Any plan to implement Ethernet GW?
I tried manually installing Netdisco, but it won't compile. I get an error complaining about gcc failing with error status 1.
The config file it looks for is in my normal home folder (which I assume is correct). The only error in the log is that it could not initialize discovery because dependency netdisco 0.5.2 could not be installed.
I think I will try this again tomorrow with Debian or Ubuntu... seems to be a more favorable distro to install Home-Assistant to. I think I even may have an old Pi still kicking around.
You don't need discovery for mysensors, so you could disable that in the config if you don't have any other component that you want to activate which need discovery.
Do you have gcc installed and general packages for building, usually called build tools, build-essentials etc?
Haven't tried build-tools (tried build-essential, it couldn't find any packages) and I do have GCC installed.
Will try again when i'm done work for the evening and see what happens.
I think it's called development tools for Fedora. Google it.
If you can post the build log message, I could advise better. It could be a specific lib package that is missing for the compile. The log will usually give some hint on what's missing.
I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
Eg:
rm -r ~/.homeassistant/lib mkvirtualenv -p /usr/bin/python3 hasstest2 cd ~/dev/home-assistant git branch -D mysensors-tcp-gateway git fetch origin mysensors-tcp-gateway git checkout mysensors-tcp-gateway pip3 install -e . pip3 install colorlog pip3 install python-Levenshtein -
This is the error I am getting when starting up HASS.
(hasstest) pi@pitest:~/dev/home-assistant $ hass Config directory: /home/pi/.homeassistant 16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api 16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Hello, and welcome to Home Assistant! We'll hope that we can make all your dreams come true. Here are some resources to get started: - Configuring Home Assistant: https://home-assistant.io/getting-started/configuration/ - Available components: https://home-assistant.io/components/ - Troubleshooting your configuration: https://home-assistant.io/getting-started/troubleshooting-configuration/ - Getting help: https://home-assistant.io/help/ This message is generated by the introduction component. You can disable it in configuration.yaml. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history> 16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation> 16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port 16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook> 16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads) 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant> 16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123 16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting 16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 - 16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]> 16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning ^CProcess Process-1: Traceback (most recent call last): Traceback (most recent call last): File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module> load_entry_point('homeassistant', 'console_scripts', 'hass')() File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main keep_running, exit_code = run_hass_process(hass_proc) File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap self.run() File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run self._target(*self._args, **self._kwargs) File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass exit_code = int(hass.block_till_stopped()) TypeError: 'bool' object is not iterable File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped self.stop() File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop self.pool.stop() File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop self.block_till_done() File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done self._work_queue.join() File "/usr/lib/python3.4/queue.py", line 86, in join self.all_tasks_done.wait() File "/usr/lib/python3.4/threading.py", line 290, in wait waiter.acquire() KeyboardInterruptmysensors: gateways: - device: '192.168.1.10' persistence_file: '~/.homeassistant/mysensors3.json' tcp_port: 5003 debug: true persistence: true version: '1.5' -
(hasstest) pi@pitest:~/dev/home-assistant $ hass Config directory: /home/pi/.homeassistant 16-03-05 20:07:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant> 16-03-05 20:07:57 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation 16-03-05 20:07:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 16-03-05 20:07:59 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api 16-03-05 20:07:59 INFO (MainThread) [homeassistant.components.introduction] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Hello, and welcome to Home Assistant! We'll hope that we can make all your dreams come true. Here are some resources to get started: - Configuring Home Assistant: https://home-assistant.io/getting-started/configuration/ - Available components: https://home-assistant.io/components/ - Troubleshooting your configuration: https://home-assistant.io/getting-started/troubleshooting-configuration/ - Getting help: https://home-assistant.io/help/ This message is generated by the introduction component. You can disable it in configuration.yaml. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=introduction> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http> 16-03-05 20:07:59 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history> 16-03-05 20:07:59 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTPS connection (1): pypi.python.org 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state updater.updater=0.14.2; friendly_name=Update Available @ 20:08:00 05-03-2016>, entity_id=updater.updater> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation> 16-03-05 20:08:00 ERROR (MainThread) [homeassistant.components.mysensors] Missing required configuration items in mysensors: port 16-03-05 20:08:00 ERROR (MainThread) [homeassistant.bootstrap] component mysensors failed to initialize 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=log, domain=logbook> 16-03-05 20:08:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook> 16-03-05 20:08:00 INFO (MainThread) [requests.packages.urllib3.connectionpool] Starting new HTTP connection (1): maps.googleapis.com 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state sun.sun=below_horizon; next_setting=22:12:29 06-03-2016, elevation=-21.55, next_rising=10:44:01 06-03-2016, friendly_name=Sun @ 20:08:01 05-03-2016>, entity_id=sun.sun> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Starting Home Assistant (13 threads) 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant> 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant> 16-03-05 20:08:01 INFO (Thread-17) [homeassistant.components.http] Starting web interface at http://0.0.0.0:8123 16-03-05 20:08:01 INFO (Thread-15) [homeassistant.core] Timer:starting 16-03-05 20:08:01 INFO (Thread-18) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 - 16-03-05 20:08:01 INFO (Thread-19) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -^C16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Stopping 16-03-05 20:08:01 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]> 16-03-05 20:08:02 INFO (Thread-16) [netdisco.service] Scanning ^CProcess Process-1: Traceback (most recent call last): Traceback (most recent call last): File "/home/pi/.virtualenvs/hasstest/bin/hass", line 9, in <module> load_entry_point('homeassistant', 'console_scripts', 'hass')() File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 330, in main keep_running, exit_code = run_hass_process(hass_proc) File "/usr/lib/python3.4/multiprocessing/process.py", line 254, in _bootstrap self.run() File "/usr/lib/python3.4/multiprocessing/process.py", line 93, in run self._target(*self._args, **self._kwargs) File "/home/pi/dev/home-assistant/homeassistant/__main__.py", line 248, in setup_and_run_hass exit_code = int(hass.block_till_stopped()) TypeError: 'bool' object is not iterable File "/home/pi/dev/home-assistant/homeassistant/core.py", line 100, in block_till_stopped self.stop() File "/home/pi/dev/home-assistant/homeassistant/core.py", line 107, in stop self.pool.stop() File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 364, in stop self.block_till_done() File "/home/pi/dev/home-assistant/homeassistant/util/__init__.py", line 358, in block_till_done self._work_queue.join() File "/usr/lib/python3.4/queue.py", line 86, in join self.all_tasks_done.wait() File "/usr/lib/python3.4/threading.py", line 290, in wait waiter.acquire() KeyboardInterruptmysensors: gateways: - device: '192.168.1.10' persistence_file: '~/.homeassistant/mysensors3.json' tcp_port: 5003 debug: true persistence: true version: '1.5'Did you checkout correct branch?
git fetch origin mysensors-tcp-gateway git checkout mysensors-tcp-gatewayYou should remove the lib directory in ~/.homeassistant/ before you start hass again after the git checkout also.
rm -r ~/.homeassistant/lib -
Ugh, forgot to run the checkout command. palm smacks head
Booting now, will report back in a minute if it is working or not.
Don't forget to use the correct ip address of your gateway in your network.
It works! Found my motion sensor with ease. Will start adding lights now shortly
Thanks again, loving this.
EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
:thumbsup:
When you have time, can you run
git logand tell me the top commit message, so I know which version you are using.Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"or if you want to install as root:
sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"This way you should be able to autostart the usual way, per instructions on the web.
But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
Here is the info you requested:
commit d07f8097a6186611371b8bc918fcb0d436bb39ba Author: MartinHjelmare <marhje52@kth.se> Date: Sat Feb 27 04:55:38 2016 +0100 Add mysensors tcp ethernet gateway * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE. * Add tcp_port in config. * Use fork pymysensors repo, temporarily. * Try to guess if tcp or serial gateway is configured, by validating device name as an ip address. If successful setup tcp gateway, if it fails, setup serial gateway. * Update device_state_attributes to show correct device, ethernet or serial. commit 278fdc0983a8528945e13cf912da82f3bc5fe14c Merge: 6dc49df 8ffa368 Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no> Date: Fri Feb 26 10:49:10 2016 +0100 Merge pull request #1385 from balloob/rfxtrx improve rfxtrx sensor : -
commit d07f8097a6186611371b8bc918fcb0d436bb39ba Author: MartinHjelmare <marhje52@kth.se> Date: Sat Feb 27 04:55:38 2016 +0100 Add mysensors tcp ethernet gateway * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE. * Add tcp_port in config. * Use fork pymysensors repo, temporarily. * Try to guess if tcp or serial gateway is configured, by validating device name as an ip address. If successful setup tcp gateway, if it fails, setup serial gateway. * Update device_state_attributes to show correct device, ethernet or serial. commit 278fdc0983a8528945e13cf912da82f3bc5fe14c Merge: 6dc49df 8ffa368 Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no> Date: Fri Feb 26 10:49:10 2016 +0100 Merge pull request #1385 from balloob/rfxtrx improve rfxtrx sensor :Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
Let me know if you experience any problems.
If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
Hey @martinhjelmare,
I finally got this working.
I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
Still testing ...
Still testing ...
Do you mean that the sensors are not showing the latest values in the gui?
If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
actually, I just got it working ...
yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
I restarted the server and now updates are working.
What I'm seeing in the log is constantly this message:
16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.jsonIf I'm not wrong this is the persistence.
Apart of this I now see updates coming in ...
Good!
The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
I usually put the file in the same directory as configuration.yml.
Ok, couple of things that I'm seeing now.
Everytime I restart the server the MySensor nodes are no longer in the system. I have to restart them to get them in again. All of them are in the persistence file.
Now i can only have 1 node added.
While in the persistence file I see multiple nodes, once I add one of them I can't add anymore. No error if fired (at least not that I've seen).
Can you attach the persistence file here and post your config, and I'll take a look?
Sure!
Consistence file:
{"156": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 156}, "102": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 102}}the Configuration is very light. Actually is the by default config and i just added this to test MySensors:
mysensors: gateways: - device: 192.168.1.X persistence_file: '/home/pi/.homeassistant/MSPersistence.json' tcp_port: 5003 debug: true persistence: true version: '1.5'let me know if you need anything else.
In the persistence file I can see two issues.
Sketch name is null for both nodes.
Both nodes don't have any children.Are you using a non default example sketch, if so can you post it?
