  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.4k Views 6 Watching
    @drock1985
    :thumbsup:
    When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
    Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
    If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
    pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
    or if you want to install as root:
    sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
    This way you should be able to autostart the usual way, per instructions on the web.
    But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
    Dave DanD
    Dave DanD
    Dave Dan
    wrote on last edited by Dave Dan
    #35
    Hey @martinhjelmare
    Does the above reply to @drock1985 means that I can do a basic installation as per https://home-assistant.io/
    pip3 install homeassistant
    hass --open-ui
    followed by
    and will have a valid testing env without going into all the above steps of creating a virtualenv??
    If so I'd rather more this avenue because I can clean up everything with a new installation, install the zip and have a new testing env in minutes :)
    martinhjelmareM 2 Replies Last reply
    • Dave DanD Dave Dan
      Hey @martinhjelmare
      hass --open-ui
      followed by
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Dave-Dan
      I can't see any big issues with your sketch, just one small:
      I guess this is a typo:
      #defin TEMP_CORRECTION 2
      Since your sketch looks ok, I think something must have gone wrong with the communication between node and gateway. Have you been monitoring the comm, with a serial monitor, on the node side for example, to make sure all messages are sent ok?
      Dave DanD 1 Reply Last reply
        Hey @martinhjelmare
        hass --open-ui
        followed by
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @Dave-Dan
        The zip file you install from my github account, is the mysensors tcp gateway branch of home-assistant. So you shouldn't install home-assistant first, if you're going to install my branch.
        If you don't have any other version of home-assistant that you wish to keep, on the same computer, you can install my branch directly. You just have to make sure you uninstall it and remove ~/.homeassistant/lib before installing an update from me, if I commit some updates.
        Yeah, setting up a dev machine can be a hassle the first time, and not so useful if you're not developing with it.
          @Dave-Dan
          Dave DanD
          Dave DanD
          Dave Dan
          @martinhjelmare
          thanks for the hint ... definetly a typo :$
          Yes, I'm monitoring the GW with MYSController as my GW is ethernet and I see all messages showing with no issue. But, I'll be happy to review again. :)
            @martinhjelmare
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @Dave-Dan
            Yes, please start from the beginning:
            Remove the persistence file
            Start hass
            Wait until you see that hass has (:smile:) connected to the gateway
            Start a node
            Start the next node
            If you can post the serial log from that here, and also the log from hass, that would be great.
            • D
              drock1985
              @martinhjelmare
              Haven't had any issues with the sensors I have on my Dev unit; so far so good.
              Are you thinking of releasing the ethernet GW code in this weeks update?
              My Projects
              2 Door Chime Sensor
              Washing Machine Monitor
              • Andrew SanjanwalaA
                Andrew SanjanwalaA
                Andrew Sanjanwala
                @martinhjelmare
                Though I'm eager to try, I can't actually launch the Ethernet Gateway branch in a Windows environment. The best error I can provide is the generic failed to create process on calling hass. Platform is Windows Home Server 2011 running Python 3.5.1. All previous and current release branches of home assistant launch without error.
                Any thoughts or other steps I can take to debug it further?
                • D drock1985
                  @martinhjelmare
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @drock1985
                  Good to hear. Have you tried connecting more than one node to the gateway at the same time?
                  Unfortunately I don't think it will make this release, cause I won't have time until Sunday, and the release might be finished before that. I will add some updates this weekend that you are welcome to try. After that we should be ready for release.
                  • Andrew SanjanwalaA Andrew Sanjanwala
                    @martinhjelmare
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @Andrew-Sanjanwala
                    My experience with python on Windows is very limited. How do you normally start home assistant?
                      Andrew SanjanwalaA
                      Andrew Sanjanwala
                      @martinhjelmare
                      I typically launch either using hass or hass --open-ui from an administrative powershell session. No-go in either of these two cases.
                        @martinhjelmare
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Andrew-Sanjanwala
                        Did you install directly from my github branch using pip?
                          Andrew SanjanwalaA
                          Andrew Sanjanwala
                          Alright, false alarm. Root issue in my case was a faulty environment and/or operator that resulted in binaries being compiled for the wrong platform.
                          Once corrected, it compiled and launched your branch and connected to the gateway without incident. Next up is experimenting with the nodes and actuators. I'll see if the persistence file can be written to.
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @Andrew-Sanjanwala
                            :thumbsup:
                            • Dave DanD
                              Dave DanD
                              Dave Dan
                              Hey @martinhjelmare,
                              I've been able to do some tests this time.
                              From a Sensoring standpoint (retreive information from sensors to show in dashboard) works perfetly fine.
                              I found the issue that I was referring before.
                              Let's say you have already included a number of nodes and everything is working but for any reason you want to reset and start again. My logic was to remove the MSPersistance.json file, create a new one and the system will reconfigure again.
                              What I'm seeing is that if you do that the system enters in a limbo situation where no nodes are added but those that were beforer are not added either. you can't see them in the dashboard nor in the Developers Tools section.
                              Next step is to start testing relays, dimmers, etc.
                              Let me know if you need more detils on the scenario.
                              thanks!
                                thanks!
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                Can you describe more in detail how you did this? Do you have an example persistence file before and after your modifications?
                                • Dave DanD
                                  Dave DanD
                                  Dave Dan
                                  Sure!
                                  the persistence once I've added some nodes looks like this:
                                  {"104": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "38.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "34"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 104, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "106": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "37.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "5"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 9, "sensor_id": 106, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "156": {"sketch_version": null, "children": {}, "battery_level": 0, "sensor_id": 156, "type": 17, "sketch_name": null}, "101": {"sketch_version": "1.2", "children": {"0": {"id": 0, "values": {"1": "34.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "21.0"}, "type": 6}, "2": {"id": 2, "values": {}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 101, "type": 17, "sketch_name": "dyaSensor (HTLM) v1.2"}, "102": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "36.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "18.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "69"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 2, "sensor_id": 102, "type": 17, "sketch_name": "dyaSensor (HTLM)"}}
                                  after my modification (meaning, clear everything) looks this way:
                                    Sure!
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @Dave-Dan
                                    Did you do it like this?
                                    1. Stop hass.
                                    2. Remove old persistence file.
                                    3. Create new persistence file with the same name and path, containing an empty JSON object, "{}".
                                    4. Start hass.
                                    5. Start node. Result: Messages are coming in to gateway, but node sensors are not added to entities nor shown in GUI.
                                    • Dave DanD
                                      Dave DanD
                                      Dave Dan
                                      #52
                                      Exactly that.
                                      maybe something to do with the fact that those items are already included in the DB (for history, etc) and the system can't add them again? (just guessing)
                                      One more thing.
                                      If I move the file and create a new one instead of deleting it. And after trying to add the items again I stop everything and restore the backup everything works again.
                                        Exactly that.
                                        One more thing.
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Dave-Dan
                                        I don't know yet, but I'll try to reproduce this and figure it out. Thanks for this report, and taking your time to test this.
                                        I haven't had time to push my latest commits, that I had planned. I want to just test them quickly on my side before I push. But since you experience this problem, I think it's best to troubleshoot this first, before I push any new commits.
                                        I'll post back here, once I have more info.
                                        • Dave DanD
                                          Dave DanD
                                          Dave Dan
                                          hey @martinhjelmare,
                                          would it be possible to have an updated compilation with the 0.16 versión? I think the one you have above is 0.15 still (or older, right?)
                                          I'd like to do more testing and integrate other items (for example the new Vera integration) with MySensors actuations, etc.
                                          thanks in advance.
