  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
  • C
    C
    charlybrown
    Excellent work. I need help with android code. Anybody can help me with this?
    thanks
      shemmozhipandian
      I made the circuit, but later i realize it required vera controller to sync all the data. Is there other way or idea to send data to the built system.
      petewillP 1 Reply Last reply
      • S shemmozhipandian
        petewillP
        petewillP
        petewill
        @shemmozhipandian Sorry for the delayed reply. It does require a controller (like Vera) but there are free ones out there. Take a look here: http://www.mysensors.org/controller/
        I know Domoticz is free and seems to be fairly popular here. There are others as well. If you find one you like you may want to write a quick post to check compatibility. I personally use Vera so I'm not sure how the others work.
          A Former User
          Hello Pete, thanks for your hard work on this. Superb!
          I want to build a irrigation controller like your project but can't figure out hows the wiring. On the wiki an image is shown but I can't see what the connections are in this "virtual proto board"
          Is there something clearer or like a pinout to pin list?
          I'm using an Arduino Nano, so things will be something different.
          Thank you very much.
          • ? A Former User
            petewillP
            petewillP
            petewill
            @Sergio Jim (@BulldogLowell) posted some more details above but here is my fritzing project as well. Hopefully you can zoom in where you need to see more.
            Fritzing Irrigation Controller Wiring.fzz
              A Former User
              wrote on last edited by [[global:former-user]]
              #112
              Mmm... I finally assembled the device. But I'm having problems with it. It doesn't activate/deactivates the relays. I'm getting the power for the relay board from the nano itself. Could that be the problem?
              Also, my domoticz doesn't receive the off signal from the controller. (doens't turn the light off) and sometimes throws some error telling that can't contact the node.
              BTW I tried to contac Bulldogloweel without success :sob:
              • ? A Former User
                petewillP
                petewillP
                petewill
                Yes, that is most likely the problem. Most of the relays I have used need more power than what the arduino can supply. Try feeding it more power (like from a phone charger).
                Check the serial monitor with debug enabled. Does this happen every time? It could be radio issues. Do you have a 4.7uf cap on the radio? Is it close enough to your gateway?
                  @moffen666
                  I don't have Domoticz but I suspect that the callback isn't functioning.
                  try populating the array with the desired times for each sequence. replace this:
                  int allZoneTime [NUMBER_OF_VALVES + 1];
                  int valveSoloTime [NUMBER_OF_VALVES + 1];
                  with something like this:
                  int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
                  int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
                  This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
                  fusion_manF
                  fusion_manF
                  fusion_man
                  @BulldogLowell
                  I need to add a relay for a master valve. This will open when any zone valves open. I think it could be mapped to All On 0(1) but I am not sure how to accomplish this. I don't know the code for that or electrical connection. I also noticed we are about maxed out of data (99%) using ProMini. Any ideas?
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    #115
                    If you are worried about Program Space you can turn off Serial debug to rid yourself of a bunch of overhead in the sketch. I am not using String class so there is PLENTY of RAM and I've been using this for a while with no stack corruption issues:
                    #define DEBUG_ON   // comment out to surpress serial monitor output
                    if you propose to turn ON the master valve when each valve is cycled on, then I believe all you need to do is add that valve to the bitmask (logical OR) each time you updateRelays().
                    void updateRelays(int value)
                      if(value)
                        value |= 0b0000000010000000;  // master is the eighth relay, there are 7 controlled in this example (active HIGH in this example)
                      digitalWrite(latchPin, LOW);
                      digitalWrite(latchPin, HIGH);
                    not tested
                    fusion_manF 2 Replies Last reply
                        if(value)
                      not tested
                      fusion_manF
                      fusion_manF
                      fusion_man
                      @BulldogLowell
                      By commenting out the DEBUG, it went from 99% to 63% used memory.
                      The modification to void updateRelays worked very nicely. I only wish the master control valve would remain ON during cycling through each valve (subjected to VALVE_RESET_TIME) as I am using it to control a chemical feed pump to prevent hydrogen proxide (30%) from entering my irrigation system.
