  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.1k Views 36 Watching
  • R robosensor
    @Koresh what about price for assembled boards?
    KoreshK
    KoreshK
    Koresh
    @robosensor So far 9-10$ for each board. Small batch and not mass production soldering... Negotiating smd services for PCBA. Hope to reduce costs by $2 final. Will see what happens.
      Wow ! I really like the color and design.
      Waiting for alpha testing of the nrf chip.
      Is soldering it more difficult than soldering the atmega as they are not the same package type ?
      Y
      Y
      yury
      wrote on last edited by yury
      #64
      3 steps process:
      1. tin-plating the board contacts
      2. tin-plating the chip contacts
      3. apply flux-gel and place chip on the board and heat it with soldering Heat Blower - pre-heat-wait-heat-wait . Like standard soldering profile http://www.renesas.eu/products/lead/specific_info/rt/heatproof/index.jsp .
      also need to have a good ayes ))) the flux-gel should be the one you do not have to remove after.
      • Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        You make some... I'll buy some... great work!
        Y 1 Reply Last reply
        • Y
          Y
          yury
          Alfa testing:
          Checking radios as various nodes. Currently working as 2 relay nodes, DHT 22 temperature node and gateway.
          All is good . Range 1-2 meters less than NRF24 with big antenna in apartment surrounding.
          Digital pins cheeked like in the video: https://youtu.be/00fy9amZnt4
          Analog pins tested with generic arduino light sensor. So radios and pins are OK.
          • Sander TeunissenS Sander Teunissen
            Y
            Y
            yury
            #67
            So far still negotiating\finding reliable PCBA. First batch of 17 boards Koresh and me we were not impressed.
            • Sander StolkS
              Sander StolkS
              Sander Stolk
              Keep me posted!
              Will order when board comes soldered and ready to use!
              • GertSandersG
                GertSandersG
                GertSanders
                Congratulations !!! Best hardware project indeed !
                KoreshK 1 Reply Last reply
                  shabba
                  I would be all over this (would get a dozen!) if using RF69. Should be handy enough to modify? I better start watching those KiCad tutorials!
                  • GertSandersG GertSanders
                    KoreshK
                    KoreshK
                    Koresh
                    @GertSanders Thanks! :)
                    @shabba I've almosted completed new ultrasmall radionode based on rfm69. I'am very busy now but I hope to finish all tests in a week. I will post board asap :)
                    scalzS 1 Reply Last reply
                    • KoreshK Koresh
                      @Koresh wow looks promising :) I can't wait!!! I thought that sub Ghz antenna is bigger than 2.4ghz??
                        shabba
                        I would think we would solder on out own antenna.
                          oh maybe I didn't understand well, I thought that semtech ic (rfm69) would be onboard?? because if we wire our antenna, I don't see well why not use rfm69 module instead. In case of pcb antenna trace, ic onboard makes more sense imho. but maybe I'm wrong..I thought to give a try to this sometimes ago but had this reflexion,..and good design of pcb antenna trace for 433-915mhz is a lot bigger than 2.4ghz nrf. and smaller trace, lower range..+ need to be tuned for each design (in theory, I'm not expert)
                          that's cool because koresh is skilled at this :) lot of thing to learn! so I can't wait to see or try one board!
                            Slorf
                            @Koresh
                            I got all the parts, but I think the NRF24L01 is the normal version and not the + version, there is no + to be found on the chip.
                            Would the older NRF24L01 ( without plus ) work on the board ?, or do I have to use the R1 resistor ?
                            ( Resistor 1M ( which package size ) - unnecessary element (R1 can be mounted for backward compatibility with nRF24L01, nevermind)
                            Alex
                            • S Slorf
                              @Koresh
                              Alex
                              KoreshK
                              KoreshK
                              Koresh
                              @Slorf It depends on crystal. If oscillator starts and works correctly some days you can omit it.
                                Slorf
                                @Koresh
                                Ermm... how do I know it works correctly ?, and if it doesn't work correctly which 1M resistor do I have to use ?
                                Thanks for your help !!!
                                Alex
                                • S Slorf
                                  @Koresh
                                  Alex
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  @Slorf NRF oscillator can work or not (or could stop after some time). If problems appear use any 1m resistor (0402 or 0603 if you can solder it). Do not worry. It is the last stage (after nrf soldering and atmega programming).
                                  Can you provide link to your nrf chip(where you buy it)? I want to check it.
                                    Slorf
                                    @Koresh
                                    Sorry for the late reply, our second son was born just 2 weeks ago.... no sleep anymore :-)
                                    It looks like this one, except mines it labelled: 0935VI, the one on the link 0935VJ
                                    http://www.aliexpress.com/store/product/NRF24L01-QFN20-24L01-SMD-chip-new-original-SDQYS/1823911_32468479303.html
                                    sundberg84S Y 2 Replies Last reply
                                    • S Slorf
                                      @Koresh
                                      sundberg84S
                                      sundberg84S
                                      @Slorf said:
                                      @Koresh
                                      Congrats!!! :baby: :sleeping: :smiley:
                                      • S Slorf
                                        @Koresh
                                        Y
                                        Y
                                        yury
                                        @Slorf said:
                                        reply
                                        Congrats and enjoy ))
                                        • Sander TeunissenS
                                          Sander TeunissenS
                                          Sander Teunissen
                                          @koresh Just created a light sensor from one of the boards I bought from you. It works great !
                                          I had to do some tweaking with the serial monitor speed from my arduino IDE (I had to double the speed which was set in the code or something)
                                          I also had to press the reset button just before uploading of the sketch started.
                                          Apart from that: Great !
                                          Thanks !
