  3. OpenHAB
  4. openHAB binding
openHAB binding
89 Posts 30 Posters 74.8k Views 33 Watching
  • T ted
    @Harry-Gomez
    What if you modify start.sh and start openhab from console? I'm not a linux expert; could it be that the usb driver was initiated after /etc/init.d is processed ?
    Harry GomezH
    Harry GomezH
    Harry Gomez
    @ted
    Thank worked with change to openhab.sh - I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 at the begining to be able to work. I'm not sure why it would workthere and not on the /etc/init.d/openhab. Also there is not start.sh when you install using apt-get it is named opendhab.sh
    Thanks!!
    • FrancoisF
      FrancoisF
      Francois
      wrote on last edited by Francois
      #32
      Hi what is the syntax for a relay in openhab using this binding?
      This in what I get in the log but the light do not switch on or off.
      2016-03-27 20:37:00.068 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
      2016-03-27 20:37:00.889 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
      2016-03-27 20:37:01.622 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
      2016-03-27 20:37:02.407 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command OFF
      2016-03-27 20:37:03.247 [INFO ] [runtime.busevents             ] - LightSwitch_GF_Study received command ON
      This is the syntax that I am use and it is not working. Also try V_LIGHT without any luck.
      Switch LightSwitch_GF_Study	"Study Light  [%s]"				<light> 	(GF_Study)			{mysensors="41;1;V_BINARY"}
      andredtsA bklB 2 Replies Last reply
      • FrancoisF Francois
        andredtsA
        andredtsA
        andredts
        @Francois
        Hi, I use {mysensors="12;0;V_STATUS"}. Remember to give your node a ID, because OH does not give one.
          bklB
          bklB
          bkl
          Hi @Francois
          The syntax look OK.
          This is what i have working.
          Switch  Relay_10_0              "Relay 1"                       <none>                                  {mysensors="10;0;V_STATUS"}
          Try and turn on debug log for mysensors
          Add this to logback.xml
          <logger name="org.openhab.binding.mysensors" level="DEBUG" />
          • FrancoisF
            FrancoisF
            Francois
            Hi @bkl
            Are you using the standard relay sketch with this binding or did you change anything in the sketch as I just don't get my relay to work.
            Here is my log with the above string in my logback.xml.
            17:28:48.825 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor node found: node-id=15
             * Example item: 15;255;I_BATTERY_LEVEL      - Use this to report the battery level 0-100 (%)
             * Example item: 15;255;I_SKETCH_NAME        - Sketch name that can be used to identify sensor
             * Example item: 15;255;I_SKETCH_VERSION     - Sketch version that can be reported to keep track of the version of sensor
            17:28:48.827 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
            17:28:50.856 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=11,pt=0,l=25,sg=0:Main Bedroom Relay & Butt
            17:28:50.858 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_NAME"
            17:28:50.860 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
            17:28:50.862 [INFO ] [.b.m.internal.MySensorsBinding:318  ] - No item configured for "15;255;I_SKETCH_VERSION"
            17:28:50.864 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 15-15-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
            17:28:50.867 [INFO ] [.b.m.internal.MySensorsBinding:257  ] - New MySensor sensor found (Binary device (on/off)): node-id=15, sensor-id=1 with type S_BINARY
             * Example item: 15;1;V_STATUS             - Binary status. (on/off)
             * Example item: 15;1;V_WATT               - Watt value for power meters
            17:28:51.457 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'LightSwitch_GF_Study' with state 'ON' in rrd4j database (again)
            17:28:51.460 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
            17:28:51.500 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
            17:28:51.503 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
            17:28:51.719 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:29.1
            17:28:51.722 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Hum_GF_Study = 29.1
            17:28:51.729 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'Hum_GF_Study' with state '29.1' in rrd4j database
            17:28:51.760 [INFO ] [runtime.busevents             :26   ] - Hum_GF_Study state updated to 29.1
            17:28:51.762 [DEBUG] [.b.m.internal.MySensorsBinding:248  ] - internalReceiveUpdate(Hum_GF_Study,29.1) is called!