                      Awesome job and I am very pleased with your design.
                      The only problem I had when building the controller was getting the LCD to communicate.
                      I added this comment to my program under Instructions.
                      • If your LCD is unresponsive, download sketch http://forum.arduino.cc/index.php?topic=128635.0 then check serial monitor for LCD address. Insert your address below.
                          if(value)
                        not tested
                        fusion_manF
                        fusion_manF
                        fusion_man
                        @BulldogLowell
                        I ended up going a different approach. I modified the program so I could use Arduino digital pin6 as an output powering my master valve relay. I then added digitalWrite (masterValvePin, HIGH) where you have updateRelays(BITSHIFT_VALVE_NUMBER) to turn ON the valve. To turn off the valve I added a delay then digitalWrite (masterValvePin, LOW) to if (state == STAND_BY_ALL_OFF). This has tested perfectly for my situation.
                        The only thing missing from the Controller is the ability to add the RainBird rain sensor to the board. I think the way of achieving this is an input to my Vera controller.
                        • fusion_manF fusion_man
                          @BulldogLowell
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @fusion_man
                          maybe we can add a rain sensor this season. It is a good idea to include it.
                          fusion_manF 1 Reply Last reply
                            @fusion_man
                            fusion_manF
                            fusion_manF
                            fusion_man
                            @BulldogLowell
                            I already did and it is up and running. I used A0 as the input for the rain sensor. I can see the rain sensor in Vera as a motion sensor. I didn't post the code as I didn't want to offend the designer. Being a newbie, I didn't know how to handle this update.
                              @BulldogLowell
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @fusion_man
                              why not just post your code? I'm sure the guy who wrote the original code won't mind, if you include his original notes and credits.
                              • Mark JeffordM
                                Mark JeffordM
                                Mark Jefford
                                Quick question, semi also referenced on the openhab binding.
                                Looking to use this with Openhab, I have managed to get it to work with the serial gateway, however i don't see a way i can pass out any configuration of a valve time, i can however trigger valves with a runtime of 0 seconds.
                                Any ideas how i can amend this to either use a fixed runtime in the project (happy to run it in 1min increments trigged from openhab hydro sensor results)
                                • Mark JeffordM Mark Jefford
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  @Mark-Jefford
                                  In that case, I would just treat each zone as a separate relay/lamp and use Openhab to control the individual ON times... I think.
                                  johnecyJ Mark JeffordM 2 Replies Last reply
                                    @Mark-Jefford
                                    johnecyJ
                                    johnecyJ
                                    johnecy
                                    can I use pin D6 instead ok pin D8 to control the shift register. I am making the controller on the easy/newbie pc board and there is nothing connected to pin D8 on this board.
                                    • johnecyJ johnecy
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @johnecy
                                      const int latchPin = 8;
                                      I think you should be OK to try that
                                      johnecyJ 1 Reply Last reply
                                        @johnecy
                                        johnecyJ
                                        johnecyJ
                                        johnecy
                                        @BulldogLowell thanks for the reply i will post pictures when i get it finished
                                          @Mark-Jefford
                                          Mark JeffordM
                                          Mark JeffordM
                                          Mark Jefford
                                          wrote on last edited by Mark Jefford
                                          #126
                                          @BulldogLowell
                                          Gave up with using openhab now using domoticz which is a lot nicer, forced it to hard coded run times by doing this:
                                          int variable1 = 5; // atoi(message.data);// RUN_ALL_ZONES time
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F(" = "));
                                          DEBUG_PRINTLN(variable1);
                                          allZoneTime[i] = variable1;
                                                zoneTimeUpdate = true;
                                              int variable2 = 5; //atoi(message.data);// RUN_SINGLE_ZONE time
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINTLN(variable2);
                                                valveSoloTime[i] = variable2;
                                          one thing to note the shift register 0b0000000010000000 does not seem to work, will work out a plan around this as i need to run a 12 pump off the relay bank to draw water from the water butt.
