  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 74.8k Views 33 Watching
  • Mark JeffordM
    Mark JeffordM
    Mark Jefford
    Quick question, trying to integrate the mysprinkler project into openhab.
    getting stuck using V_VAR1-3 i need to somehow export out a runtime variable to the remote ardunio... any idea how i can get the V_VAR1-3 to output something that is not binary? i.e a runtime of 5 min for sprinklers...
    i have the triggering working, just can't configure the runtime.
    any help appreciated.. will do a guide if it get it working :)
    • Harry GomezH
      Harry GomezH
      Harry Gomez
      I recently moved my OpenHab install from a Raspberry PI 2 to a Raspberry Pi 3 from wheezy to jessie and now the biding is not working. Everything was working perfectly with the previous install now i keep getting the following message, serial port exist and it works. I suspect it has do to with the change from wheezy to jessie but nothing i tries is working.
      2016-03-25 19:28:20 DEBUG o.o.b.m.i.MySensorsBinding[:96]- activate
      2016-03-25 19:28:20 ERROR o.o.b.m.i.gateway.Serial[:70]- Unable to find Serial port '/dev/ttyUSB0'
      [ 3137.417846] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
      [ 3137.520958] usb 1-1.5: New USB device found, idVendor=1a86, idProduct=7523
      [ 3137.520979] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      [ 3137.520992] usb 1-1.5: Product: USB2.0-Serial
      [ 3137.522050] ch341 1-1.5:1.0: ch341-uart converter detected
      [ 3137.525880] usb 1-1.5: ch341-uart converter now attached to ttyUSB0
      regards
      Harry
      • Harry GomezH Harry Gomez
        regards
        Harry
        ted
        @Harry-Gomez
        From https://github.com/openhab/openhab/wiki/Serial-Binding
        If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
        -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0
        whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
        Harry GomezH 1 Reply Last reply
        • T ted
          @Harry-Gomez
          Harry GomezH
          Harry GomezH
          Harry Gomez
          I tried that but it did not work - this is how part of the /etc/init.d/openhab looks - any other ideas - i did not needed this with the RPi2 and wheezy
          JAVA_ARGS_DEFAULT="-Dosgi.clean=true
          -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0
          -Declipse.ignoreApp=true
          -Dosgi.noShutdown=true
          -Djetty.port=${HTTP_PORT}
          -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
          -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
          -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
          -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
          -Djetty.home="${OPENHAB_DIR}"
          -Djetty.port.ssl=${HTTPS_PORT}
          -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
          -Djetty.logs="${OPENHAB_LOG_DIR}"
          -Djetty.rundir="${OPENHAB_DIR}"
          -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
          -Dfelix.fileinstall.filter=.*\.jar
          -Djava.library.path="${OPENHAB_DIR}/lib"
          -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
          -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
          -Dequinox.ds.block_timeout=240000
          -Dequinox.scr.waitTimeOnBlock=60000
          -Dfelix.fileinstall.active.level=4
          -Djava.awt.headless=true
          -jar ${LAUNCHER}
          -configuration ${OPENHAB_WORKSPACE_DIR}
          -data ${OPENHAB_WORKSPACE_DIR}
          -console ${TELNET_PORT}"
            -jar ${LAUNCHER}
            ted
            @Harry-Gomez
            What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
            Harry GomezH zeblongZ 2 Replies Last reply
            • T ted
              @Harry-Gomez
              Harry GomezH
              Harry GomezH
              Harry Gomez
              @ted
              Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
              Thanks!!
              • FrancoisF
                FrancoisF
                Francois
                wrote on last edited by Francois
                #32
                Hi what is the syntax for a relay in openhab using this binding?
                This in what I get in the log but the light do not switch on or off.
                2016-03-27 20:37:00.068 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                2016-03-27 20:37:00.889 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                2016-03-27 20:37:01.622 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                2016-03-27 20:37:02.407 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
                2016-03-27 20:37:03.247 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
                This is the syntax that I am use and it is not working. Also try V_LIGHT without any luck.
                Switch LightSwitch_GF_Study	"Study Light  [%s]"				<light> 	(GF_Study)			{mysensors="41;1;V_BINARY"}
                andredtsA bklB 2 Replies Last reply
                • FrancoisF Francois
                  andredtsA
                  andredtsA
                  andredts
                  @Francois
                  Hi, I use {mysensors="12;0;V_STATUS"}. Remember to give your node a ID, because OH does not give one.
                    bklB
                    bklB
                    bkl
                    Hi @Francois
                    The syntax look OK.
                    This is what i have working.
                    Switch  Relay_10_0              "Relay 1"                       <none>                                  {mysensors="10;0;V_STATUS"}
                    Try and turn on debug log for mysensors
                    Add this to logback.xml
                    <logger name="org.openhab.binding.mysensors" level="DEBUG" />
                    • FrancoisF
                      FrancoisF
                      Francois
                      Hi @bkl
                      Are you using the standard relay sketch with this binding or did you change anything in the sketch as I just don't get my relay to work.
