So, did you add another 'switch' to your controller to send the all zone command?
                                        • rechin304R
                                          rechin304R
                                          rechin304
                                          I did this so all relays on is ok now.
                                          What i miss is to start individual zones more than once at a time :).