            17:28:51.862 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
            17:28:51.864 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
            17:28:52.045 [DEBUG] [.p.rrd4j.internal.RRD4jService:132  ] - Stored 'LightSwitch_GF_Study' with state '0' in rrd4j database
            17:28:52.075 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
            17:28:52.077 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
            17:28:52.252 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
            17:28:52.255 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
            17:28:52.448 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command OFF
            17:28:52.451 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
            17:28:52.648 [DEBUG] [.b.m.internal.MySensorsBinding:263  ] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
            17:28:52.650 [INFO ] [runtime.busevents             :22   ] - LightSwitch_GF_Study received command ON
            17:28:52.654 [DEBUG] [.b.m.internal.MySensorsBinding:230  ] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
            17:28:52.659 [DEBUG] [.b.m.internal.MySensorsBinding:307  ] - Motion_GF_Study = ON
            17:28:52.662 [DEBUG] [.p.rrd4j.internal.RRD4jService:113  ] - Stored 'Motion_GF_Study' with state 'OFF' in rrd4j database (again)
            • bklB bkl
              @BastienVH
              https://github.com/openhab/openhab/wiki/Serial-Binding
              Note2: If you are using non standard serial ports you have to adapt start.sh to have the serial port included. the java command line should then include the following parameters:
              -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0
              whereas ttyAMA0 is the path to your serial port. Please be aware to change all scripts you might use for startup (debug, automatic start in linux,...)
              skatunS
              skatunS
              skatun
              @bkl
              So my question (linux newbie) is what is the best way to attach my Arduino nano to rpi, so that it always find it on reboot or if it is unplugged/replugged.
              Is this correct and will this work with the binding?
              /etc/udev/rules.d/99-usb-serial.rules"
              with my device info:
              SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A40360T2", SYMLINK+="ttyUSB99"
              • T ted
                @Harry-Gomez
                zeblongZ
                zeblongZ
                zeblong
                @ted
                Hi
                I use RASPBIAN JESSIE.
                Command minicom -b 115200 -o -D /dev/ttyUSB0 show traffic from serial gateway.
                I write -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0 to /usr/share/openhab/bin/openhab.sh and /etc/init.d/openhab but still 'Unable to find Serial port '/dev/ttyUSB0''.
                Please help me
                Harry GomezH 1 Reply Last reply
                • zeblongZ zeblong
                  @ted
                  Hi
                  Please help me
                  Harry GomezH
                  Harry GomezH
                  Harry Gomez
                  wrote on last edited by Harry Gomez
                  #38
                  @zeblong
                  for me I had to put -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0\ right at the begining for it to work at usr/share/openhab/bin/openhab.sh - i removed from /etc/init.d/openhab it did not make a difference. below is how it looks for me. also check the output if dmesg for changes in tty. I also use jessie on a RPi3
                  JAVA_ARGS_DEFAULT="-Dosgi.clean=true
                  -Duser.timezone=America/Los_Angeles
                  -Declipse.ignoreApp=true
                  -Dosgi.noShutdown=true
                  -Djetty.port=${HTTP_PORT}
                  -Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg"
                  -Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations"
                  -Dopenhab.logdir="${OPENHAB_LOG_DIR}"
                  -Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
                  -Djetty.home="${OPENHAB_DIR}"
                  -Djetty.port.ssl=${HTTPS_PORT}
                  -Djetty.config="${OPENHAB_CONF_DIR}/jetty"
                  -Djetty.logs="${OPENHAB_LOG_DIR}"
                  -Djetty.rundir="${OPENHAB_DIR}"
                  -Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons"
                  -Dfelix.fileinstall.filter=.*\.jar
                  -Djava.library.path="${OPENHAB_DIR}/lib"
                  -Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf"
                  -Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties"
                  -Dequinox.ds.block_timeout=240000
                  -Dequinox.scr.waitTimeOnBlock=60000
                  -Dfelix.fileinstall.active.level=4
                  -Djava.awt.headless=true
                  -jar ${LAUNCHER}
                  -configuration ${OPENHAB_WORKSPACE_DIR}
                  -data ${OPENHAB_WORKSPACE_DIR}
                  -console ${TELNET_PORT}" \
                  ~ $ dmesg |grep tty
                  [ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa02082 bcm2709.serial=0x71ef84a5 smsc95xx.macaddr=B8:27:EB:EF:84:A5 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                  [ 0.001288] console [tty1] enabled
                  [ 0.267235] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
                  [ 0.919548] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
                  [ 2.166808] systemd[1]: Starting system-getty.slice.
