  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
    Slorf
    Nice !!!
    I am still waiting for some parts to arrive from china :-(
    Alex
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      Wow ! I really like the color and design.
      Waiting for alpha testing of the nrf chip.
      Is soldering it more difficult than soldering the atmega as they are not the same package type ?
      Y 1 Reply Last reply
      • KoreshK Koresh
        First small batch is completed :)
        R
        R
        robosensor
        wrote on last edited by robosensor
        #62
        @Koresh what about price for assembled boards?
        KoreshK 1 Reply Last reply
        • R robosensor
          KoreshK
          KoreshK
          Koresh
          @robosensor So far 9-10$ for each board. Small batch and not mass production soldering... Negotiating smd services for PCBA. Hope to reduce costs by $2 final. Will see what happens.
            Y
            Y
            yury
            wrote on last edited by yury
            #64
            3 steps process:
            1. tin-plating the board contacts
            2. tin-plating the chip contacts
            3. apply flux-gel and place chip on the board and heat it with soldering Heat Blower - pre-heat-wait-heat-wait . Like standard soldering profile http://www.renesas.eu/products/lead/specific_info/rt/heatproof/index.jsp .
            also need to have a good ayes ))) the flux-gel should be the one you do not have to remove after.
            • Sander TeunissenS
              Sander TeunissenS
              Sander Teunissen
              You make some... I'll buy some... great work!
              • Y
                Y
                yury
                Alfa testing:
                Checking radios as various nodes. Currently working as 2 relay nodes, DHT 22 temperature node and gateway.
                All is good . Range 1-2 meters less than NRF24 with big antenna in apartment surrounding.
                Digital pins cheeked like in the video: https://youtu.be/00fy9amZnt4
                Analog pins tested with generic arduino light sensor. So radios and pins are OK.
                • Sander TeunissenS Sander Teunissen
                  Y
                  Y
                  yury
                  #67
                  So far still negotiating\finding reliable PCBA. First batch of 17 boards Koresh and me we were not impressed.
                  • Sander StolkS
                    Sander StolkS
                    Sander Stolk
                    Keep me posted!
                    Will order when board comes soldered and ready to use!
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      Congratulations !!! Best hardware project indeed !
                        shabba
                        I would be all over this (would get a dozen!) if using RF69. Should be handy enough to modify? I better start watching those KiCad tutorials!
                        • GertSandersG GertSanders
                          KoreshK
                          KoreshK
                          Koresh
                          @GertSanders Thanks! :)
                          @shabba I've almosted completed new ultrasmall radionode based on rfm69. I'am very busy now but I hope to finish all tests in a week. I will post board asap :)
                          scalzS 1 Reply Last reply
                          • KoreshK Koresh
                            @Koresh wow looks promising :) I can't wait!!! I thought that sub Ghz antenna is bigger than 2.4ghz??
                              shabba
                              I would think we would solder on out own antenna.
                                oh maybe I didn't understand well, I thought that semtech ic (rfm69) would be onboard?? because if we wire our antenna, I don't see well why not use rfm69 module instead. In case of pcb antenna trace, ic onboard makes more sense imho. but maybe I'm wrong..I thought to give a try to this sometimes ago but had this reflexion,..and good design of pcb antenna trace for 433-915mhz is a lot bigger than 2.4ghz nrf. and smaller trace, lower range..+ need to be tuned for each design (in theory, I'm not expert)
                                that's cool because koresh is skilled at this :) lot of thing to learn! so I can't wait to see or try one board!
                                  Slorf
                                  @Koresh
                                  I got all the parts, but I think the NRF24L01 is the normal version and not the + version, there is no + to be found on the chip.
                                  Would the older NRF24L01 ( without plus ) work on the board ?, or do I have to use the R1 resistor ?
                                  ( Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
                                  Alex
                                  • S Slorf
                                    @Koresh
                                    Alex
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    @Slorf It depends on crystal. If oscillator starts and works correctly some days you can omit it.
                                      Slorf
                                      @Koresh
                                      Ermm... how do I know it works correctly ?, and if it doesn't work correctly which 1M resistor do I have to use ?
                                      Thanks for your help !!!
                                      Alex
                                      • S Slorf
                                        @Koresh
                                        Alex
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @Slorf NRF oscillator can work or not (or could stop after some time). If problems appear use any 1m resistor (0402 or 0603 if you can solder it). Do not worry. It is the last stage (after nrf soldering and atmega programming).
                                        Can you provide link to your nrf chip(where you buy it)? I want to check it.
                                          Slorf
                                          @Koresh
                                          Sorry for the late reply, our second son was born just 2 weeks ago.... no sleep anymore :-)
                                          It looks like this one, except mines it labelled: 0935VI, the one on the link 0935VJ
                                          http://www.aliexpress.com/store/product/NRF24L01-QFN20-24L01-SMD-chip-new-original-SDQYS/1823911_32468479303.html
                                          sundberg84S Y 2 Replies Last reply