                      Here is my log with the above string in my logback.xml.
                      17:28:48.825 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor node found: node-id=15
                       * Example item: 15;255;I_BATTERY_LEVEL      - Use this to report the battery level 0-100 (%)
                       * Example item: 15;255;I_SKETCH_NAME        - Sketch name that can be used to identify sensor
                       * Example item: 15;255;I_SKETCH_VERSION     - Sketch version that can be reported to keep track of the version of sensor
                      17:28:48.827 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      17:28:50.856 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=11,pt=0,l=25,sg=0:Main Bedroom Relay & Butt
                      17:28:50.858 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_NAME"
                      17:28:50.860 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
                      17:28:50.862 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_VERSION"
                      17:28:50.864 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                      17:28:50.867 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Binary device (on/off)): node-id=15, sensor-id=1 with type S_BINARY
                       * Example item: 15;1;V_STATUS             - Binary status. (on/off)
                       * Example item: 15;1;V_WATT               - Watt value for power meters
                      17:28:51.457 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'LightSwitch_GF_Study' with state 'ON' in rrd4j database (again)
                      17:28:51.460 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                      17:28:51.500 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                      17:28:51.503 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                      17:28:51.719 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:29.1
                      17:28:51.722 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Hum_GF_Study = 29.1
                      17:28:51.729 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'Hum_GF_Study' with state '29.1' in rrd4j database
                      17:28:51.760 [INFO ] [runtime.busevents             :26   ] - Hum_GF_Study state updated to 29.1
                      17:28:51.762 [DEBUG] [.b.m.internal.MySensorsBinding:248  ] - internalReceiveUpdate(Hum_GF_Study,29.1) is called!
                      17:28:51.862 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                      17:28:51.864 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                      17:28:52.045 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
                      17:28:52.075 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                      17:28:52.077 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                      17:28:52.252 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                      17:28:52.255 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                      17:28:52.448 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
                      17:28:52.451 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                      17:28:52.648 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                      17:28:52.650 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
                      17:28:52.654 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                      17:28:52.659 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Motion_GF_Study = ON
                      17:28:52.662 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'Motion_GF_Study' with state 'OFF' in rrd4j database (again)
                      • bklB bkl
                        @BastienVH
                        Note2: If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
                        skatunS
                        skatunS
                        skatun
                        @bkl
                        So my question (linux newbie) is what is the best way to attach my Arduino nano to rpi, so that it always find it on reboot or if it is unplugged/replugged.
                        Is this correct and will this work with the binding?
                        /etc/udev/rules.d/99-usb-serial.rules"
                        with my device info:
                        SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A40360T2", SYMLINK+="ttyUSB99"
                        • T ted
                          @Harry-Gomez
                          zeblongZ
                          zeblongZ
                          zeblong
                          @ted
                          Hi
                          I use RASPBIAN JESSIE.
                          Command minicom -b 115200 -o -D /dev/ttyUSB0 show traffic from serial gateway.
                          I write -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 to /usr/share/openhab/bin/openhab.sh and /etc/init.d/openhab but still 'Unable to find Serial port '/dev/ttyUSB0''.
                          Please help me
                          • zeblongZ zeblong
                            @ted
                            Hi
                            Please help me
                            Harry GomezH
                            Harry GomezH
                            Harry Gomez
                            wrote on last edited by Harry Gomez
                            #38
                            @zeblong
                            for me I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0\ right at the begining for it to work at usr/share/openhab/bin/openhab.sh - i removed from /etc/init.d/openhab it did not make a difference. below is how it looks for me. also check the output if dmesg for changes in tty. I also use jessie on a RPi3
                            -Duser.timezone=America/Los_Angeles
                            -jar ${LAUNCHER}
                            -console ${TELNET_PORT}" \
                            ~ $ dmesg |grep tty
                            [ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x71ef84a5 smsc95xx.macaddr=B8:27:EB:EF:84:A5 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                            [ 0.001288] console [tty1] enabled
                            [ 0.267235] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
                            [ 0.919548] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
                            [ 2.166808] systemd[1]: Starting system-getty.slice.
                            [ 2.170421] systemd[1]: Created slice system-getty.slice.
                            [ 3.635870] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
                            zeblongZ bklB 2 Replies Last reply
                              @zeblong
                              -jar ${LAUNCHER}
                              ~ $ dmesg |grep tty
                              zeblongZ
                              zeblongZ
                              zeblong
                              @Harry-Gomez
                              That's all well done. does not work. It may be necessary to install any more bindings or the Java packages?
                              • zeblongZ zeblong
                                @Harry-Gomez
                                Harry GomezH
                                Harry GomezH
                                Harry Gomez
                                @zeblong
                                Do you have the serial package installed --> org.openhab.io.transport.serial-1.8.2.jar?
                                Did you add openhab to dialout group -> sudo usermod -a -G dialout openhab
                                What is the error on you logs?