                  [ 2.170421] systemd[1]: Created slice system-getty.slice.
                  [ 3.635870] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
                  zeblongZ bklB 2 Replies Last reply
                  • Harry GomezH Harry Gomez
                    @zeblong
                    -jar ${LAUNCHER}
                    ~ $ dmesg |grep tty
                    zeblongZ
                    zeblongZ
                    zeblong
                    @Harry-Gomez
                    That's all well done. does not work. It may be necessary to install any more bindings or the Java packages?
                    • zeblongZ zeblong
                      @Harry-Gomez
                      Harry GomezH
                      Harry GomezH
                      Harry Gomez
                      @zeblong
                      Do you have the serial package installed --> org.openhab.io.transport.serial-1.8.2.jar?
                      Did you add openhab to dialout group -> sudo usermod -a -G dialout openhab
                      What is the error on you logs?
                      zeblongZ 1 Reply Last reply
                      • FrancoisF
                        FrancoisF
                        Francois
                        #41
                        All my temp motion and humidity sensor work but my relay and dimmer sensor don't work, why will this be the case? Here is the log:
                        2016-04-03 09:25:07.928 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:07.930 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:08.186 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:08.406 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:08.527 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:08.539 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:08.584 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:08.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:08.625 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:08.802 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:09.247 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:09.588 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:10.421 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:10.899 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:11.410 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:11.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:11.594 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:11.829 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:12.513 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:12.840 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:12.841 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                        2016-04-03 09:25:13.145 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                        2016-04-03 09:25:13.394 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:13.422 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:17.880 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:17.882 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:18.025 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:18.536 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:18.538 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:18.541 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:22.736 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:22.737 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                        2016-04-03 09:25:23.021 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:1
                        2016-04-03 09:25:23.022 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = ON
                        2016-04-03 09:25:23.033 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                        2016-04-03 09:25:23.431 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,ON) is called!
                        2016-04-03 09:25:23.765 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=5,c=1,t=38,pt=7,l=5,sg=0:2.90
                        2016-04-03 09:25:23.766 [DEBUG] [.b.m.internal.MySensorsBinding] - MotionBatVcc_GF_Study = 2.90
                        2016-04-03 09:25:23.937 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(MotionBatVcc_GF_Study,2.90) is called!
                        2016-04-03 09:25:26.984 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:26.985 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:27.203 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:27.648 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:27.650 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=17,pt=5,l=4,sg=0:315
                        2016-04-03 09:25:27.651 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_WATT"
                        2016-04-03 09:25:27.653 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:29.284 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 66-66-0 s=1,c=1,t=24,pt=5,l=4,sg=0:2718269
                        2016-04-03 09:25:29.286 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "66;1;V_VAR1"
                        2016-04-03 09:25:31.838 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:31.840 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                        2016-04-03 09:25:32.184 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                        2016-04-03 09:25:33.022 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 95-95-0 s=1,c=1,t=16,pt=1,l=1,sg=0:0
                        2016-04-03 09:25:33.024 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen = OFF
                        2016-04-03 09:25:33.326 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen,OFF) is called!
                        2016-04-03 09:25:35.140 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:35.141 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:35.447 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:35.556 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                        2016-04-03 09:25:35.557 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 1
                        2016-04-03 09:25:35.561 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,1) is called!
                        2016-04-03 09:25:36.738 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:36.851 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:37.297 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:37.324 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:37.758 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:37.962 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:38.434 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:38.454 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,ON) is called!
                        2016-04-03 09:25:38.877 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(LightSwitch_GF_Study,OFF) is called!
                        2016-04-03 09:25:39.995 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 40-40-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:40.045 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Study = 0
                        2016-04-03 09:25:40.341 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Study,0) is called!
