  3. Dallas temp sensor in Fahrenheit, must be celsius
11 Posts 3 Posters 4.6k Views 2 Watching
  • P Offline
    P Offline
    Petjepet
    I'm a bit confused on the temperatures my DST is sending.
    send: 0-0-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 0-0-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
    send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    sensor started, id=0, parent=0, distance=0
    send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
    send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
    send: 0-0-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:75.8
    send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:73.7
    send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:72.8
    send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:72.1
    send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:71.7
    I used the standard sketch where I see this 'boolean metric' setting (I guess for arranging this):
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    My Pimatic shows the temp as 70 C.
    I think it is a Fahrenheit vs Celsius mix-up since 70 F is about 21 C which would be correct.
    • S Offline
      If i read the log correctly: send: 0-0-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok: is a request for Metric/Farenheit but the controller does not seem to respond.
      You should have something like:
      read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      • P Offline
        P Offline
        Petjepet
        Strange. I can not see what goes wrong.
        I updated the sketch to just use Celsius.
        Replace this (for the Temperature sketch) from:
         float temperature = static_cast<float(static_cast<int((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        With this
         float temperature = static_cast<float>(static_cast<int>((sensors.getTempCByIndex(i)) * 10.)) / 10.;
        Related to this topic and the fact I used CodeBender I guess somewhere there is the problem.
        The IsMetric function doesn't seem to work.
        • P Offline
          P Offline
          Petjepet
          I tried again to get it to work with the original sketch.
          1. send: 0-0-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
          2. send: 0-0-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
          3. send: 0-0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          4. sensor started, id=0, parent=0, distance=0
          5. send: 0-0-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
          6. send: 0-0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
          7. send: 0-0-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
          8. send: 0-0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:66.6
          Should the M appear in line 7?
          What is deciding in going for Imperial or Metric?
          Can anyone help me out?
          • hekH Offline
            hekH Offline
            You should get a in INTERNAL/I_CONFIG message from controller. With a payload of "M".
            Line 7 is the presentation message from your sensor (c=0=PRESENT).
            I cannot see any incoming traffic from your gateway.. Do you have some kind of communication problems? You should have a look in the gateway log.
            P 1 Reply Last reply
            • P Offline
              P Offline
              Petjepet
              Line 8 is giving the temperature and will keep doing this.
              It is also accepted by my controller (Pimatic on a RasPi) and therefore I did not think of a communication problem.
              Where can I find this gateway log?
              I'm pretty new to this so still learning :smiley:
              • hekH Offline
                hekH Offline
                You might wanna check with the Pimatic plugin developer here (in the Pimatic sub forum) or in the Pimatics community.
                  P Offline
                  P Offline
                  Petjepet
                  wrote on last edited by Petjepet
                  Is this the gateway log?
                  debug [pimatic-mysensors]: <- MySensorDST  { sender: 0, sensor: 0, type: 0, value: '72.2' }
                  15:47:17
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0:72.2
                  15:45:02
                  debug [pimatic-mysensors]: <- MySensorDST  { sender: 0, sensor: 0, type: 0, value: '72.1' }
                  15:45:02
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0:72.1
                  15:45:01
                  debug [pimatic-mysensors]: <- Presented Node  [ '0', '0', '0', '0', '6', '' ]
                  15:45:01
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
                  15:45:01
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
                  15:45:01
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0:Temperature Senso
                  15:44:59
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                  15:44:59
                  debug [pimatic-mysensors]: <- Presented Node  [ '0', '255', '0', '0', '17', '1.5.3' ]
                  15:44:59
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.3
                  15:44:59
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                  15:44:53
                  15:44:53
                  15:44:53
                  15:44:53
                  debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;0;3;0;9;read: 0-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0:0'
                  I do not see a INTERNAL/I_CONFIG message.
                  • P Offline
                    P Offline
                    Petjepet
                    Got it working now :smiley:
                    I installed Arduino software and mysensors api again.
                    Reloaded my gateway from this install.
                    On the node ran the EEPROM sketch from mysensors library and reloaded the DST sketch from also the mysensors library.
                    I think something went wrong in library updated Arduino suggested.
                    @hek Is it essential to work from the mysensors library (as distributed in the api) and keep that as a stable set and ignoring library updated suggested by the Arduino software?
                    And when updating libraries they will updated in a My Documents folder causing Arduino software to generate issues on compiling of having libraries twice. What is the way to work on this?
                    • hekH Offline
                      hekH Offline
                      You got a bigger chance of getting help if you keep the versions in the distribution.
                      But it's not optimal in any way. Would've been nice if the IDE would have some sort package manager like Node where version could be specifed.
                      • P Offline
                        P Offline
                        Petjepet
                        I agree.
                        It is very hard/difficult to keep a consistent set of libraries operational in a broader scope of elements to be managed.
