  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 70.9k Views 36 Watching
  • flozscF
    flozscF
    flozsc
    @Koresh Thanks for your quick reply.
    Sleeping sometimes helps. ;-) After thinking over it again, I think I'll prepend a step-up converter to 5V behind the battery as most sensors at least require 3.3V or even 5V... :)
    Looking forward to your update on the 20 test boards!
    • Y
      Y
      yury
      So far betatests for two modules soldered manually two weeks ago are good. I was using two analog inputs and 5 digital outputs. Radio is rock stable also.0_1457364082654_1745f59fdda935cd02a9fcf4f5f741a256b98564f4610991d6c502bc6aec6aa6.jpg
      • fifipil909F
        fifipil909F
        fifipil909
        Impressive !!
        did you reflow the board, or did you REALLY manually solder the nrf24l chip with an iron ???
        KoreshK 1 Reply Last reply
        • fifipil909F fifipil909
          Impressive !!
          KoreshK
          KoreshK
          Koresh
          @fifipil909 Thanks.
          I've soldered these boards using simple soldering iron and hot air fan (lukey 702).
          • KoreshK
            KoreshK
            Koresh
            wrote on last edited by Koresh
            #58
            First small batch is completed :)
            R 1 Reply Last reply
              excellent :laughing:
                Slorf
                Nice !!!
                I am still waiting for some parts to arrive from china :-(
                Alex
                • ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  Wow ! I really like the color and design.
                  Waiting for alpha testing of the nrf chip.
                  Is soldering it more difficult than soldering the atmega as they are not the same package type ?
                  Y 1 Reply Last reply
                  • KoreshK Koresh
                    R
                    R
                    robosensor
                    wrote on last edited by robosensor
                    #62
                    @Koresh what about price for assembled boards?
                    • R robosensor
                      KoreshK
                      KoreshK
                      Koresh
                      @robosensor So far 9-10$ for each board. Small batch and not mass production soldering... Negotiating smd services for PCBA. Hope to reduce costs by $2 final. Will see what happens.
                        Y
                        Y
                        yury
                        wrote on last edited by yury
                        #64
                        3 steps process:
                        1. tin-plating the board contacts
                        2. tin-plating the chip contacts
                        3. apply flux-gel and place chip on the board and heat it with soldering Heat Blower - pre-heat-wait-heat-wait . Like standard soldering profile http://www.renesas.eu/products/lead/specific_info/rt/heatproof/index.jsp .
                        also need to have a good ayes ))) the flux-gel should be the one you do not have to remove after.
                        • Sander TeunissenS
                          Sander TeunissenS
                          Sander Teunissen
                          You make some... I'll buy some... great work!
                          • Y
                            Y
                            yury
                            Alfa testing:
                            Checking radios as various nodes. Currently working as 2 relay nodes, DHT 22 temperature node and gateway.
                            All is good . Range 1-2 meters less than NRF24 with big antenna in apartment surrounding.
                            Digital pins cheeked like in the video: https://youtu.be/00fy9amZnt4
                            Analog pins tested with generic arduino light sensor. So radios and pins are OK.
                            • Sander TeunissenS Sander Teunissen
                              Y
                              Y
                              yury
                              #67
                              So far still negotiating\finding reliable PCBA. First batch of 17 boards Koresh and me we were not impressed.
                              • Sander StolkS
                                Sander StolkS
                                Sander Stolk
                                Keep me posted!
                                Will order when board comes soldered and ready to use!
                                • GertSandersG
                                  GertSandersG
                                  GertSanders
                                  Congratulations !!! Best hardware project indeed !
                                    shabba
                                    I would be all over this (would get a dozen!) if using RF69. Should be handy enough to modify? I better start watching those KiCad tutorials!
                                    • GertSandersG GertSanders
                                      KoreshK
                                      KoreshK
                                      Koresh
                                      @GertSanders Thanks! :)
                                      @shabba I've almosted completed new ultrasmall radionode based on rfm69. I'am very busy now but I hope to finish all tests in a week. I will post board asap :)
                                      scalzS 1 Reply Last reply
                                      • KoreshK Koresh
                                        @Koresh wow looks promising :) I can't wait!!! I thought that sub Ghz antenna is bigger than 2.4ghz??
                                          shabba
                                          I would think we would solder on out own antenna.