                        2016-04-03 09:25:40.590 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:40.591 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                        2016-04-03 09:25:40.595 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                        2016-04-03 09:25:41.596 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.4
                        2016-04-03 09:25:41.597 [DEBUG] [.b.m.internal.MySensorsBinding] - Hum_GF_Study = 43.4
                        2016-04-03 09:25:41.852 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Hum_GF_Study,43.4) is called!
                        2016-04-03 09:25:43.390 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 82-82-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                        2016-04-03 09:25:43.392 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion_GF_Kitchen01 = OFF
                        2016-04-03 09:25:43.395 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion_GF_Kitchen01,OFF) is called!
                        bklB 1 Reply Last reply
                          @zeblong
                          zeblongZ
                          zeblongZ
                          zeblong
                          @Harry-Gomez
                          Many thanks.
                          Line 'sudo usermod -a -G dialout openhab' helped me.
                            bklB
                            bklB
                            bkl
                            Hi @Francois
                            Yes i am using the standard relay sketch.
                            I thing i found you problem, try and change V_BINARY to V_STATUS
                              @zeblong
                              -jar ${LAUNCHER}
                              ~ $ dmesg |grep tty
                              bklB
                              bklB
                              bkl
                              Hi @Harry-Gomez
                              If you make a guide to make openhab work with a non standard serial port, then i will make it part of the first post.
                              • sSpeakerS
                                sSpeakerS
                                sSpeaker
                                I'm trying to control curtain with UP/DOWN/STOP commands, but it does not work.
                                2016-05-03 05:00:45.446 [INFO ] [.b.m.internal.MySensorsBinding] - New MySensor sensor found (Window covers or shades): node-id=30, sensor-id=0 with type S_COVER
                                 * Example item: 30;0;V_UP                 - Window covering. Up.
                                 * Example item: 30;0;V_DOWN               - Window covering. Down.
                                 * Example item: 30;0;V_STOP               - Window covering. Stop.
                                 * Example item: 30;0;V_PERCENTAGE         - Percentage value. 0-100 (%)
                                2016-05-03 11:17:58.351 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveCommand(BedroomCurtain,UP) is called!
                                2016-05-03 11:17:58.354 [DEBUG] [.b.m.internal.MySensorsBinding] - Command "class org.openhab.core.library.types.UpDownType" is not a valid Command tyoe: [class org.openhab.core.library.types.PercentType]
                                Item:
                                Rollershutter	BedroomCurtain	"Bedroom Curtain"	<"rollershutter">	(Bedroom)	{mysensors="30;0;V_PERCENTAGE"}
                                Sitemap:
                                Switch	item=BedroomCurtain mappings=[UP="Up", STOP="Stop", DOWN="Down"]
                                • mark_vennM
                                  mark_vennM
                                  mark_venn
                                  I am going to give this a try with the serial gateway. I am not sure whether to use mqtt or serial; this might help me make up my mind!
                                  :smile:
                                  • skatunS
                                    skatunS
                                    skatun
                                    Hi all,
                                    can we please document this binding and add it to github of openhab in similiar way to all other bindings? I can help with doing so:)
                                    • bklB bkl
                                      Hi
                                      I have been playing a bit with creating a binding for openHAB.
                                      And it is now in a state where i think it is ready for some more testing.
                                      Links
                                      GitHub (https://github.com/bloft/openhab)
                                      Download (http://bkl.linux.dk/org.openhab.binding.mysensors-1.8.0-SNAPSHOT.jar)
                                      Features
                                      • Serial Gateway supported Only
                                      • Supported all sensors (1.6)
                                      • Discovery of devices (sort of)
                                      • Support requesting values from openhab
                                      Experimental / Not Tested
                                      • Ethernet Gateway
                                      • Error handling of Gateway (restart of connection)
                                      • I_CONFIG support add mysensors:metric=true to mysensors:metric=false to openhab.cfg
                                      Not Working
                                      • Auto assign of Node ID
                                      Howto Use
                                      1. Add jar to addons dir
                                      2. Modify openhab.cfg add "mysensors:port=/dev/ttyUSB0"
                                      3. Add items
                                      Configure ethernet gateway
                                      Modify openhab.cfg set
                                      mysensors:type=ethernet
                                      mysensors:host=<host ip>
                                      mysensors:port=5003
                                      This is still untested so please report if it is working or not.