                                zeblongZ 1 Reply Last reply
                                • FrancoisF
                                  FrancoisF
                                  Francois
                                  #41
                                  All my temp motion and humidity sensor work but my relay and dimmer sensor don't work, why will this be the case? Here is the log:
                                  2016-04-03 09:25:07.928 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:07.930 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:08.186 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:08.406 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:08.527 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:08.539 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:08.584 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:08.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:08.625 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:08.802 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:09.247 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:09.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:10.421 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:10.899 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:11.410 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:11.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:11.594 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:11.829 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:12.513 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:12.840 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:12.841 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                  2016-04-03 09:25:13.145 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                  2016-04-03 09:25:13.394 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:13.422 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:17.880 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:17.882 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:18.025 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:18.536 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:18.538 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:18.541 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:22.736 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:22.737 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                  2016-04-03 09:25:23.021 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:1
                                  2016-04-03 09:25:23.022 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = ON
                                  2016-04-03 09:25:23.033 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                  2016-04-03 09:25:23.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,ON) is called!
                                  2016-04-03 09:25:23.765 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=5,c=1,t=38,pt=7,l=5,sg=0:2.90
                                  2016-04-03 09:25:23.766 [DEBUG] [.b.m.internal.MySensorsBinding] - MotionBatVcc_GF_Study = 2.90
                                  2016-04-03 09:25:23.937 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(MotionBatVcc_GF_Study,2.90) is called!
                                  2016-04-03 09:25:26.984 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:26.985 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:27.203 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:27.648 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=17,pt=5,l=4,sg=0:315
                                  2016-04-03 09:25:27.651 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_WATT"
                                  2016-04-03 09:25:27.653 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:29.284 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=24,pt=5,l=4,sg=0:2718269
                                  2016-04-03 09:25:29.286 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_VAR1"
                                  2016-04-03 09:25:31.838 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:31.840 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                  2016-04-03 09:25:32.184 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                  2016-04-03 09:25:33.022 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:0
                                  2016-04-03 09:25:33.024 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = OFF
                                  2016-04-03 09:25:33.326 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,OFF) is called!
                                  2016-04-03 09:25:35.140 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:35.141 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:35.447 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:35.556 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                  2016-04-03 09:25:35.557 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                                  2016-04-03 09:25:35.561 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                                  2016-04-03 09:25:36.738 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:36.851 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:37.297 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:37.324 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:37.758 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:37.962 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:38.434 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:38.454 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                                  2016-04-03 09:25:38.877 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                                  2016-04-03 09:25:39.995 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:40.045 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                                  2016-04-03 09:25:40.341 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                                  2016-04-03 09:25:40.590 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:40.591 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                                  2016-04-03 09:25:40.595 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                                  2016-04-03 09:25:41.596 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.4
                                  2016-04-03 09:25:41.597 [DEBUG] [.b.m.internal.MySensorsBinding] - Hum_GF_Study = 43.4
                                  2016-04-03 09:25:41.852 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Hum_GF_Study,43.4) is called!
                                  2016-04-03 09:25:43.390 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                  2016-04-03 09:25:43.392 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                                  2016-04-03 09:25:43.395 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                                  bklB 1 Reply Last reply
                                    @zeblong
                                    zeblongZ
                                    zeblongZ
                                    zeblong
                                    @Harry-Gomez
                                    Many thanks.
                                    Line 'sudo usermod -a -G dialout openhab' helped me.
                                      bklB
                                      bklB
                                      bkl
                                      Hi @Francois
                                      Yes i am using the standard relay sketch.
                                      I thing i found you problem, try and change V_BINARY to V_STATUS
                                        @zeblong
                                        -jar ${LAUNCHER}
                                        ~ $ dmesg |grep tty
                                        bklB
                                        bklB
                                        bkl
                                        Hi @Harry-Gomez
                                        If you make a guide to make openhab work with a non standard serial port, then i will make it part of the first post.
                                        • sSpeakerS
                                          sSpeakerS
                                          sSpeaker
                                          I'm trying to control curtain with UP/DOWN/STOP commands, but it does not work.
                                          2016-05-03 05:00:45.446 [INFO ] [.b.m.internal.MySensorsBinding] - New MySensor sensor found (Window covers or shades): node-id=30, sensor-id=0 with type S_COVER
                                           * Example item: 30;0;V_UP                 - Window covering. Up.
                                           * Example item: 30;0;V_DOWN               - Window covering. Down.
                                           * Example item: 30;0;V_STOP               - Window covering. Stop.
                                           * Example item: 30;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
                                          2016-05-03 11:17:58.351 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(BedroomCurtain,UP) is called!
                                          2016-05-03 11:17:58.354 [DEBUG] [.b.m.internal.MySensorsBinding] - Command "class org.openhab.core.library.types.UpDownType" is not a valid Command tyoe: [class org.openhab.core.library.types.PercentType]
                                          Item:
                                          Rollershutter	BedroomCurtain	"Bedroom Curtain"	<"rollershutter">	(Bedroom)	{mysensors="30;0;V_PERCENTAGE"}
                                          Sitemap:
                                          Switch	item=BedroomCurtain mappings=[UP="Up", STOP="Stop", DOWN="Down"]