                                      Auto discovery
                                      Every time a Presentation is detected, example of usage is printed to the openhab.log on INFO
                                      Example of items:
                                      Number  Humidity              "Hjemmebio [%s %%Rh]"   <water>         (gBio,gHumidity)        {mysensors="3;0;V_HUM"}
                                      Number  Temperature           "Hjemmebio [%s °C]"     <temperature>   (gBio,gTemperature)     {mysensors="3;1;V_TEMP"}
                                      Switch  Motion                "Hjemmebio [%s]"        <motion>        (gBio,gMotion)          {mysensors="3;2;V_TRIPPED"}
                                      Number  Light                 "Hjemmebio [%s]"        <slider>        (gBio,gLightLevel)      {mysensors="3;3;V_LIGHT_LEVEL"}
                                      AffordableTechA
                                      AffordableTechA
                                      AffordableTech
                                      @bkl
                                      Just wanted to say thanks for making my wish come true!
                                      My Experience Setting up OpenHab
                                      If it helps others, I tried OpenHab a year ago but gave it away simply because of the instabilities associated with using MQTT, i.e. needing a server, a broker, a client and the gateway. Far too many modules to configure, making it so easy to get it wrong.
                                      Thanks to this MySensors/OpenHab binding, the Arduino gateway talks direct to OpenHab without all the middleware, making it easier to configure and more reliable.
                                      It took only a few minutes to install OpenHab 1.8 and this binding. Pasted the items and sitemap examples and presto - it was working! A very pleasant change from nearly three days wasted trying to get the (alternate) OpenHab2 binding working.
                                      I'll upgrade to OpenHab2 when I'm confident it is stable and the matching binding is sorted out.
                                      Paul
                                      • mark_vennM
                                        mark_vennM
                                        mark_venn
                                        Hi
                                        I have setup openhab on my pi 2 and I can see the gateway and a motion sensor with the following output in the openhab log:
                                        2016-05-28 16:13:05.519 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
                                        2016-05-28 16:13:23.624 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
                                        2016-05-28 16:13:24.471 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
                                        2016-05-28 16:13:29.131 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'test.items'
                                        2016-05-28 16:13:56.064 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
                                        2016-05-28 16:14:02.165 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
                                        2016-05-28 16:14:09.952 [DEBUG] [ySensorsGenericBindingProvider] - New Item "Motion (Type=SwitchItem, State=Uninitialized)" based on configuration "3; 2;V_TRIPPED"
                                        2016-05-28 16:14:10.139 [DEBUG] [.b.m.internal.MySensorsBinding] - activate
                                        2016-05-28 16:14:10.456 [DEBUG] [.o.b.m.internal.gateway.Serial] - Serial port '/dev/ttyUSB0' has been found.
                                        2016-05-28 16:14:10.530 [INFO ] [.service.AbstractActiveService] - MySensors Refresh Service has been started
                                        2016-05-28 16:14:12.181 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: gateway started, id=0, parent=0, distance=0
                                        2016-05-28 16:14:12.194 [INFO ] [.b.m.internal.MySensorsBinding] - Gateway Ready
                                        2016-05-28 16:14:35.120 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                        2016-05-28 16:14:35.136 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;1;V_TRIPPED"
                                        2016-05-28 16:14:49.747 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                                        2016-05-28 16:14:49.760 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;255;I_REQUEST_SIGNING"
                                        2016-05-28 16:14:49.771 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=255,c=0,t=18,pt=0,l=5,sg=0:1.5.4
                                        2016-05-28 16:14:49.836 [INFO ] [.b.m.internal.MySensorsBinding] - New MySensor node found: node-id=1 ( REPEATER )
                                        • Example item: 1;255;I_BATTERY_LEVEL - Use this to report the battery level 0-100 (%)
                                        • Example item: 1;255;I_SKETCH_NAME - Sketch name that can be used to identify sensor
                                        • Example item: 1;255;I_SKETCH_VERSION - Sketch version that can be reported to keep track of the version of sensor
                                          2016-05-28 16:14:49.851 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                                          2016-05-28 16:14:50.016 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                                          2016-05-28 16:14:51.780 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
                                          2016-05-28 16:14:51.792 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;255;I_SKETCH_NAME"
                                          2016-05-28 16:14:51.806 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                                          2016-05-28 16:14:51.821 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;255;I_SKETCH_VERSION"
                                          2016-05-28 16:14:51.832 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
                                          2016-05-28 16:14:51.847 [INFO ] [.b.m.internal.MySensorsBinding] - New MySensor sensor found (Motion sensor): node-id=1, sensor-id=1 with type S_MOTION
                                        • Example item: 1;1;V_TRIPPED - Tripped status of a security sensor. (Tripped/Untripped)
                                        • Example item: 1;1;V_ARMED - Armed status of a security sensor. (Armed/Bypassed)
                                          2016-05-28 16:14:51.861 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                          2016-05-28 16:14:51.868 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;1;V_TRIPPED"
                                          2016-05-28 16:15:10.721 [DEBUG] [.b.m.internal.MySensorsBinding] - Gateway Version: 1.5.4
                                          2016-05-28 16:15:43.284 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          2016-05-28 16:15:43.298 [INFO ] [.b.m.internal.MySensorsBinding] - No item configured for "1;1;V_TRIPPED"
                                        "no item configured fo "1;1;V_TRIPPED" seems to be confusing me. I have entered the motion sensor into the items file as in the example so can you point me in the direction to correct this please?
                                        I am very impressed so far, easier to get to this stage than it was using insteon!
                                        • mark_vennM
                                          mark_vennM
                                          mark_venn
                                          Found it! I had the .items entries wrong and if I had read things properly I would have worked it out before :disappointed_relieved:
                                          2016-05-28 18:22:35.565 [INFO ] [c.internal.ModelRepositoryImpl] - Refreshing model 'test.items'
                                          2016-05-28 18:22:35.649 [DEBUG] [ySensorsGenericBindingProvider] - New Item "Motion (Type=SwitchItem, State=Uninitialized)" based on configuration "1;1;V_TRIPPED"
                                          2016-05-28 18:22:46.463 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          2016-05-28 18:22:46.488 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion = OFF
                                          2016-05-28 18:22:46.504 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion,OFF) is called!
                                          2016-05-28 18:22:52.541 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                          2016-05-28 18:22:52.552 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion,ON) is called!
                                          2016-05-28 18:22:52.562 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion = ON
                                          2016-05-28 18:23:11.590 [DEBUG] [.b.m.internal.MySensorsBinding] - Gateway Version: 1.5.4
                                          2016-05-28 18:23:58.676 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          2016-05-28 18:23:58.688 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion,OFF) is called!
                                          2016-05-28 18:23:58.698 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion = OFF
                                          2016-05-28 18:24:05.045 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
                                          2016-05-28 18:24:05.058 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion,ON) is called!
                                          2016-05-28 18:24:05.067 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion = ON
                                          2016-05-28 18:24:08.746 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read and forward: 4-4-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          2016-05-28 18:24:09.134 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: send: 0-0-4-4 s=255,c=3,t=8,pt=1,l=1,sg=0,st=fail:0
                                          2016-05-28 18:24:11.594 [DEBUG] [.b.m.internal.MySensorsBinding] - Gateway Version: 1.5.4
                                          2016-05-28 18:25:11.141 [DEBUG] [.b.m.internal.MySensorsBinding] - I_LOG_MESSAGE: read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
                                          2016-05-28 18:25:11.155 [DEBUG] [.b.m.internal.MySensorsBinding] - internalReceiveUpdate(Motion,OFF) is called!
                                          2016-05-28 18:25:11.165 [DEBUG] [.b.m.internal.MySensorsBinding] - Motion = OFF
